n-Fab Bumper BS Thread
Discussion in 'General Tundra Discussion' started by boardude, Mar 2, 2018.
  1. Mar 27, 2018 at 6:42 PM
    #91
    Help New Member
    Ryan
    Tucson, AZ
    2014 Blue DC 5.7 FFV
    Bright pink truck nuts.
    I wrapped my factory ones in electrical tape and zip tied out of the way lol I figure since I've got relays on all the lines, i should be able to splice at least the fogs together and run them off the factory stalk w/o killing anything. The A pillars and bar obv need their own switch
    831Tun[QUOTED] likes this.
  2. Mar 27, 2018 at 6:45 PM
    #92
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Rigid has an adapter harness. Get in touch with them and ask if you get the parts
    831Tun likes this.
  3. Mar 28, 2018 at 9:45 AM
    #93
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    I see most do a 42" LED bar in the center of the bumper, then pod lights on the sides.
    I'd like to use the lexan bumper side pieces to fill in the corner bumper holes, but I still would like fogs.
    I see some have done a 20" LED bar in the center with 4 square LED pods.
    Has anyone done a 30" LED bar in the center combined in the same section with only 2 pods (used as fogs)?
    Thanks!
  4. Mar 28, 2018 at 10:57 AM
    #94
    Baja Designs
    Baja Designs The Scientist of Lighting Vendor
    Bill
    San Marcos, CA
    Our Squadron Series Lights will be a great alternative to the lights posted in this thread. They measure 3"x3" and do come in a few different performance options. Here is a quick comparison between the Squadron Sport and Squadron Pro:
    Squadron Sport - starting at $119.95
    https://www.bajadesigns.com/products/Squadron-Sport.asp
    20W/2260 Lumens
    Squadron Pro - starting at $219.95
    https://www.bajadesigns.com/products/Squadron-Pro.asp
    40W/4900 Lumens
    We do offer a 10% Forum Discount (code: BDForums) which includes $5 shipping to the Lower 48!
    Please let us know if you have any questions.
    -Bailey, Baja Designs
    www.bajadesigns.com
  5. Mar 28, 2018 at 11:07 AM
    #95
    Boosted4runner
    WA
    Thanks! And how much are the Baja to Toyota wiring adapters to retain factory power? Or do they come with the lights?
    Also - what is the beam pattern - Fog/Spot/Flood?
    Thanks!
  6. Mar 28, 2018 at 11:08 AM
    #96
    boardude
    boardude [OP] I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I taped into the fog wiring for the pods backlighting and then ran the main pod spotlight to a switch. I like the subtle backlighting with the main lights on. And then I can switch them on for additional light and for anytime fogs
  7. Mar 28, 2018 at 11:23 AM
    #97
    Baja Designs
    Bill
    San Marcos, CA
    They aren't included but we sell them for $14.95/set if you call 800-422-5292
    These lights come in a few different patterns for forward projection. We offer a Spot, Driving/Combo, and Wide Cornering pattern. The Spot is designed for long range distance. The Wide Cornering is designed for near field lighting. And the Driving/Combo is a nice all-in-one pattern for near field, midfield, and distance lighting.
    The best part is that these can easily be changed thanks to our uService technology. You can fine tune the light pattern to your specific needs.
    We offer replacement lenses on our site here for any looking to change a pattern or color :)
    https://www.bajadesigns.com/products/Replacement-Lenses.asp
    What is your primary use for these lights? Currently the Squadron Sport, Pair, Wide Cornering is very popular for fog lights! We have many customers running them in OEM and Aftermarket applications.
    www.bajadesigns.com
  8. Mar 28, 2018 at 11:25 AM
    #98
    Eclipsed & Floating
    Voluptuous Whitey
    @Boosted4runner
    Trust us all, you want to get the Baja Design lights and the fog pocket kits. Get the wide cornering
  9. Mar 28, 2018 at 11:46 AM
    #99
    Boosted4runner
    WA
    Thanks! Aren't the Fog Pockets for the factory bumper though? I'm currently searching for the best deal on the N-Fab MRDS front bumper. Trying to plan the 2018 Grill (have now), 2018 LED Headlights (will be here tomorrow), and front Bumper swap all at the same time.
    eta - I'd really like to use the plexi plastic pieces in the corners of the MRDS bumper, I don't want fogs in the corners. I'd like the look to resemble a plate-style bumper as much as possible. Thanks for the wide cornering info - those I think would make the most sense after installing the 2018 LED headlights.
