My tundra is a little loose
Discussion in '1st Gen Tundras (2000-2006)' started by Jake92, Feb 5, 2023.
  1. Feb 5, 2023 at 8:24 PM
    Jake92
    Jake92 [OP] New Member
    2000 Toyota Tundra SR5 4x4 TRD
    So my truck has a lot of hard hard non maintenance miles from the previous owner. I Can feel she like to sway and is a little loose at higher speeds above 55mph I have new tie rod ends, sway bar bushings that I anm gonna install and rack and pinion bushings. Besides an alignment what else should I look at maybe new leaf springs too? Since she bottoms out with only a little weight in the back? because I’d like to tighten her up and make her ride almost like new. She does have new front struts and rear shock absorbers along with newer lower ball joints . Her Milesis at 355,xxx hard miles.
  2. Feb 5, 2023 at 11:51 PM
    NickB_01TRD
    Nick
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    If you can't verify for certain they are OEM you should strongly consider doing them again.
    Your allignment could be part of your issue especially if your numbers are way off.
    bmf4069 and Jake92[QUOTED][OP] like this.
  3. Feb 6, 2023 at 12:30 AM
    blenton
    blenton New Member
    New Shock absorbers.
    OE are ok; lots of aftermarket choices to improve on the OE ride. I purchased one of my vehicles with around 80k on the clock and it swayed and floated a little on the test drive. Felt loose. I knew it needed new shocks and didn’t bother trying to get the dealership to fix it; they had just inspected everything and it “passed with flying colors”.
    Got it home, put it up on Jack stands and sure enough both rear shocks are done - one so bad that it moves 2 or 3 inches with zero resistance before making a half hearted effort to resist more movement. It was caked in shock oil and road grime. I put OE shocks in the rear and the inexpensive Eibach’s up front and the sway/wiggle/looseness almost completely disappeared.
    I could tell the alignment was out a tick, too, so I had it aligned and it’s darn near perfect.
    NickB_01TRD likes this.
  4. Feb 6, 2023 at 8:06 AM
    shifty` All my rowdy friends have settled down
    This!! ^^
    For lower balljoints specifically, only OEM is OK. You don't want to be part of the thousands-long list of guys posted here or on Facebook with their front wheel snapped off. Aftermarket DOES NOT make LBJs that are stout enough to handle the high stress. Not even Moog, and I was a Moog fanboi up until their quality went to shit 10-15 years ago, as they began outsourcing to others.
    YES, this LBJ thing sounds like BS if you don't know better. NO, it's not exaggeration. There's a reason people make stickers like this. It's not a joke, it's not a fad, it's the truth. If you made the mistake of not using OEM LBJs, with fresh bolts, it's in your best interest to pull whatever you installed and replace with OEM. The risk of failure is too high with aftermarket.
    That said, take 10 minutes to read this thread. It'll talk about alignment numbers, suspension and whatnot. If you want to stick with stock ride heigh, Bilstein 4600 front and rear will get you back near an OEM ride. Drifting on road can be alignment issue, but check your rack bushings ... hell, check all rubber bushings on the truck from the steering rack out to the lower shock mounts, upper and lower control arms, etc. Wiggle things around and look for play. Likewise, check the steering shaft for play.
  5. Feb 6, 2023 at 10:49 AM
    chunk
    chunk New Member
    110 miles north of Los Angeles, Ca.
    2001 SR5 Tundra, 2WD
    Bone stock, original owner
    [QUOTE="Jake92, post: 3076356[/QUOTE]
    I knew a girl like that once;).
    bmf4069, Jack McCarthy and shifty` like this.
  6. Feb 6, 2023 at 11:02 AM
    Ob1
    Ob1 New Member
    Is it leveled or lifted?
  7. Feb 6, 2023 at 11:09 AM
    Kung
    KG, VA
    There's a "your mom" joke in here somewhere.
    bmf4069 likes this.
  8. Feb 6, 2023 at 11:23 AM
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
  9. Feb 6, 2023 at 6:12 PM
    Jake92
    Thank you thank you thank you. I will be putting oem lbj on her soon because there are moog on the lower and upper . I’ll also be wiggling her around to see whatever else is loose on her. Thank you again
  10. Feb 6, 2023 at 6:13 PM
  11. Feb 6, 2023 at 6:16 PM
    Jake92
    It has Bilstein 5100s on all four corners and eibach lift springs in front.
  12. Feb 6, 2023 at 6:39 PM
    Jake92
    this was such a great read
    FrenchToasty likes this.
  13. Feb 6, 2023 at 6:52 PM
    Hi06silver
    Hi06silver Fat. Thumbs.
    Ryan
    2006 DC 4x4 Waltrip
    5 inch TC Lift. Icon 2.5 Ext. travel coilovers- Icon Resi- shocks w/Firestrone air-ride 285/75/17 Toyo OC Ext. FN Overlander wheels Retrofit Projectors Kenwood H/U Natika Back-up camera
    shifty`[QUOTED] likes this.
  14. Feb 6, 2023 at 7:17 PM
    NickB_01TRD
    Nick
    KY
    It's a little long winded. I apologize lol
  15. Feb 6, 2023 at 7:36 PM
    Ob1
    Ob1 New Member
    The steering on mine felt darty and hard to keep centered, although I had no pull left nor right. This happened after I leveled it with 5100's at top setting. Someone suggested JBA upper control arm and he was spot on. Once installed, I had the left caster dialed to 2.9 and the right to 3.4 degrees. The difference was like day and night.
  16. Feb 6, 2023 at 7:47 PM
    Hi06silver
    Ryan
    2006 DC 4x4 Waltrip
    Wasn't your info that was all good info. Just the variances in different years torques etc. That could make it some what confusing. All the questions are there now to make it less fortunately.
    NickB_01TRD[QUOTED] likes this.
  17. Feb 7, 2023 at 4:21 AM
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    bmf4069 likes this.
  18. Feb 7, 2023 at 11:53 AM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
    Regular show was awesome. But yeah, they were high as eagle tits.
