Need advise
Discussion in 'Wheels & Tires' started by Teflondon100, Sep 14, 2018.
  1. Sep 14, 2018 at 2:17 PM
    Teflondon100
    Teflondon100 [OP] New Member
    2018 Tundra TRD Limited
    Just had coil overs installed today.
    Before measurement
    Driver front =36 3/4
    Passenger front = 37
    After measurement
    Driver front = 38 3/4
    Passenger front = 39
    I want to retain the factory TRD wheels and use the Nitto Ridge Grappler.
    I’m torn between sizes, 275x70x18 with 1 1/8 wheel spacers or 285x70x18.
    I’m not sure I could use wheel spacers with the 285x70’s.
    Can someone offer me advise on the selection of these two sizes.
    7547A61D-4A8A-4E8A-8AFC-0DE7A929BC01.jpg C49CF014-55BE-42CD-B1A5-52252EC22697.jpg
    Casper3 and 4x4_Angel like this.
  2. Sep 14, 2018 at 3:22 PM
    Teflondon100
    I’m leaning towards the 285’s.
    They are $100.00 and some change more than the 275’s.
    I’m not seeing that much rubber difference.
    But I only want to cry once.
    I would hate to go with a tire too small that I hate.
    jewsNbrews and Watt maker like this.
  3. Sep 15, 2018 at 4:13 PM
    Teflondon100
    I pulled the trigger on the 285x70x18 today.
    They are going to order them in and check fitment. If all goes well I should have pictures to post Monday.
  4. Sep 15, 2018 at 4:17 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Great choice. Can't wait to see the results.
    Teflondon100[OP] likes this.
  5. Sep 15, 2018 at 4:44 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
  6. Sep 16, 2018 at 4:14 PM
    Teflondon100
    That’s a great looking truck. Exactly the look I’m wanting.
    Do you mind sharing what wheels you’re running and the offset.
    Casper3[QUOTED] likes this.
  7. Sep 16, 2018 at 4:18 PM
    Teflondon100
    Also...do you mind sharing what brand slider or board that is.
  8. Sep 16, 2018 at 4:24 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    SCS ray 10 wheels +25 offset
  9. Sep 16, 2018 at 4:25 PM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
  10. Sep 16, 2018 at 4:25 PM
    Teflondon100
    I had ordered Spidertrax wheel spacers when I was in limbo about tire size.
    Does anyone think I could use the spacers with the 285’s and factory TRD wheels without rubbing.
    jewsNbrews likes this.
  11. Sep 16, 2018 at 4:26 PM
    Teflondon100
    Awesome...thank you
  12. Sep 16, 2018 at 4:28 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    You should be able to.
  13. Sep 18, 2018 at 10:17 AM
    Teflondon100
    Test fitting one now.
  14. Sep 18, 2018 at 4:10 PM
    Teflondon100
    Gained almost 1 inch of clearance.
    Rubbing on skid plate which is an easy fix.
    Wish I had went 295x70x18.
    Will post more pictures after wheel spacers.
    ECB87A2E-A15C-4F7D-BD7E-E6577629463C.jpg 896C4A74-DCA0-4432-977D-61124870C04B.jpg ECB87A2E-A15C-4F7D-BD7E-E6577629463C.jpg
    monaco730, Rica25, parker44 and 6 others like this.
  15. Sep 18, 2018 at 4:16 PM
    Blueknights75
    Ron
    Clayton, NC
    Looks perfect to me!
  16. Sep 18, 2018 at 5:05 PM
    Teflondon100
    Thanks
    I’m going to try the Spidertrax 1 1/4 wheel spacers and see how the fit and look.
    More to follow.
  17. Sep 19, 2018 at 4:33 AM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    OP I think those 285/70/18 are perfect. There isn't a huge height difference in them and the 295's, but according to Nitto's website, those 295's are 10 lbs heavier per tire! Going from stock, the 295's definitely will impact some power and mpg, as they are about 20 lbs heavier than stock tires.
    Not sure how, but the website says my 275/70/18 ridge grapplers are almost identical weight to the 285/70/18 at roughly 58 lbs. If I can stomach the $300 price difference in these sizes, I may go 285/70/18 next time haha.
  18. Sep 19, 2018 at 10:24 AM
    Teflondon100
    Thanks for all the kind responses.
    Still waiting on Fedex to show up with the wheel spacers.
    Meanwhile I removed the running boards. While practical...they definitely didn’t do anything for the looks.
  19. Sep 19, 2018 at 12:42 PM
    Rica25
    Ricardo
    Tulare
    I have 295 70 18 with 3k miles on them u wanna trade
  20. Sep 19, 2018 at 1:33 PM
    Teflondon100
    Got the spacers on and good to go. Totally changed the look.
  21. Sep 19, 2018 at 1:34 PM
    Teflondon100
    Thanks for the offer. I had luck with the Spidertrax and I’m totally happy now.
