My Tundra mods for stable towing
Discussion in 'Towing & Hauling' started by BrakeDust, Feb 26, 2021.
  1. Mar 19, 2021 at 2:50 PM
    Professional Hand Model
    Hand Protectors
    Nice feedback. Which color Sumos did you use? What do you not like about them vs stock? I see you cut them down which sounds like a good idea so you aren’t riding them constantly, but looking for more specific feedback. Thank you.
  2. Mar 22, 2021 at 5:40 AM
    BrakeDust
    BrakeDust [OP] New Member
    Hill Country, TX
    2021 CM SR5 4x4 Magnetic
    Had a long shakedown trip last weekend, about 400 miles round trip between Austin and Dallas. Notes below.
    ATX to Dallas
    - Moderate traffic, driving after dark
    - Fairly strong tail wind (~15 MPH)
    - Incredibly smooth drive, I could easily take my hands off the wheel when going 70MPH and have a big rig pass me, not even feel it
    - Stayed behind other large vehicles most of the way, probably got 12MPG on the way up
    - Handled some fast ramps well, notably the I35 split as it forks to Ft Worth and Dallas. Google maps told me about the turn rather late and I had to speed up to about 80MPH to get in there, then brake moderately hard as I hit the ramp (it's surprisingly tight in the Ft Worth direction.) No understeer or oversteer.
    - Truck stayed between 1800-2000RPM most of the time, even at 70MPH
    Dallas to ATX
    - Tons of traffic due to ending of spring break
    - Fairly strong wind either directly from the side or about 45 degrees at the front (15-20 MPH)
    - Meager 8MPG gas mileage, wind like that makes a massive difference in mileage and handling
    - RPM anywhere from 1800-3000
    - Decided to cap out at 65MPH due to the wind. No sway, but could feel the buffeting.
    - Noticed some other campers, eg. a large Forest River behind a chevy 2500. He wasn't going any faster than me.
    At our KOA my neighbor had a 2WD Tundra double cab with regular bed, so ostensibly the same length as my 4x4 CM. He was towing a 30ft trailer, 33' from ball to bumper. Didn't ask how it towed, but because those campers sit above the wheels without any wheel wells, he had a riser on his truck hitch to meet the trailer coupler. Can't imagine it being a very good combo.
    Came to realize that road conditions vary in the USA. The Autobahn in Germany is over very high quality and is consistent. Here our roads can indeed be just as good but usually this is a short stretch. You'll find cracks and potholes, but on freeways the worst part is 'swells.' The surface simply isn't level. Sometimes those swells/dips are intermittent and your rig merely has to absorb it at high speed. Other times those swells are more regular and lead to a harmonic effect on your drive. Usually one must slow down since speeding up is seldom and option. It doesn't affect individual vehicles very much but for a 50ft trailer combination they are apparent.
    Important Note: Turns out I had a flat tire at some point during/after my trip to the CAT scales! I have no idea if I got it at the start of the day or the end, but discovered it later. The truck drove like crap on my way to the scales, that's all I know. Now I do a quick walk around every time I take a break just to make sure all the lugs are in place, tires look good, no wheels are hot, my WDH is all set - can't take anything for granted.
    I have the Blue sumos. I started with the Black but didn't install, they are rock hard. And yes I did cut the top donut since I didn't want constant contact between axle & frame. To me they seemed to provide too much connection, I prefer to rely upon my WDH setup to 'level' the truck & trailer. As I have it now, the sumos function as a progressive version of the bump stops rather than a helper spring.
    ColoradoTJ and JohnLakeman like this.
  3. Mar 24, 2021 at 9:12 AM
    Sacul
    Sacul New Member
    2024 Tundra Limited TRD
    Nothing yet
    Did you have any issues with fitment on the sway bar? Sparks Parts list the genuine Toyota hitch as a possible conflict.
