Necessary to change gears with a 3" lift and 295/70-18 tires ?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Dustydirt19, Oct 24, 2016.
  1. Oct 24, 2016 at 3:49 AM
    Dustydirt19
    Dustydirt19 [OP] Hoghead
    Dustin
    Duluth, MN
    2015 Blue Ribbon Metallic 5.7L 4WD SR5 TRD DC
    ProComp 6" stage 2 lift 18x9 Fuel Vapor -12 offset 35x12.5 Nitto Ridge Grapplers BullyDog Tuner Gibson Metal Mulisha cat-back exhaust, S&B cold air intake, Color matched TRD PRO Grille, Compustar Remote Start N-Fab Hooped Nerf Bars, AMI Big stick antenna, Salex organizer and tray, Weathertech laser cut floor mats, Weathertech window deflectors Black out badge Black out front and rear bumper Black out flags 24/7 black out TRD Off-road decals Spray in Line-X Bedliner Scosche phone mount Soft rolling tonneau cover TRD pedals and footrest
    With a 3" lift and 295 70 18 tires on a '15 sr5 with the trd package is it necessary to change your gears? Pro...Cons... if it is necessary what's a good brand
  2. Oct 24, 2016 at 3:55 AM
    No...maybe if I had 37-30"
  3. Oct 24, 2016 at 8:36 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Tundras have PLENTY of power and torque. There's no need for regearing with 34". Not even close
    rons23 and zcarpenter92 like this.
  4. Oct 24, 2016 at 8:38 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    There are those who will swear tires of that size will turn your truck into a dog. Others say they can't tell the difference. Neither camp tends to show the difference on paper. I fall in the later camp. I put 285/65/R20's on (just slightly taller than yours), and I could not tell the difference. I guess it depends on how sensitively calibrated your butt dyno is. My advice would be to do your lift/upsize, followed by adding a speedo calibrator, followed by ZPC. Only then will you be in a position to determine if you really need a gear change.
