Need Help! Blinker keeps blowing!
Discussion in '2nd Gen Tundras (2007-2013)' started by MookTastic, Aug 19, 2016.
  1. Aug 19, 2016 at 3:40 PM
    MookTastic
    MookTastic [OP] Because I was inverted!
    Trice
    Rapid City, SD
    2013 5.7L White D/C TSS Offroad Icon Stage 8
    Icon Stage 8 AlphaRex Headlights
    Need some help! So I have blown a DRL twice in one day. Something is making my blinker light pop I'm assuming. I'm not going to keep putting new bulbs in her until I know why. Anyone have any ideas, or have had this before?
  2. Aug 19, 2016 at 3:54 PM
    Fuses checked?
    Relays?
  3. Aug 19, 2016 at 3:58 PM
    Grounding? Somewhere?
  4. Aug 19, 2016 at 4:01 PM
    Mike Tread lightly.
    south carolina
    Could be a turn signal relay.. if you have a trailer hitch wiring make sure nothing is in the plug making it goto ground.
  5. Aug 19, 2016 at 4:20 PM
    MookTastic
    Trice
    Rapid City, SD
    Ok false alarm. New bulb was not blown. I'm thinking maybe didn't haven't it seated right. Will update if problem returns. Thanks for all the input fellas!
  6. Aug 19, 2016 at 5:52 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Low on blinker fluid?
  7. Aug 19, 2016 at 5:56 PM
    Nor7
    Nor7 Chilton Manual Guy
    2007 Tundra Limited CM, 5.7L
    x2 on the blinker fluid.
  8. Aug 19, 2016 at 6:05 PM
    MookTastic
    Trice
    Rapid City, SD
  9. Aug 19, 2016 at 6:25 PM
    David2013Tundra
    David2013Tundra New Member
    David
    2013 Tundra DC 5.7
    x2 Fuses checked? The fuse in the cabin was the culprit when my DRL was not working.
  10. Aug 19, 2016 at 6:33 PM
    No, low on air grease for OXY sensors.. Obvious.
  11. Aug 19, 2016 at 6:38 PM
    csuviper
    Broomfield, CO
    He did say he figued it out. Was just making a joke....Or was I?
  12. Aug 19, 2016 at 6:38 PM
    MookTastic
    Trice
    Rapid City, SD
    Keep this mind. Thank you
  13. May 22, 2020 at 4:35 PM
    Mcollins-az
    Mcollins-az New Member
    Michael
    2014 Tundra
    I had same problem. Have to put pressure on new bulb until it snaps in. Feels like its in but need the snap.
  14. May 23, 2020 at 7:36 PM
    Dr_Al
    Dr_Al New Member
    Al
    I had the same problem with the one in the headlight. It would stop working and you would have to twist the bulb to make it work. People need to read. Why would a fuse be something you would point to for a bulb blowing? A bad alternator regulator sending too much voltage, possible, but a fuse?