  4. Mar 24, 2021 at 12:46 PM
    BrakeDust
    Hill Country, TX
    No issues at all. No idea why they'd say that, they even include an extra set of washers for those who _don't_ have the factory hitch. If you have a hitch, you leave those washers out.
    Sacul[QUOTED] likes this.
  5. Mar 24, 2021 at 3:17 PM
    Sacul
    Sacul New Member
    Nothing yet
    Great! Thanks
  6. Mar 29, 2021 at 11:42 PM
    Have you ever thought about how much money you're spending to make a vehicle that tows well within the boundaries it was designed...to tow a little better outside of the boundaries of design? I was all in with my 2012 CM Tundra. SC, VB for trans, suspension, bags, etc.
    When I started doing the math, I stopped and made some decisions, started saving for a bigger truck. After I was all said and done, these upgrades that did nothing for payload and GCWR except drain my wallet. When all said and done, it was going to be around 10K for my build, and this didn't even include a big brake kit to assist in stopping. The Tundra brakes are very good in my opinion...and I mean boy band girl hookup good....for a 1/2 ton truck. I went diesel and a nicely equipped one, but most do not need a diesel or want the extra attention they require. I never recommend them to daily drive, and rarely do most need one for weekend warrior stuff.
    Over the years, I have seen plenty of members move up in truck size to accommodate life changes. Most of them are still very active on the forum (and many don't even know they sold the tundra...and I will not out them). Just food for thought. You obviously care about weight ratings, have the perfect 5th wheel setup to reduce pin weight, and from the looks of the truck...it needs nothing in the service/maintenance department (a complement to you sir).
    Food for thought....
    BroTun13 and Cpl_Punishment like this.
  7. Mar 30, 2021 at 5:51 AM
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Great write-up showing depth of prep @BrakeDust!
  8. Apr 6, 2021 at 9:34 PM
    onesojourner
    onesojourner Here, let me derail that for you
    SW MO
    06 DBLcab LTD 4x4
    Can we see some pictures of this setup? How long to you plan to keep this setup?
  9. Jun 11, 2021 at 2:10 PM
    2mchfun
    So, you mentioned ditching the Sumo springs, suppose you do or did. If you keep or kept the cb shackles and the springs flex due to terrain or load and hit factory bump stop would that not be compromising the spring because at that point it would be forced down by the long shackle beyond factory design limits? I mean this is why I think you better keep the taller Sumo springs and not bend over your leaf packs.
  10. Jun 12, 2021 at 5:21 AM
    BrakeDust
    Hill Country, TX
    I didn't ditch them, I just cut off the top donut. IMO they're a little 'tall' straight from the factory. After initial install they appeared to allow some space between the bumper and frame but after a week of driving my mods settled a little (bilsteins, shackles.) There was now only a quarter inch gap even when unloaded and with a load the sumos were already compressed. After deleting the top ring I now have about an inch of clearance when unloaded and a quarter inch when loaded. This allows some articulation and the sumos are progressive when being worked. The stock bumpers are pretty short, quite a bit less than even the 'reduced' sumo. I've towed multiple times with the setup and haven't seen my leafs turning into a 'W', pretty sure it's ok.
    But if I were to do it all over again I could stick with just the OEM tundra stops. The WDH already balances the load, anyone with the factory Bilsteins could pretty much run their truck bone stock. (ie. TRD off road for example.)
    shoe07 likes this.
  11. Jun 12, 2021 at 7:41 AM
    2mchfun
    I understand that you kept them but I think you might be misleading others by implying that they could just use the shackles. I believe if the Sumo springs were not in place the shackles would force the springs down further than the factory design allows for which would then be possibly compromising to the springs. Maybe I'm wrong but I don't think so.
  12. Jun 12, 2021 at 1:01 PM
    shoe07
    shoe07 New Member
    Ohio
    2004 Tundra Double-cab SR5 Tow pkg
    I imagine Toyota knew what they were doing when designing the oem suspension. Sumo springs help prevent squat and can help give extra support in turns when the truck leans.
