n-Fab Bumper BS Thread
Discussion in 'General Tundra Discussion' started by boardude, Mar 2, 2018.
  1. Apr 2, 2020 at 5:12 PM
    #301
    2Tall
    2Tall New Member
    Chance
    South MS
    2020 Super White CM SR5 4x4
    Man that pic is making me want this bumper more and more!
    BravoDeltaRomeo and Rica25 like this.
  2. Apr 2, 2020 at 5:20 PM
    #302
    Trdwillie14
    Trdwillie14 New Member
    Billy
    2014 trd off road
    2.5 fox 2.5 ads triple bypass T/C uppers Nfab front bumper Westin rear Bajas Rci skids All pro sliders Icon rxt leafs Stt pros Method 701s 37 Mickey Thompson
    Don’t do it. Get off this forum it’s a money pit. I’ve gotta a ton used and it’s a killer
    V3N0M and Rica25 like this.
  3. Apr 2, 2020 at 5:23 PM
    #303
    Rica25
    Ricardo
    Tulare
    I had dame issue but with only two bolts they would not line up but mine was more of the whole bracket having to slightly be tweaked
    Swatdude1 likes this.
  4. Apr 2, 2020 at 5:27 PM
    #304
    2Tall
    2Tall New Member
    Chance
    South MS
    Thanks for the warning but it's too late for me. Mod bug got me long before this truck or this forum. Y'all are just enabling me at this point haha
  5. Apr 2, 2020 at 5:32 PM
    #305
    Trdwillie14
    Billy
    2014 trd off road
    @Swatdude1 u May want to ask @831Tun he knows all when it comes to tundra plus this was his bumper
    Rica25 and Swatdude1 like this.
  6. Apr 2, 2020 at 8:05 PM
    #306
    Swatdude1
    Swatdude1 New Member
    Phoenix, AZ
    2008 Tundra Crewmax Limited TRD
    Icon 3.0 Coilover Stage 2, SDHQ Traction Bars, Nitro 4.88 gears, AlphaRex Headlights, Katskin Leather, Method 17" Vex with 35"Toyo M/Ts, Eaton Rear Locker, N-Fab MRDS
    Does the bumper ever knock the plastic out of whack when you are bombing off road? I had the limited full resin bumper but bought the SR-5 top cap and metal support to go with my MRDS. I am guessing a hard landing might push the metal retainer/cover up? Or you haven't had any problems with that?
    Rica25 likes this.
  7. Apr 2, 2020 at 8:07 PM
    #307
    Trdwillie14
    Billy
    2014 trd off road
    Not really to be honest with u. However as soon as my wife lets me leave the house other then work @dcsleeper408 is putting on my rear leafs and triple bypass so those trial speeds are sure gonna be ramping up.
  8. Apr 4, 2020 at 11:21 AM
    #308
    Trdwillie14
    Billy
    2014 trd off road
    This is a front shot if it helps any
  9. May 2, 2020 at 6:44 PM
    #309
    Swatdude1
    Phoenix, AZ
    I have to say this MRDS Bumper has been a total fiasco. I posted previously the bolt holes weren't wide enough. So I measured and measured and then grinded the slots wider on each side. Turns out the slots were off center so I had to grind the right side even wider. Wound up with some very large hardened mil-spec washers to hold the bumper on. FYI, Toyota Torque spec is 43 ft-lbs. I went to 47 since I had the large washers.
    So earlier today I got to installing the light bar. had purchased the same ones from Amazon as AWS278. They were too short and too tall, so I measured and started drilling a holed in the tall bracket at the correct spacing. WTFrick!! These are like case hardened steel. I have drilled 1/4" 304 stainless with the same bits with coolant and they are barely putting a dent in these brackets!!!
  10. May 2, 2020 at 6:58 PM
    #310
    Trdwillie14
    Billy
    2014 trd off road
    I hope your doing all this with booze to ease the pain
    Rica25 likes this.
  11. May 2, 2020 at 7:05 PM
    #311
    Swatdude1
    Phoenix, AZ
    Not yet. But it's driving me to drinking.
    Did I mention my bumper doesn't have the "window" between the steel supports like I see in the pictures of the Gen 3's on this thread? So even if I get the bracket drilled, it's going to be tough to get it screwed together.
    Also, there is a thick weld on the right side that is preventing the mesh screens from fitting into place. Crappy QC for a USA made product!!!
    Rica25 likes this.
  12. May 2, 2020 at 7:14 PM
    #312
    Trdwillie14
    Billy
    2014 trd off road
    I would contact them see what they say his took me maybe 1 hour to put on man
  13. May 2, 2020 at 7:31 PM
    #313
    Swatdude1
    Phoenix, AZ
    Too late. I made a rookie mistake and didn't test fit it before powder coating. I was being lazy and didn't want to take the impact bar off and put it back on. It's on now and ain't going anywhere. Just have to figure this light thing out.
