Need help ID Running Boards
Discussion in '2.5 Gen Tundras (2014-2021)' started by gizmo1086, Aug 1, 2024.
  1. Aug 1, 2024 at 5:32 AM
    gizmo1086
    gizmo1086 [OP] New Member
    2020 Tundra TRD Pro Army Green
    I need to identify the running boards on my truck. It’s a 2020 TRD Pro and has all black running boards. The rear end caps are chipping and I need to figure out what way to go. If I can replace the caps I’ll do that, otherwise it might be a good time to just remove or replace the boards.
  2. Aug 1, 2024 at 5:41 AM
    Tripleconpanna
    2021 TRD PRO CM; 2008 SR5 CM
    I pulled what looks the same set off of my '21 Pro... what part of the country do you live in??
  3. Aug 1, 2024 at 5:43 AM
    gizmo1086
    I’m in Indiana, but the Truck is from Oklahoma.
    Tripleconpanna likes this.
  4. Aug 1, 2024 at 5:45 AM
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Those look like factory Toyota to me...
  5. Aug 1, 2024 at 8:02 AM
    Tripleconpanna
    I was going to say if you're close to the PNW, you're welcome to take a look at the ones I pulled off my '21 and see if they'd work for you...
  6. Aug 1, 2024 at 8:05 AM
    Tripleconpanna
    They do, and I think there are ones that are Toyota OE like that. However, I don't think the ones they hung on my '21 Pro were as I couldn't find a single OE part #, label, etc.. anywhere on them. The satin/black ones on my '08 have Toyota part#s and Toyota badging on the steps...
    I think some of what got thrown on these later Gen 2.5s may not have been OE toyota parts :notsure:
    gizmo1086[OP] likes this.
  7. Aug 1, 2024 at 8:55 AM
    ejes
    ejes New Member
    2020 1794 Tundra / 2023 4Runner TRD PRO
    I believe the Toyota part numbers are 20315192 and 20315191. I might be wrong, but I think they were made for Toyota by Westin.
  8. Apr 5, 2025 at 4:58 AM
    Retired...finally
    Rather than start a new thread on the ID of running boards I thought I'd just add to this one. A FB marketplace has a set for a 2014 CM and I have a 2021 CM. Will these older running boards fit my newer model and can anyone identify these? Price is $75.Screenshot_20250404-172901.png
  9. Apr 5, 2025 at 6:22 AM
    Tripleconpanna
    Yes, the 2014 will line up and work for a 2021...
    That being said, those are probably not OE Toyota running boards (if that matters to you)... I have those exact boards on my '08, and the black 'step' are stamped w/Toyota's insignia. In my experience, many of these aftermarket boards rust easier and simply are not the same quality as the older OE Toyota products. But, $75 isn't bad, and those appear to be in good shape. If you're somewhere that does have rust issues, just use a coating on the brackets and underside of the boards and you should be fine.
    Finally, if you flip them upside down or have the seller do that, you'll be able to see a Toyota part# if they are OE...
  10. Apr 5, 2025 at 8:02 AM
    Retired...finally
    Thanks for the reply and good information. The seller states they are stainless. Talked it over with my wife and she doesn't think it will help her in any appreciable way getting in or out of the Tundra so I'm going to pass on the running boards. BTW, they are in Newark Ohio if anyone is interested.
