n-Fab Bumper BS Thread
Discussion in 'General Tundra Discussion' started by boardude, Mar 2, 2018.
  1. Dec 11, 2020 at 1:52 PM
    #421
    BayRunner
    2017 Tundra Platinum
    looks good, what brand of bed spray did you use?
    Rica25 likes this.
  2. Dec 11, 2020 at 1:53 PM
    #422
    BayRunner
    Wow, I didn’t think plasmodia had that long of a life.
    Rica25 likes this.
  3. Dec 11, 2020 at 1:58 PM
    #423
    sr5shark
    sr5shark Shop smart. Shop S-Mart.
    Alan
    Walnut Creek, CA
    2016 SR5
    Fox & ADS | SCS SR8 | Nitto RG
    I'm a little bummed about how well it has held up. :rofl:I only did plastidip as a way of testing to make sure that I liked the black over the silver. I want to do it right but the darn thing still looks as good as the day I painted it.
    When I do paint I will prime with etching primer and then may use a textured black to look closer to the powder coat on the bumper.
    Rica25 likes this.
  4. Dec 11, 2020 at 2:03 PM
    #424
    BayRunner
    Lol... I have used the Rustolium bed liner before and it is very textured. Kinda like sandpaper. Not bad looking but not sure of the longevity. I do have some concern that since the skid is already textured silver that the Rustolim may make it too textured. That’s why I was asking @Trdwillie14 what brand he used.
    Rica25 likes this.
  5. Dec 11, 2020 at 2:11 PM
    #425
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    No bed liner i used these for my sliders as well. 3 coats each I live on the coast my truck slowly gets eaten away by rust
    Rica25 likes this.
  6. Dec 11, 2020 at 2:49 PM
    #426
    BayRunner
    What color is the Dupli-Color? It's hard for me to tell.
    Rica25 likes this.
  7. Dec 11, 2020 at 3:51 PM
    #427
    Trdwillie14
    Billy
    2014 trd off road
  8. Dec 11, 2020 at 8:33 PM
    #428
    BayRunner
    Rica25 likes this.
  9. Dec 11, 2020 at 8:36 PM
    #429
    Trdwillie14
    Billy
    2014 trd off road
    No prob
    Semperfi5th and Rica25 like this.
  10. Dec 11, 2020 at 11:42 PM
    #430
    Semperfi5th
    Semperfi5th New Member
    Bamuffler Pro comp 7 inch lift 37x12.50r18 4.88 nitro gears Amp research steps King shocks all around Icon uca Nfab bumper Rigid pods Method nv305 18x9 wheels Prinsu roof rack Baja designs 40 inch light bar Coachbuilder steering Coachbuilder rear lift shackles Boss front bumper shims
  11. Dec 11, 2020 at 11:59 PM
    #431
    Semperfi5th
    Installed it last week..added the boss 1/2 inch shims..20201203_075912~2.jpg
  12. Dec 12, 2020 at 12:05 AM
    #432
    Semperfi5th
    Added the rough country 40 inch light bar
    V3N0M, Rica25 and Trdwillie14 like this.
  13. Dec 12, 2020 at 5:58 PM
    #433
    BayRunner
    Ok, so I installed the N-Fab bumper today. Not difficult, but I o have some observations and tips for others.
    • Potential Safety Issue: (not an n-fab issue, but install approach)Due to the difficulty reaching the nuts while installing the N-Fab skid plate, it was suggested to use rivnuts. Before even touching the truck, I spent considerable time trying to install rivnuts that would align with the holes in the skid. I could only get the 4 corners aligned and thought I'd have to dremel the 2 top center holes. However, before I did, I noticed that the rivnuts did not install correctly. When installing a rivnut, the crimp tool is supposed to compress the rivnut forming a washer type ridge on the opposite side of the material/hole. The n-fab skid mounting bracket is too thick for this ridge to form on the opposite side. The ridge was being created inside the bracket hole forming a friction hold. This seemed secure, but is highly dangerous. The skid could go flying at any time with any given jolt or bump. Granted this could have been the result of my particular rivnut tool, but in my case, I removed the rivnuts and stuck with the bolt through. Anyone using rivnuts, Please examine them and make sure the compressed ridge is on the opposite side of the bracket forming a solid and correct hold. If you do not see this ridge, replace the rivnut immediately with a bolt through.
