Need help diagnosing Coolant leak
Discussion in '1st Gen Tundras (2000-2006)' started by Stokeluke, May 29, 2016.
  1. May 29, 2016 at 12:37 PM
    Stokeluke
    Stokeluke [OP] New Member
    Hi everyone,
    I have a 2002 sr5 6-cyl, and I have a coolant leak. I'm losing some coolant but not too much, nothing to where the engine is overheating. Opened the hood noticed red coolant dried around every hose connection point, and then noticed coolant leaking out of the top of the radiator and dripping down.
    I'm wondering if I just need to get a new radiator?
    I've heard the stock ones end up cracking or the o ring gives out over time with the plastic ones.
    If someone could give me some advice on this that would be awesome.
    Thanks
  2. May 29, 2016 at 12:58 PM
    mdavis
    mdavis I need a beer.
    Michael
    Rock Hill, SC
    @Mike can help with this I'm sure.
  3. May 29, 2016 at 2:08 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    3.4 liter? There can be leaks anywhere??? Take pics
  4. May 29, 2016 at 3:49 PM
    Stokeluke
    Yes it's a 3.4 liter and here are some pics . And u can see that the coolant level is already low and just filled the other day image.jpg image.jpg image.jpg image.jpg
  5. May 29, 2016 at 4:01 PM
    Stokeluke
    All of the hoses seem to be in good condition. No cracking and the clamps are still very tight. As you can probably see as well I see that it looks like coolant has been sprayed everywhere from it leaking while driving. So I feel like it has to do with the top of my radiator, but I don't know what's causing the dried crusty coolant around the connections.
    Let me know what you guys think.
    Thanks
  6. May 29, 2016 at 4:23 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Have you ever replaced the cap and hoses? You could try that first, something you'd probably want to do anyway if you replace the radiator. They're often considered preventative maintenance items, radiators, debatable. The cap and hoses are going to be cheaper as well considering that we're not sure it's the radiator. Also, you could pull it anyway and have it pressure tested.
  7. May 29, 2016 at 4:54 PM
    Mike Tread lightly.
    south carolina
    To me..
    Looks like your clamps are not tight enough. Im not seeing enough squeeze in the tubing for my liking but not too tight. The hoses tho good can still leak. To me looks like your radiator is or near failure. If you have the plastic radiator they fail quickly.
    IMO replace all hoses and radiator but I need more pics.
    T-Rex266, LOTSOFTOYS and 15whtrd like this.
  8. May 29, 2016 at 5:06 PM
    Stokeluke
    Alright I'll think I'll go ahead and just replace the radiator and hoses, haven't done it for a while.
    Do you have any recommendations for a good radiator that won't have this problem again. One with out the plastic?
    Thanks.
  9. May 29, 2016 at 5:18 PM
    Mike Tread lightly.
    south carolina
    I hate to say it but aftermarket ones are all made in China and probably made by the same company just different names. I have one on my Tacoma with the 5vz-fe(v6) and really no problems been on there 4 years now plus. It's plastic. Most all radiators today are plastic. It's not that it's plastic is not the problem, just like if it was metal it just wears out from all the stress and heat.
    I recommend you replace those clamps just to be safe. They are cheap insurance.
    T-Rex266 and 15whtrd like this.
  10. May 29, 2016 at 6:45 PM
    LOTSOFTOYS
    Jace
    Mile high
    2005 Tundra DBL cab
    This ^ throw hoses, clamps and a radiator I'm it
    T-Rex266 likes this.
  11. May 29, 2016 at 10:07 PM
    Stokeluke
    Just went with everyone's advice and ordered a new radiator, hoses, clamps.
    Thanks for everyone's help!