    I do not have a anti roll bar on my rear axle.
    I also cut my top donut as I didn’t want to hit the spring under normal driving. When loaded for a trip with the wdh setup properly I am just off of mine now.
    before it would be almost touching when unladen.
  13. Jun 12, 2021 at 3:32 PM
    BrakeDust
    Hill Country, TX
    I got the smallest CB shackles on purpose. The Bilsteins I put on are set to the lowest perch and still give about a half inch lift. Similarly the short CB shackles should only 'lift' the rear by a half inch. I measured the rake before and after, this was indeed the case both front and back. A half inch is nothing, the width of my pinkie. I don't think it's an issue. I wanted to preserve the factory rake while running better shocks.
  14. Jun 12, 2021 at 3:38 PM
    2mchfun
    Are you going to remove your Sumo springs and go back to factory bump stops?
  15. Jun 12, 2021 at 3:45 PM
    BrakeDust
    Hill Country, TX
    No, they've been in a landfill for months! :rolleyes: And even if I had them it's not worth the trouble. I'd have to get fresh U-bolts for the install since I already reused the OEM bolts for the sumos - supposedly they stretch and many recommend brand new bolts for each install.
    FWIW I did order the 'black' Sumos at first - they felt so hard I returned them without installing. Rated for 1500 lbs in the bed, they were as firm as the OEM stops and didn't compress at all. At least the blue type has a little give.
    I ran my 2008 Tundra for years with the factory stops and was perfectly happy. Did have Bilsteins and the short CB shackles, those were the only mods.
    Anyway I'm happy with the blue sumos at my "-1" setting, no complaints. The rear sway bar makes the biggest difference that I can actually feel, and the E-rated tires.
    2mchfun[QUOTED] likes this.
  16. Jun 12, 2021 at 4:02 PM
    3rdTundra
    3rdTundra Hay Hauler
    Central Texas
    2017 Tundra SR5 Double Cab TSS 4x4
    FRAC harness / camera & Full set of Valhalla plates
    @BrakeDust
    Curious, did you consider the Roadmaster active suspension setup rather than the CB shackles and sumo bump stops? I have read that the Roadmaster kit increases the unloaded rear height a bit and provides better towing support like the shackle/sumo combo. Just curious if you researched Roadmaster when preparing for your build and, if so, why you chose this route.
    sportbikenut and 2mchfun like this.
  17. Jun 13, 2021 at 4:41 AM
    BrakeDust
    Hill Country, TX
    I did not research them, but I've since seen good reports on this forum.
  18. Jul 6, 2021 at 5:37 AM
    BrakeDust
    Hill Country, TX
    More pics from central Texas
    Spartanfam and BobsYourUncle like this.
  19. Oct 17, 2021 at 7:51 AM
    #49
    slowpokepete
    slowpokepete New No More
    Peter
    Hillsdale, NY
    2007 Blue Tundra DC 4x4 SR5
    Getting a 2020 Globetrotter 25' in a few weeks from Colonial in NJ.
    SPP
  20. Oct 17, 2021 at 8:33 AM
    #50
    sportbikenut
    sportbikenut New Member
    Chuck
    Pittsburgh Region, PA
    2021 Tundra Limited DC MGM 4x4 (New Oct 2021)
    Traded in 2016 Tundra Limited DC Silver 4x4
    I second that suggestion. Ditch the Sumo's and install RAS HD. They work very well and also act similar to the TRD anti sway bar. Feels very solid and sporty when not towing and still a comfortable ride. I had them on my 2016 and putting on my 2021.
    ATHiker likes this.
  21. Dec 13, 2021 at 8:55 PM
    #51
    ProTex1
    ProTex1 New Member
    Longview, Texas
    2021 Tundra TRD Sport
    18x9 Method Roost Wheels, Nitto TG G2 285/60R18, AREz Topper, Gator Mud Mats, Bilstein 5100 & Eibach Springs front, Bilstein 5160 rear, Good-Year Vent Visors.
