My Rant
Discussion in '2nd Gen Tundras (2007-2013)' started by vjb, Oct 9, 2022.
  1. Oct 9, 2022 at 12:20 PM
    vjb
    vjb [OP] New Member
    V.J.
    Idaho
    2011 Tundra Limited 4x4 5.7L
    Installed Bilstein 5100 shocks front & rear. Front set at first ring (0.85"). Attempting to get this 2011 Tundra off-road ready.
    My rant on Tundras.
    So far I'm not impressed with my Toyota Tundra. Not easy to work on, components that need occasional replacement, such as starters, alternators, etc., are located in areas not easy to get to or require removing half the engine/vehicle to get to the part you want to repair – poor engineering. Parts are expensive, independent mechanic are few and far between and dealerships charge an arm and leg to work on these vehicles.
    I recently replaced the alternator in my 2011 Tundra because of an oil leak above it's location. After removing the alternator I cleaned the area and it appears there's a small leak from the junction between the Cylinder Head and the Cam Tower, just above the alternator. I've attempted to seal it externally with silicone, will run it for a few days and see what happens. Also, it should not take hours and most of the skin off your arms and hands to change an alternator – put the damn thing where it can be easily replaced. Toyota could learn a lot from GMC, Ford, Dodge & AMC.
    Continuing, because it's such a small oil leak I would normally just let it leak, but it's leaking on the alternator and I believe this could be a fire problem. I could not see a way of diverting the oil from leaking elsewhere and not on the alternator, so I hope my silicone fix does the trick.
    To be continued!
  2. Oct 9, 2022 at 12:21 PM
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    2 rant threads, you must be spicy
  3. Oct 9, 2022 at 12:23 PM
    FrenchToasty
    Mo
    Bone stock
  4. Oct 9, 2022 at 12:31 PM
    timsp8
    NY
    It’s good that Toyotas hold their value. You could trade it in on a domestic and get a lot for it.
  5. Oct 9, 2022 at 12:55 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    Just one rant.
    The other threads was asking where to post this rant.
    :annoyed:
  6. Oct 9, 2022 at 1:10 PM
    PhotoNerd
    PhotoNerd New Member
    Tony
    Waterford, CT
    2008 Salsa Red Tundra DC SR5 4x4
    Chrome delete, Sequioa grill, bed lights, LED + head, fog & tail lights, Dynamat throughout, front & rear cameras, Pheonix PX6 13" head unit, 8" subwoofer, JBL speaker upgrades, tonneau cover, custom shifter, steering wheel cover
    Oil changes suck.
    Remove the entire rusted out skid plate every time? And the stupid nut on the oil filter housing that requires far more torque to remove than the oil filter it's mounted on??
    Tundra Dude 45 likes this.
  7. Oct 9, 2022 at 1:24 PM
    FrenchToasty
    Mo
    Bone stock
    The first thread came off as ranty, “im angry, where should I rant?!”
  8. Oct 9, 2022 at 1:37 PM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
  9. Oct 9, 2022 at 4:36 PM
    TheBrit
    TheBrit Wrinkly member
    Mark
    2013 Double Cab Tundra 2WD stuckinthemud
    That's great news for those with ones that are gunked up with silicone. :rofl:
    Cpl_Punishment likes this.
  10. Oct 9, 2022 at 4:38 PM
    TheBrit
    Mark
    I found the alternator to be quite the easy fix when compared to replacing the passenger side dipped headlamp bulb...
  11. Oct 9, 2022 at 8:06 PM
    Cpl_Punishment
    Neil
    2020 MGM SR5 CM 4X4
    At least you don't have to replace it every 3 weeks like on the 2007-2013 GMs...
