My son’s tranny ... help
Discussion in 'Other Toyota Vehicles' started by Porkchop Express, Jun 21, 2019.
  1. Jun 21, 2019 at 8:08 PM
    Porkchop Express
    Porkchop Express [OP] Its all in the reflexes
    Cody
    2017 Tundra CM
    Lift , tires , stereo , TRD headlights , Rolling tonneau
    My son accidentally drained his transmission instead of the oil.
    2006 Taco automatic.
    I have no idea how much he let out , I put 1.5 qts of Valvoline Max life in it and he said it was OK.
    Well , now he says it’s hesitating out of first gear and Has high Reving .
    I’m at a loss .
    Any thoughts on how to salvage this ?
  2. Jun 21, 2019 at 8:13 PM
    Aerindel
    Aerindel New Member
    Montana
    No idea what your actual capacity is...but I think its a LOT more than 1.5 quarts. Check the dipstick. I suspect you're talking more like 4-5 quarts to fill it back up.
    Black Wolf and Mountun Goat like this.
  3. Jun 21, 2019 at 8:18 PM
    AZTundra
    Paul
    Phoenix, AZ
    That title made me laugh....:rofl:
    Is there no dipstick to check the level?....
  4. Jun 21, 2019 at 8:20 PM
    Aerindel
    Aerindel New Member
    Montana
    A quick search is showing about 3.5 quarts for a drain and fill. Start putting more in it, checking the level as you go (with the engine running)
    Black Wolf likes this.
  5. Jun 21, 2019 at 8:20 PM
    AZTundra
    Paul
    Phoenix, AZ
    Sounds like the capacity is 4 quarts if you drain the pan if that helps any.
  6. Jun 21, 2019 at 8:20 PM
    CyberViking
    CyberViking New Member
    The Ozarks
    2018 MGM Tundra TRD Sport
    It's probably never been changed..the only thing that was keeping it going was the suspended material in the oil.
  7. Jun 21, 2019 at 8:21 PM
    AZTundra
    Paul
    Phoenix, AZ
    That sucks...
  8. Jun 21, 2019 at 9:09 PM
    Porkchop Express
    Cody
    2017 Tundra CM
    Yeah , no dip stick . There is a check plug on the pan. I will add some more in the morning and try the check procedure.
  9. Jun 21, 2019 at 9:10 PM
    TheBeast The Beach
    this seems pretty common on tacos. my buddy did the same mistake on his new to him 2012 Taco few months back :) I told him he should have bought a Tundra...
  10. Jun 21, 2019 at 9:52 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Trans temp should be between 95-115. If you have a scan tool. Usually 3-3.5 quarts when you drain.
    Darkness likes this.
  11. Jun 21, 2019 at 10:00 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    No, more likely that he is running with not enough fluid for the transmission to function. If you are low on fluid your tranny won't be able to shift.
    He should just do a drain and fill at this point. Sounds like the amount of fluid in the tranny is unknown, but draining and filling can change that.
    Black Wolf and Aerindel like this.
  12. Jun 21, 2019 at 10:07 PM
    TXTundra2722
    2015 Black Tundra
    Same here, I only clicked on this thread just to make sure we were talking about transmissions..... now I'm disappointed. :);)
  13. Jun 21, 2019 at 10:28 PM
    Aerindel
    Aerindel New Member
    Montana
    This.
    Being extremely low on ATF will cause all sorts of problems. The torque converter is probably half full of air the way it is right now.
  14. Jun 22, 2019 at 2:32 AM
    Toyokuhl
    Toyokuhl New Member
    aaron
    SWFL
    2018 Cav Blue CM OR
    Confirmed, son's not a tranny?
  15. Jun 22, 2019 at 3:02 AM
    GNTundra
    Gino
    2013 White
    Titles the only reason I showed up! :D
  16. Jun 22, 2019 at 8:22 AM
    Porkchop Express
    Cody
    2017 Tundra CM
    Nope. Not a tranny , but tranny problems abound ...
  17. Jun 22, 2019 at 9:36 AM
    Mr Badwrench
    Mr Badwrench New Member
    Why does Toyota do this crap? How hard could it be to include a damned dipstick?
    Black Wolf, 15whtrd and 15Yota like this.
  18. Jun 22, 2019 at 9:51 AM
    15whtrd
    15whtrd Mr. Blonde
    I have never shied away from doing minor and major maintenance on my vehicles. But something is intimidating to me about having the transmission at specific temperature while adding oil. Sounds too unreliable haha. I like the simplicity of the dipstick and just having the vehicle up to operating temperature. Having the transmission temperature somewhere in the middle just feels unreliable.
    Darkness and 15Yota like this.
  19. Jun 22, 2019 at 10:00 AM
    realtorblake
    realtorblake Tundra Thunda
    Redneckistan... aka Cypress, TX
    2019 Crewmax Platinum 5" Zone lift Fox 2.5 /OME suspension 12.5x35x18 ProComp's
    Yeah, I was hesitant to open it...LOL
    AZTundra[QUOTED] likes this.
  20. Jun 22, 2019 at 10:03 AM
    Black Wolf Bigfoot Hunter, Sasquatch too, but not Yeti
    Aurora CO
    The engineer that thought hiding the starter and oil filter on the 5.7L determined that leaving off the dipstick would save 15 cents.
  21. Jun 22, 2019 at 10:14 AM
    15whtrd
    15whtrd Mr. Blonde
    I’m still used to old school. Drive the car around, pull back in the driveway on flat ground, engine running and check the level LOL use small funnel and fill as necessary.
  22. Jun 22, 2019 at 10:35 AM
    Aurora CO
    With a truly sealed transmission the recommended sweet spot temps need to be followed. AT fluid will expand and contract. Transmissions with dipstiks aren't sealed. More convenient but good luck making 90K miles to first service like the sealed transmission.
    15Yota and 15whtrd like this.
  23. Jun 22, 2019 at 11:48 AM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    My instinct would be to do this, fill cold and get up to temp, pull inspection plug to let excess bleed out and I would think that would work. Otherwise I would have my neighbors thinking I'm doing some Heisenberg shit in the front yard with the bunsen burners out.
    15Yota likes this.
  24. Jun 22, 2019 at 3:28 PM
    Aerindel
    Aerindel New Member
    Montana
    The reason the vehicle needs to be running....at least for dipstick vehicles, is that the torque converter sucks up a quart or two of fluid when its spinning that it doesn't when its not.
  25. Jun 22, 2019 at 5:41 PM
    Porkchop Express
    Cody
    2017 Tundra CM
    ok , i went to the dealer and bought 4 qts of toyota WS fluid. Got the truck running for about 15 minutes , cycled through the gears while parked.
    Pulled the check plug and drain plug, got maybe one quart out , but it looked clear and no smell or particles.
    Replaced drain plug and pumped 2 qts into the fill plug, started the truck and checked the gears , all good no leaks.
    Turned off truck and pulled the check plug and it pissed out a quarter of a quart before i got it back in place.
    Thats the key - only pull the check plug when the truck is running.
    OK - i started the truck again , pulled the check plug and added another quart and 1/2 until fluid started dribbling out of the check port.
    installed check plug , installed fill plug and test drove.
    Night and day difference.
    No hesitation , no stutters . Runs better than the day he bought it.
    So , for $40 and some time ,now he can get the hell out of my driveway!
    Aerindel, Darkness and 15Yota like this.
  26. Jun 22, 2019 at 10:34 PM
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    Glad that worked.