    @Baja Designs - I would want the Baja Lights to act as Fogs would for beam pattern.
  10. Mar 28, 2018 at 11:51 AM
    #100
    Baja Designs
    Bill
    San Marcos, CA
    Then our Wide Cornering pattern would be perfect :thumbsup:
  11. Mar 28, 2018 at 12:37 PM
    #101
    Eclipsed & Floating
    Voluptuous Whitey
    DUHHHH!!!!!
    Don’t get the fog pockets...forgot the thread we were on :frusty:
    Still, get wide cornering and the same mounts @boardude and I have, totally adjustable
  12. Mar 28, 2018 at 1:11 PM
    #102
    pschiller86
    pschiller86 2017 SR5 CrewMax
    Paul
    Temecula, CA
    @Baja Designs Most common set up between fogs/ditch lights would be: Fogs= wide cornering Amber and Ditch= Driving/Combo or Spot in White?
    Eclipsed & Floating likes this.
  13. Mar 28, 2018 at 1:35 PM
    #103
    Baja Designs
    Bill
    San Marcos, CA
    For the Fogs the Amber Wide Cornering is certainly most common. For the Ditch lights it's 50/50 between Spot and Driving/Combo. A lot comes down to personal preference. Some customers do prefer a little more vision towards the sides with their ditch lights. Here is a quick comparison using the Squadron Pro:
    pschiller86[QUOTED] likes this.
  14. Mar 28, 2018 at 1:50 PM
    #104
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I'm pretty surprised with those mounts. Based on the looks I wasn't sure if they would hold the position of the pod as well as they do since they are multi-point adjustable. After dozens of wheeling adventures and Ricky Bobby'ing it in the desert they are still holding solid.
  15. Mar 28, 2018 at 2:48 PM
    #105
    Boosted4runner
    WA
    LOL!! :cheers:
    Thanks for the pics Bailey!! Do you have any of the "amber wide cornering"?
  16. Mar 28, 2018 at 3:14 PM
    #106
    Baja Designs
    Bill
    San Marcos, CA
    Stole these from @BlueBottle . He has 2018 LED Headlights and the Squadron Sport, Pair, Amber Wide Cornering.
  17. Mar 28, 2018 at 3:25 PM
    #107
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    Or you can get PROs and make night into day!
    This is in the same spot with the PROs
  18. Mar 28, 2018 at 3:50 PM
    #108
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Dayyuuuum!!
  19. Mar 28, 2018 at 3:55 PM
    #109
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Right! And this is just the Pros!
    blue16 likes this.
  20. Mar 28, 2018 at 4:31 PM
    #110
    Boosted4runner
    WA
    WOW!!!! That'll do it! :)
    Thank you all!!!
  21. Mar 28, 2018 at 4:34 PM
    #111
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    I want to replace my pillar pods with these.. So much to do with so little money..
    blue16 likes this.
  22. Mar 28, 2018 at 4:35 PM
    #112
    BlueBottle
    '16 Platinum 4x4
    See fine print
    Easy. Credit card!
    :spending:
    boardude[QUOTED][OP] likes this.
  23. Mar 28, 2018 at 4:44 PM
    #113
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    My card is :bananadead: from the 3.0s and the chase rack lol.
    Back to selling my body on CL
    blue16 and Eclipsed & Floating like this.
  24. Mar 28, 2018 at 5:11 PM
    #114
    Eclipsed & Floating
    Voluptuous Whitey
    I’ll give you tree doll hairs ant fiddy sense!!!
  25. Mar 28, 2018 at 5:13 PM
    #115
    Eclipsed & Floating
    Voluptuous Whitey
    Joon will need to show output pics of my lighting...............
    .:(:pout::sick::redxfall::violent:
  26. Mar 28, 2018 at 5:29 PM
    #116
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    That's way more than most my offers. Cheap bastards!
  27. Mar 28, 2018 at 5:30 PM
    #117
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    :sadviolin:
  28. Mar 28, 2018 at 6:17 PM
    #118
    Eclipsed & Floating
    Voluptuous Whitey
    :rofl::rofl::rofl:
  29. Mar 28, 2018 at 11:51 PM
    #119
    Boosted4runner
    WA
  30. Mar 29, 2018 at 4:49 AM
    #120
    boardude
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