    • Tip: Remove the old bumper from the top. I've had my bumper off before and removed the grill many times, so this was just a natural approach for me. Removing the grille allowed me to remove the bumper skin first and then the aluminum crash bar second. IMHO this makes it much easier and also allows me to store the stock bumper/skin easier.
    • Tip: Removing the grille gives you all the room in the world to install the n-fab skid plate. You can easily hold the rear nuts from the top. Again, all the room in the world making the skid install a non issue.
    • Tip: Use bumper shims. Using 1/2 inch shims pushes the bumper forward just enough so that it does not rub on the grille and also provides enough room to remove the grille in the future. I had Coachbuilder shims, but any 1/2 inch shim set will do. Also, if you have a RCI engine skid like I do, the bumper shims aligns up the n-fab skid and RCI skid perfectly. No overlapping necessary.
    Anyhow, I have not installed the parking sensors yet or wired the switches for the light bar. The H11 and Way 2 pin connectors cam in so I'll be able to make a an adapter harness to plug the BD fogs into the OEM fog wires. Not the best pics, but I'll provide better ones later in the daylight.
  14. Dec 21, 2020 at 8:53 AM
    #434
    BayRunner
    Finally got my switches installed. I used the Rough Country light bar with the DRL’s so I hooked them up to a separate switch that will automatically cut off when the headlights come on. Also took a different route then most routing the wires to the engine bay through the grommet in the driver floor board. Already had the AMP power step wires going through there so it was easy to use the same grommet.
    Clemshady and Rica25 like this.
  15. Dec 28, 2020 at 12:04 PM
    #435
    BayRunner
    Finally painted the n-fab skid black to match the bumper and RCI skid.
    Also, being in a state that requires a front license plate, Local LE suggested that I find a better way to mount the front plate instead of flush on the n-fab skid. While technically not against the code, I was told that a LEO having a bad day or one right out of the academy may give me a hard time about it. Just was not worth the potential hassle so I fabricated a matching bracket to display the plate vertical to the bumper.
  16. Dec 30, 2020 at 7:40 PM
    #436
    Clemshady
    Clemshady Bama Storm Trooper
    Jeff
    2017 Super White Limited DC TRD 4x4 Offroad
    \ Factory OEM LED Tundra Pro headlight upgrade Diode Dynamic amber Pro fogs 3" DD amber Pro ditch lights SDHQ ditch brackets 42" DD light bar SwitchPro 9100 Pedal Commander Vinyl wrapped bumpers Painted calipers Painted horns Chrome delete complete ARE CX Evolve Topper TRD rear swaybar Matching door handles and mirror caps Oh shit handle upgrade Matching grille surround/hood bulge TRD PRO insert grille BBS Forged TRD PRO wheels Coachbuilder +3 shackles Eibach Pro 2.0 Coilovers and rear shocks
    Looking good there Van. I wouldn't pull you over for a license plate violation, just sayin. Thanks again for your suggestions and answering my questions a few weeks ago. I am gonna join the N-Fab club tomorrow. Tired of waiting on my lights and Switch Pro. Will pull back off to install them later.
  17. Dec 31, 2020 at 8:03 AM
    #437
    BayRunner
    Thanks Jeff. The license plate thing just was not worth the potential hassle. I have a good relationship with the local agencies and sometimes the young recruits get a little over enthusiastic in their job. Plus the EZPass cameras can’t pick up the plate when it’s flush on the n-dan skid.
    Glad your getting yours. I take it the guy finally responded back to you or did you go through a dealer? Post pics when mounted.
    Rica25 likes this.
