My truck caught corona virus!!
Discussion in '2nd Gen Tundras (2007-2013)' started by 89Trisha, Mar 16, 2020.
  1. Mar 16, 2020 at 3:49 PM
    89Trisha
    89Trisha [OP] New Member
    Trisha
    2010 SR5 Crewmax Tundra
    Hey y’all! Truck (2010) wont start and makes a grinding type noise before giving up. I tried a scanner to see what it could be and this is all that came up on the screen-No dtc or freeze frame data. What does this mean?
    Toyokuhl and Rica25 like this.
  2. Mar 16, 2020 at 3:54 PM
    ezdog
    ezdog New Member
    Gateway To The West
    Oh Man!
    I hope its not too close to other vehicles?
    How Old is it?
    Any other Symptoms,might just be bad Gas?
    Mine are not showing symptoms at all but I am pretty sure the new one is a carrier!
    Mountun Goat likes this.
  3. Mar 16, 2020 at 3:57 PM
    Seaflea
    Seaflea New Member
    William
    Sounds like you're starter is going out. Or already out. It could also possibly voltage to the starter (ie. battery) What year do you have and how old is the battery?
  4. Mar 16, 2020 at 4:10 PM
    89Trisha
    Trisha
    Its a 2010.Lol. I do have gas in it. I do need an oil change but that can’t be it. I cant see the year on the battery. I’ll probably bring it down to Auto Zone so they can check how much life it’s got left in it.
    Seaflea likes this.
  5. Mar 16, 2020 at 4:26 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    #1. Make sure your battery is fully charged and not sulfated.
    #2. Check battery connections - clean and tight.
    #3. Crank motor. If it grinds: starter drive gear/bendix is bad.
    If you replace the starter, and it still grinds, it’s a worn ring gear on the flywheel. Big job to R&R the ring gear - transmission has to come out.
  6. Mar 16, 2020 at 4:56 PM
    blackdemon_tt
    blackdemon_tt Battery Slayer
    How many miles??
  7. Mar 16, 2020 at 4:57 PM
    89Trisha
    Trisha
    121,410
  8. Mar 16, 2020 at 5:16 PM
    blackdemon_tt
    nuclearlemon likes this.
