My toyota anti toyotaing
Discussion in 'General Tundra Discussion' started by Acidriver267, Jan 28, 2025.
  1. Jan 28, 2025 at 8:00 AM
    Acidriver267
    Acidriver267 [OP] New Member
    Austin
    Ontario
    2007 tundra 4.7 v8
    Airbag suspension Ram bar Lift kit
    So i posted an update about my ome timming belt being changed 18 years later and 360000km on it. I got it changed and 3 days later I turn off my truck turn in on it starts stalling then turns off. The check engine light is on and the oil temp light is on.
    Check under the hood still has oil. Also got an oil change done with it.
    I've been told that it the belt might have slipped. But I wanna hear from you guys. To see what you think it is. I'll post an update when it gets diagnosed
  2. Jan 28, 2025 at 8:07 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    I think it is codes that were not read.
  3. Jan 28, 2025 at 8:43 AM
    Acidriver267
    Austin
    Ontario
    2007 tundra 4.7 v8
    I haven't read the codes yet. And it's sitting at the shop right now. As their lead tech is on vacation. How ever the codes did not pop up till 3 days after the timming belt was replaced. The engine sounds fine the tranny isn't slipping. No knocking. So it could be a sensor or something else.
  4. Jan 28, 2025 at 8:55 AM
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    If the crankshaft or camshaft position sensors are not routed correctly, the serpentine belt can rub on them and damage the wires, causing electrical gremlins. This is a pretty common occurrence after the 4.7 timing belt job. If it is damaged enough, it will shut off the fuel pump as a safety precaution. I'd pull the codes and check here first, if everything looks okay, then I'd double check the timing.
    https://www.tundras.com/threads/the...chronological-story.46816/page-7#post-1885894
    https://www.tundras.com/threads/res...g-belt-replacement.146319/page-3#post-3674850
  5. Jan 28, 2025 at 9:00 AM
    Acidriver267
    Austin
    Ontario
    2007 tundra 4.7 v8
    Ok sweet ill bring it up to them when the time comes. But that helps alot. Thank you
    2mchfun and des2mtn like this.
  6. Feb 5, 2025 at 3:57 PM
    Acidriver267
    Austin
    Ontario
    2007 tundra 4.7 v8
    Update so left it at the shop for over a week
    They got back to me yesterday. And apparently my Toyota has build in kill switch idk how.
    But supposedly my key has a chip inside of it and the chip is worn out so when I get into my truck. My truck won't start unless my truck and verified the chip connected to my key.
    So i guess if someone tried to steal my truck it won't start unless it can verify the chip.
    So supposedly it's either the chip inside my key, or it's the key transponder inside my truck
  7. Feb 5, 2025 at 4:10 PM
    LohssaToy
    LohssaToy New Member
    Following to see the resolution!
  8. Feb 5, 2025 at 4:17 PM
    Acidriver267
    Austin
    Ontario
    2007 tundra 4.7 v8
    That was the problem my key so I got it working again timming belt is fine everything is fine. Just my key apperntly
    FrenchToasty likes this.
  9. Feb 5, 2025 at 4:47 PM
    yakeng
    yakeng 3URFE Apologist
    2020 Tundra 4x4; 2014 Sequoia;
    ECGS Bushing; GCS Cooler RASHD; Fox 2.0
    This thread confuses me.
  10. Feb 5, 2025 at 4:51 PM
    LohssaToy
    I feel absolutely the same!