  14. May 2, 2020 at 7:35 PM
    #314
    Trdwillie14
    Billy
    2014 trd off road
    Got any pics of the issue
  15. May 2, 2020 at 7:45 PM
    #315
    Swatdude1
    Phoenix, AZ
    I'm pretty frustrated. The only issue is with the Rough Country light bar. There is no room for the factory mounts and the after market ones I bought are like case hardened steel apparently. I'm using good Viking bits with cutting oil and it is barely putting a dent in them. Going to wait to hear back from ASW278 on if he had luck drilling them and I just got a bad set.
  16. May 2, 2020 at 8:00 PM
    #316
    Trdwillie14
    Billy
    2014 trd off road
    Gotcha yah I had to use aftermarket bracket but that sounds like a bitch sorry man
  17. May 2, 2020 at 8:24 PM
    #317
    toyota tom
    toyota tom New Member
    Jacksonville, FL
    2019 SR5 4x4 CM
    ESP underseat storage Shorter 6” antenna Bilstein 6112 @ 2.5, 6150, +2 CB shackle 275/60/20 ridge grapplers
    Looks badass! What size tire are you running?
    Rica25 likes this.
  18. May 2, 2020 at 8:29 PM
    #318
    Swatdude1
    Phoenix, AZ
    I just ordered the Rigid 40182. Can you please tell me what bracket you used?
    Rica25 likes this.
  19. May 2, 2020 at 8:31 PM
    #319
    Trdwillie14
    Billy
    2014 trd off road
    315/70r17
    Just a 34.6
    Rica25 likes this.
  20. May 2, 2020 at 8:38 PM
    #320
    Trdwillie14
    Billy
    2014 trd off road
    Can’t recall where I got them but that is them if you look close. It’s a 40inch
    Swatdude1[QUOTED] and Rica25 like this.
  21. May 2, 2020 at 8:42 PM
    #321
    toyota tom
    Jacksonville, FL
    2019 SR5 4x4 CM
    I love how you can see more of the tread from the front. Seriously looks good!
    I am running 275/60/20 now so was comparing.
    Mine if I ask you did you have to do any other trimming or a BMC?
    Rica25 likes this.
  22. May 2, 2020 at 8:46 PM
    #322
    Trdwillie14
    Billy
    2014 trd off road
    Yah so I have a 1.25 spacer and the rim is a zero off set so that helps the caster is moved out to move the wheel forward and I have a bmc and am planning a pinch as well when I go to 37s. Thanks man it’s been a process that’s for sure but love this stuff @toyota tom
    831Tun and toyota tom like this.
  23. May 2, 2020 at 9:30 PM
    #323
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    When you go to 37s???? What??:welder:
    Trdwillie14[QUOTED] and Rica25 like this.
  24. May 2, 2020 at 9:38 PM
    #324
    Trdwillie14
    Billy
    2014 trd off road
    :anonymous:A wise man named warren said “ You are never done” soooooo when these tires wear out lol. Plus when i see your rig tomorrow I’m sure it’s gonna make me go broke all over again lol
    831Tun and Rica25 like this.
  25. May 2, 2020 at 9:42 PM
    #325
    Rica25
    Ricardo
    Tulare
    Where is the meet tomorrow....not invited
  26. May 2, 2020 at 9:51 PM
    #326
    Trdwillie14
    Billy
    2014 trd off road
    Only if you wanna pay for the parts I’m buying lol :spending:
    Rica25[QUOTED] likes this.
  27. May 2, 2020 at 10:00 PM
    #327
    Rica25
    Ricardo
    Tulare
    If you buy for my FJ
  28. May 2, 2020 at 10:02 PM
    #328
    Trdwillie14
    Billy
    2014 trd off road
    Only a tundra and gun guy sorry :rofl::rofl:
    831Tun and Rica25[QUOTED] like this.
  29. May 2, 2020 at 10:20 PM
    #329
    Rica25
    Ricardo
    Tulare
    I've got my Tundra also
    Trdwillie14[QUOTED] and 831Tun like this.
  30. May 11, 2020 at 6:44 PM
    #330
    Swatdude1
    Phoenix, AZ
    I'm super frustrated with N-Fab right now. The skid plate has the holes off from a quarter to a half inch in places from one side to the other and it doesn't line up with the bumper.
    As far as my light bar, I bought the Rigid mounts, drilled them, and Cerakoted the raw metal black. They still won't fit. There is no way to screw the hardware with the light bar inside the light area since the 2nd gen bumper doesn't have the "window" at the ends. I'm not about to start cutting holes in it there. I just broke down and ordered the Baja Designs OnX6+ 30-inch LED bar and two Squadron Fog lights with wire harness adapter for Tundra fogs to the tune of $1500... GRRRRRR. Wife is not going to be happy.
    Selling Rough Country for $225 Shipped with stock brackets, Amazon Brackets and Drilled/Coated Rigid brackets. Any takers?
    831Tun likes this.
