Need help cleaning engine block. RAT NEST!
Discussion in '1st Gen Tundras (2000-2006)' started by H1N1777, Jul 12, 2018.
  1. Jul 12, 2018 at 4:57 PM
    H1N1777
    H1N1777 [OP] New Member
    Gary
    Orange County, CA
    2002 Tundra V8
    Hello! I recently got my truck from my grandmother who lives out in the country. The truck has had rats making nests in the engine and bringing in all sorts of old bedding chunks and whatnot. It was all cleaned out when I got the truck, but I found some pink fuzzy material and rat droppings hidden underneath the center of the engine. After further investigation I found what looked to be like a dead rat. A49FA5D5-D53D-457C-89F1-CAB9508D4831.jpg F3CFE22C-8DF9-4A82-8BBD-74EF88D3FE4F.jpg CCF44088-3CF0-475D-BBAC-DC0093286FC9.jpg
    92ECD556-8B77-4DCF-AE27-447F568579B8.jpg I first noticed this when I found a few ants in my truck and around the hood area. Is there a way I can get in there or take parts off to get to that area to blow it all out? I’m worried about a fire starting. Plus a dead rat in the engine isn’t cool. Any help is appreciated! Thanks!
  2. Jul 12, 2018 at 6:41 PM
  3. Jul 12, 2018 at 6:45 PM
    Sterlinglwood
    Sterlinglwood Never enough!
    Sterling
    Newbury Park, CA
    2017 Tundra Double Cab SR5 4X4
    Either spray all that shit out with a pressure washer or :bananadead:
  4. Jul 13, 2018 at 4:11 AM
    Professional Hand Model
    Hand Protectors
    Put a stick in there and get the big stuff out, then blow the rest out. Start up the engine and use a soft RV brush with a bucket of water with some degreaser to clean the entire engine. Sparkles!
    H1N1777[OP] likes this.
  5. Jul 13, 2018 at 5:53 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Welcome from CO!
  6. Jul 13, 2018 at 5:57 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    Maybe at minimum wear a dust mask. Can rats carry Hantavirus?
    Brown Bear, H1N1777[OP] and landphil like this.
  7. Jul 13, 2018 at 6:16 AM
    Mark843
    Mark843 New Member
    Mark
    WNY
    2018 Barcelona Red Tundra SR5 with TRD offroad package
    I would start with a shopvac with one of those thin extension wands. You might be able to suck out the majority. If you start with a hose, it will just blow stuff everywhere. After I sucked out what I could., then I would use a garden hose before using a pressure washer.
    mve, BestGen, 15whtrd and 2 others like this.
  8. Jul 13, 2018 at 6:34 AM
    Damn!
    I have a buddy that lost his diesel truck from this. Pack Rats built a nest next by the turbo, the nest ignited while driving and he had the privilege of watching his truck burn to the ground.
    I check under my hood of my truck before I drive it (1-2 times per month) due to this experience.
  9. Jul 13, 2018 at 6:36 AM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    That would suck. I don’t think I could keep a vehicle that was taken over by rodents. Disgusting little bastards.
    I always see rabbits hanging around the parking lot at work. Wish I could pick them off before I park.
  10. Jul 13, 2018 at 9:26 AM
    Tundradrenalin
    Tundradrenalin New Member
    Virginia Beach, VA
    2016 DC Black TRD nonPRO
    Methods, Toyos, Kings, TCs, CBs
    remove the plenum and clean it out before you spray it and make it all wet
    that looks nasty.
  11. Jul 13, 2018 at 9:47 AM
    H1N1777
    Gary
    Orange County, CA
    2002 Tundra V8
    F91D0793-DD90-4F7F-B59C-0600C0445F20.jpg Here’s another pic of all the crap we pulled out. I forgot to post this one, it was taken before I noticed the dead rat.
    BTBAKER likes this.
  12. Jul 13, 2018 at 9:48 AM
    owb2gp
    owb2gp New Member
    ID
    X2
  13. Jul 13, 2018 at 9:56 AM
    Hand Protectors
    Might want to check your attic for rats too. That pink stuff looks like blown in insulation (from an attic). Too hot to harbor in the attic in summer so they find cooler places.
    landphil and H1N1777[QUOTED][OP] like this.
