Need help getting ACC 12v to hook up my 300watt led light bar
Discussion in '2nd Gen Tundras (2007-2013)' started by atrinh15, Apr 20, 2015.
  1. Apr 20, 2015 at 7:38 PM
    atrinh15
    atrinh15 [OP] New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    So i don't want to hook straight to the battery because there will be a draw on the lighted switch. So I would like to hook up to acc but not rob it from the auxiliary or cig outlets. Thinking of using a relay but not sure the wiring diagram. I found this in Google can someone tell me me if this right 525d83ff490ef0621a7244b08cd6e9ca_285fec4c0f5455b709f3ddf60cfd54fff204e476.jpg
  2. Apr 20, 2015 at 7:40 PM
    atrinh15
    495-93 area
    Plan on using a fuse block so i can have access to it for other accessories as well.
  3. Apr 20, 2015 at 8:00 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Looks right. Here is the relay I got (with harness) for my tacoma. Install wasn't bad.
    http://www.oznium.com/relay40
    Fuse block is a good idea.
  4. Apr 21, 2015 at 4:54 PM
    atrinh15
    495-93 area
    Well the lights came with a complete wiring kit but i wanted to do a ACC wire for the power end instead of using the battery.
  5. Apr 21, 2015 at 5:57 PM
    Virgils12
    Virgils12 New Member
    Camburg Fox factory 2.5" lift Xd monsters with 295/70/18 nitto terra graplerrs Corsa cat back Weather tech liners Wet okole covers
    Painless makes some nice blocks.
  6. Apr 21, 2015 at 6:01 PM
    Mike Tread lightly.
    south carolina
  7. Apr 21, 2015 at 7:15 PM
    atrinh15
    495-93 area
    Ok cool. Im just gonna rewire the light kit than and add my fuse block. Thanks again.
  8. Apr 21, 2015 at 10:35 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    The diagram looks fine but you're going to want to go with a 30A fuse and a 40 amp relay. 20A called out in the diagram won't cut it.
    300W / 12V = 25 Amps.
  9. Apr 23, 2015 at 10:29 AM
    atrinh15
    495-93 area
    I bought this fuse block on ebay before you posted about blue sea. 79abfedf876e6b4f154cf2be32f5ab22_270fadf6d50410c55dec47906a99141640fcf5a7.jpg
  10. Apr 23, 2015 at 4:21 PM
    Mike Tread lightly.
    south carolina
    That will work put it in a nice high DRY spot and you will be fine.
  11. Apr 23, 2015 at 8:10 PM
    atrinh15
    495-93 area
    Is there a way to make the fuse block Acc. Im really just extending the battery into the cab. If i can than I could just wire it without going to the battery.
  12. Apr 26, 2015 at 9:22 AM
    Mike Tread lightly.
    south carolina
    You can with a relay. Only problem you will run into is amp draw and the rating on the relay how many amps it can handle.
