Need garage ideas
Discussion in 'General Tundra Discussion' started by Bear, Sep 2, 2017.
  1. Sep 2, 2017 at 3:19 PM
    Bear
    Bear [OP] Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    I can pull the Tundra in...with 14ft to spare. Can literally 3 point turn the wife's WRX inside...go in one door, out the other.
    It has a killer old wood stove and is set for a furnace (oil tank). Don't think I'll go the oil heat route, as I have more wood on the property than I can ever use or harvest.
    I need ideas!!
  2. Sep 2, 2017 at 3:20 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    So :jellydance: of you right now
    JC303, 4x4_Angel, Bear[OP] and 2 others like this.
  3. Sep 2, 2017 at 3:28 PM
    Baja Mike
    Baja Mike Baja Aficionado
    South Bay, Ca.
    2016 Tundra TRD 4x4 SR5 white
    LED interior lights, Baja Designs foglights, Baja Designs S8 hood bulge light bar, LED bed lights, Baja Designs S8 amber bar in bumper on Rago Fab mounts, AMP Research bedstep, Switch Pros sp-9100, tinted door windows
    Work benches (longer one for multiple projects)
    Fridge
    Shelving units
    Finish dry walling the ceiling so you don't breathe in that insulation.
    Epoxy floor
    8-10 feet of concrete before the garage entrance (nice day and you might want to work on the truck outside)
    Welding area
    Fabrication area
    Stripper pole
    couple of fans for air flow/exhaust
    I chubbed up looking at that garage. WANT!
    4x4_Angel and Bear[OP] like this.
  4. Sep 2, 2017 at 3:40 PM
    Give it to me
    Lift
    Welder
    Work bench
    Tool bench
    Shelving
    Detailing spot (lol)
  5. Sep 2, 2017 at 3:55 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    That's a garage with a lot of potential! As a builder here is what I would do with your garage.
    1. Temporarily drop the ceiling fluorescent lights, the ceiling garage door tracks & garage door openers.
    2. Install either 5/8" drywall or 7/16" plywood on the ceiling to cover the insualtion.
    3. Build either a storage closet or shelves below the stairs.
    4. Power wash the concrete floors.
    5. Cover the floors with painters plastic.
    6. Paint the walls and ceilings
    7. Reinstall the ceiling lights and ceiling garage door hardware.
    8. Remove everything out of the garage and install an epoxy floor.
    9. Install Gladiator storage units on the walls and floor for storage.
    If you want to run additional electrical, pressure air lines, or water do that before you cover the ceiling or walls back up. I know this would take a good amount of work and money though. But we can all dream right.
  6. Sep 2, 2017 at 4:21 PM
    Tacogrande
    Tacogrande New Member
    Jeremy
    2016 SR5 dbl. cab long bed gray
    Husky weatherbeaters,short antenna,window deflectors
    My first thought...you will quickly run out of room. I could pull in 10 cars in my shop...now no way.
    Wood stoves smell..do you want everything smelling like smoke?
    Congrats! No matter what you do it's awesome to have your own shop.
  7. Sep 2, 2017 at 5:36 PM
    Nit2wn
    Nit2wn New Member
    James
    Alabama
    2013 Crewmax TRD 4wd
  8. Sep 2, 2017 at 5:45 PM
    Bear
    Bear
    Custer, SD
    Ah yes!! This is what I'm talking about!
    Dry wall ceilings already on list. Previous owner had about 5-6 sheets hanging around the basement. It'll be put to use.
    My kegerator and deep freeze/lagering cooler will be there as well. This will be the partial brew room. This would assume I'm keeping it heated 24/7, otherwise the keg/cooler go in the unfinished part of the basement and I can just brew out there in the garage.
    I want clean, and easy to maintain. The squirrels have taken hold lately...they have buried their nuts everywhere (giggity)
    Storage is a must, I like the understair suggestion.
    Too many ways this could go. Compressed air would be baller.
  9. Sep 2, 2017 at 5:47 PM
    Bear
    Bear
    Custer, SD
    My wife. "OH MY GOD!"
  10. Sep 2, 2017 at 6:11 PM
    jstchilln
    jstchilln New Member
    Larry
    Eastern Kansas
    2017 Tundra 4X4 SR5 Double Cab / TRD Off road Package
    TRD Pro Grille
    The Garage Journal is full of good info and people sharing good idea's.
  11. Sep 2, 2017 at 7:45 PM
    I don't like you right meow.
    The price you paid for that home/land/shop makes me dislike you even more. ;)
    Needs a bar, chairs, projection TV, and you would have the ultimate tailgating shop. These other guys have already recommended what I would have.
    All jokes aside, you have a great place, and I hope you have found your own little slice of heaven.
  12. Sep 2, 2017 at 8:18 PM
    1UPPER
    TEXAS
    Flux capacitor!
  13. Sep 2, 2017 at 8:20 PM
    csuviper
    Broomfield, CO
    This is is a pretty good list
  14. Sep 2, 2017 at 10:03 PM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