  14. Jul 13, 2018 at 9:56 AM
    15whtrd
    15whtrd Mr. Blonde
    Start with the shopvac as others said. Long needle nose pliers to grab that dead sucker. Then wash the shit out of it.
    landphil and H1N1777[OP] like this.
  15. Jul 13, 2018 at 9:58 AM
    owb2gp
    owb2gp New Member
    ID
    Nasty little :censored:
    H1N1777[QUOTED][OP] likes this.
  16. Jul 13, 2018 at 9:58 AM
    Hand Protectors
    Do not use a shop vac as it will then be contaminated with the funk. Use a stick, then hose it down, then wash engine.
    BestGen, H1N1777[OP] and Jengel451 like this.
  17. Jul 13, 2018 at 9:58 AM
    Jengel451
    Jengel451 Misanthropist
    The Bitterroot, MT
    2017 Barcelona TRD Limited CrewMax
    3/1.5 Toytec/Icon AAL, 17" Rebounds, 317-70-70 ST Maxx's
    don't use a shop vac for mouse/rat droppings etc. sure fire way to get hunta. The exhaust from the shop vac will blow that around. Seriously, don't mess around with that. Use water, LOT's of it.
  18. Jul 13, 2018 at 10:00 AM
    Hand Protectors
    I’m considering a rat cam mod for such an event. Any reccos on a heat resitant camera. How should it be wired? Thanks in advance!
  19. Jul 13, 2018 at 10:19 AM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    1.suck
    2.blow
    3.wash
    4.rinse
  20. Jul 13, 2018 at 10:21 AM
    owb2gp
    owb2gp New Member
    ID
    Sounds like something you would get at a strip club.
  21. Jul 13, 2018 at 10:26 AM
    BuckWallace
    BuckWallace Ball don't lie.
    Oregon
    Sierra 3500 AT4 L8T
    I think you're going about this the wrong way...
  22. Jul 13, 2018 at 10:26 AM
    ToyotaTundraMike
    2015 Tundra
    My kind of party
  23. Jul 13, 2018 at 11:26 AM
    Casper421
    In the woods
    06 DC
    I would use a flexible cable pick-up tool with the 4 claw end to grab the dead rat first then wash all the shit out of there. DONT use a shop vac like others mentioned!
    H1N1777[OP] and BestGen like this.
  24. Jul 13, 2018 at 11:31 AM
    TheBeast The Beach
    rat BBQ
  25. Jul 13, 2018 at 11:32 AM
    BestGen
    BestGen New Member
    Paul
    Haunted Turnbull Canyon CA
    '05 RCLB, 2UZ-FE, 4wd / '88 4RNR XTE 22RE/W56/RF1A
    Fabtech 2.5" coilovers, BFG KO2 34/10.5/17, 17x7.5 TE wheels, add-a-leaves, 4.56 gears, Rhino-lined
    Always cover your mouth and nose when dealing with rodent droppings and bedding. Hantavirus is a killer.
    Casper421 and H1N1777[OP] like this.
  26. Jul 13, 2018 at 9:32 PM
    Redlineaz
    Redlineaz New Member
    :annoyed:I would release some stray cats into the engine bay (and home for that matter) and let them hang out there for a while until you make sure the rats are all gone...haha
  27. Jul 14, 2018 at 8:17 AM
    BestGen
    BestGen New Member
    Paul
    That's funny you say that because my grandpa in Utah would get a cat, starve it for a week, then put it up in the attic. My mom said they'd hear the cat killing the rodents during the night. Ah, the good ol days!
  28. Dec 14, 2018 at 11:02 AM
    Miami Vice
    Miami Vice New Member
    2018 Charcoal Grey Tundra SR5 CM
    None
    I use this, after finding rat nest under my 2018 Tundra Hood.....It works well
    Buy it from Amazon, $30
    $30.99[​IMG]
    Click image to open expanded view
    Fanhome Rodent Repellent car Rat Repellent car car Rat Repeller Vehicle Rodent Repellent Under Hood Rodent Repellent
    Jerry311SD likes this.
  29. Dec 18, 2018 at 10:57 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Did someone say rats nest? Like this?
  30. Dec 18, 2018 at 11:05 AM
    Hand Protectors
    Yooowwzzaa!!!
