RESOLVED: coolant leak after timing belt replacement
Discussion in '1st Gen Tundras (2000-2006)' started by Weagle, Aug 3, 2024.
  1. Aug 8, 2024 at 11:13 AM
    #61
    Mr Badwrench
    Mr Badwrench New Member
    Glad you got it! One bolt or washer always seems to get away.
    Weagle[OP] likes this.
  2. Aug 8, 2024 at 1:33 PM
    #62
    bfunke
    bfunke Tundra Curmudgeon
    Glad you got it. The crank position sensor wire is attached to a clip on the driver side cam cover. My clip was broken so I zip tied it to the clip. I tried to look up the PN and get a new clip but 82711-43020 doesn’t look anything like the clip that’s on my truck. I was thinking a clip that has a snap around the wire would be better. Let us know what you do.
    Weagle[OP] and des2mtn like this.
  3. Aug 8, 2024 at 1:34 PM
    #63
    AZBoatHauler
    So.Arizona
    I can take a pic of how I did it - fair warning I’m 90% sure it’s wrong but I haven’t had a problem yet.
    :fingerscrossed:
  4. Aug 8, 2024 at 1:39 PM
    #64
    AZBoatHauler
    So.Arizona
    I’m pretty sure the wires are supposed to go on the backside of that AC line.
    87warrior likes this.
  5. Aug 8, 2024 at 3:02 PM
    #65
    BroHon
    BroHon Undisputed Shock-King
    Bro
    Final Outpost/Bitch Mitten
    '00 SR5 AC V8 4x4
    Iron oxide weight reduction
  6. Aug 8, 2024 at 4:03 PM
    #66
    Weagle
    Weagle [OP] I survived my timing belt change
    Prattville, AL
    2006 Tundra SR5 DC 4.7 2WD LSD towing pkg
    Bilstein 5100's with 2883's - close to 2" Replacing the 2883's and going back to the bottom perch ASAP -mobile/apple play stereo with sub and backup cam -Power stop HD front calipers and rotors for towing -20" wheels with 32" tires (305/50's) Toyo AT 3's with no rubbing -Westin nerf bars -Detroit axle new (not rebuilt) steering rack with poly bushings, inner and outer TRE's -Suspension Maxx extended front sway bar links -Overland tuning - medium level -Power front leather seats and steering wheel from 06 Sequoia -fully de-chromed/blacked out trim -all light housings incl 3rd brake light and tag lights replaced with smoked lenses, LED where appropriate -mini projector headlights -fully rebuilt trans and new torque converter -new complete drive shaft with spicer u-joints and carrier bearing -all LED interior lights including backlighting -new lower window seals for all 4 doors -all new hardware and clips for tailgate Next: Dirty Deeds racing exhaust with LT headers, yellow box, 12 hole DD fuel injectors, redo or replace door panels
    Thanks. Behind the fan bracket
  7. Aug 8, 2024 at 5:18 PM
    #67
    Added to megathread.
  8. Aug 8, 2024 at 5:20 PM
    #68
    Weagle
    Prattville, AL
    Thank you and good call Shifty - that should definitely help others in the future
    I'm sure that information is out there, but I spent a long while searching without luck
  9. Aug 8, 2024 at 5:21 PM
    #69
    We haven't had one that looked as good as @BroHon's sample there, and that's what I'd been waiting for.
  10. Aug 8, 2024 at 5:59 PM
    #70
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    First contribution! :hattip::yay:
  11. Aug 8, 2024 at 6:24 PM
    #71
    BroHon
    Bro
    '00 SR5 AC V8 4x4
    It took a little finagling but both connector ends can fit down through there. A pair of needle nose pliers will be helpful. At least with my big meat fists it made it easier.
    Here is what you are avoiding by having them routed properly.
    des2mtn and Weagle[QUOTED][OP] like this.
  12. Aug 9, 2024 at 5:14 AM
    #72
    NickB_01TRD
    KY
    01 Tundra V8 4X4 AC SR5 TRD
    I need to actually look at mine now that there's a great example picture to look at. I keep forgetting to. The dealer did my timing belt last so I'd like to think it's good.