  18. Dec 31, 2020 at 10:22 AM
    #438
    Clemshady
    Jeff
    Yes he did, made a 5+ hour one way drive to Johnson City TN and got it for $750. Already powder coated and came with light bar. All about saving money if I can. Great suggestion you had on bumper shims, definitely leaves enough room to remove grill insert and it doesn't rub. What do you think?
    20201231_112911.jpg 20201231_114306.jpg 20201231_121051.jpg 20201231_121231.jpg
    silverstreak16 likes this.
  19. Dec 31, 2020 at 10:41 AM
    #439
    BayRunner
    Looks good. I like the matching color powder coat. That light bar fits perfectly in the center opening. What light is that? Also, you going to put pods in the end cap opening, leave it open or get the covers?
    Rica25 likes this.
  20. Dec 31, 2020 at 11:07 AM
    #440
    Clemshady
    Jeff
    Thanks man! Yeah, the lightbar was a perfect fit, it is the Rough Country either 40" or 42", can't remember. Got two pairs of pods on order to fill in openings. I pulled off covers and they were filthy. Thought about trimming them to fill outside edge but not sure yet.
  21. Dec 31, 2020 at 11:43 AM
    #441
    BayRunner
    Sounds good. Yea, the Rough Country light bar is a solid choice. Mine is RC as well but is the model that include the DRL strip.
    Also, you may need these generic bracket mounts for your pods. I just had a box of these that I did not need, but just sent them back.
    https://www.amazon.com/gp/product/B07QGDXK4J/ref=ppx_yo_dt_b_asin_title_o07_s03?ie=UTF8&psc=1
    Rica25 likes this.
  22. Dec 31, 2020 at 12:08 PM
    #442
    Clemshady
    Jeff
    Yep, I am a step ahead of you, already got them. Now if only my pods would come in.
  23. Dec 31, 2020 at 2:54 PM
    #443
    BayRunner
    @Clemshady Now that's you've had the chance to sit back and observe it, what are your thoughs on the n-fab? Personanly I think it looks way better in person than any photo.
    Rica25 likes this.
  24. Dec 31, 2020 at 3:40 PM
    #444
    Clemshady
    Jeff
    @BayRunner, I have to agree with you. I am liking it a lot. Gives it a nice clean look and everything is easily accessible. The components on the factory bumper gave me a headache eveytime I had to work on something.
  25. Dec 31, 2020 at 7:27 PM
    #445
    BayRunner
    Yup, and now with all that front end clearance, you have ana excuse to put on 34" (295's) or 35" tires. :mudding:
    Clemshady[QUOTED] likes this.
  26. Jan 3, 2021 at 1:07 PM
    #446
    Clemshady
    Jeff
    Switch Pro 9100 installed. Now waiting for DD pods to get shipped. If anyone is on the fence on the N-FAB MRDS bumper, go ahead and make the swap. The factory bumper is loaded up with so much crap when you need to work on something. It takes an engineering degree to put it back together. With the N-FAB the clearance, access, and tire size options make it worth it.
  27. Jan 3, 2021 at 1:34 PM
    #447
    jefroshm0
    jefroshm0 New Member
    Elk Grove, CA
    2018 Cement Tundra Crew 4x4 SR5
    Fab MRDS with Boss bumper shims. Fit a 42inch light bar in but had to make my own brackets to get it to work. Converted factory fog light harness to Dt connectors for the DD pods.
    Powder coated the skid plate and installed rivnuts to the frame so it can be taken off easily in the future.
    installed parking sensors back on the bumper.
    silverstreak16, Clemshady and Elduder like this.
  28. Jan 3, 2021 at 2:24 PM
    #448
    Elduder
    Elduder New Member
    Adding shims to push it away from the lower grill piece?
  29. Jan 3, 2021 at 2:24 PM
    #449
    jefroshm0
    Elk Grove, CA
    Yes
    Elduder[QUOTED] likes this.
  30. Jan 4, 2021 at 7:20 AM
    #450
    BayRunner
    Nice clean install of the Switch Pro. Where did you mount the control unit?
