N-Fab Podium VS N-Fab Hoop Nerf Bars
Discussion in 'General Tundra Discussion' started by jcollinet, Jan 8, 2018.
  1. Jan 8, 2018 at 8:44 AM
    jcollinet
    jcollinet [OP] New Member
    2018 Tundra Crew Max, TRD Off Road Inferno
    I see there are two types of N-Fab Nerfbars, the Podium style and the Hoop style. Which do you think looks best on a CrewMax?
  2. Jan 8, 2018 at 8:50 AM
    Vendeta2k
    Jay
    Bozeman, Montana
    2018 Limited Cement CM
    I have the podiums on my CM. Chose them over the regulars for the bit of added safety of having the full plate on the hoop for when they are slick and icy here in Montana.
  3. Jan 8, 2018 at 9:38 AM
    Diverguy
    Diverguy Breathes under water
    Leon
    PA, USA
    2018 Tundra Limited TRD Offroad-Inferno
    Windows tinted, window visors. Bedrug, led bedlights, Nfab nerf step bars, Lund toneau cover, Evo One remote start, BAMufflers 8"
    Here’s mine. I have the hoop style. I figured they wouldn’t hold dirt, snow,and ice as much as the podium style.
    monaco730 likes this.
  4. Jan 8, 2018 at 10:20 AM
    Gonna order me the hoop style
  5. Jan 8, 2018 at 10:41 AM
    Festerw
    Festerw New Member
    Cambridge Springs, PA
    04 Tundra DC
    May not be an issue where some are from but I have the hoop style on my 04 and they can get pretty slippery in the rain or especially snow.
    trayday likes this.
  6. Jan 14, 2018 at 9:01 AM
    Les7311
    Les7311 Look up, what do you see
    2008 Blue Tundra TRD 4x4
    Just installed mine. Took me 3 1/2 freeeeeking hours to install.
    The instructions was pisss poor. My solution, use of a tape measure and get creative in thoughts ,,,,,
    https://www.ebay.com/ulk/itm/282371317207
  7. Jan 14, 2018 at 9:05 AM
    trayday
    trayday New Member
    Oregon
    2015 limited CM 5.7
    What went wrong? The fabrication?
  8. Jan 14, 2018 at 9:22 AM
    Les7311
    Tube ends are differs and couldn’t tell difference between front or back
    Brackets are all labeled the same so can’t tell left fro right side
    Brackets can be installed forward mount, or rearward mount
    So I assumed the shorter from the bar tip to the first bolted hole to be the shorter end
    Used a jackstand to suspend bar as close to frame
    Starters with the front mount and went through a series of combination measurements.
  9. Jan 14, 2018 at 9:23 AM
    Les7311
    I blindly installed the mounts, the bar would not line up
    I cussed like a $1 broke pirate who just got robbed of 99 cents
  10. Jan 14, 2018 at 9:25 AM
    Les7311
    This was supposed to take less ham 30 minutes if labeled.
    eBay seller I believe don’t care. Happy with product and cost, just not the instructions
  11. Jul 3, 2019 at 5:42 PM
    bkmaine
    bkmaine New Member
    Are those eBay ones holding up? Do you have a pics? I’m thinking about going the cheaper eBay route now...
  12. Jul 3, 2019 at 6:47 PM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    I like the podiums. I have big feet and busted my arse a few times with the NFab hoops I had on my Jeep.
