My Plan well kinda
Discussion in 'Suspension' started by Payaso 9394, Apr 16, 2017.
  1. Apr 16, 2017 at 11:23 AM
    Payaso 9394
    Payaso 9394 [OP] New Member
    Ricky
    La Puente CA
    16' Tundra 2wd CrewMax 5.7l
    Tint, 33x12.5r18
    What's up Tundra World so I had a plan but not sure if it would work so here it is not going to do much off road it 4x2 but still might just messing around with it so I want something ok thinking fox 2.0s and rear fox shocks and level it out then later go get maxtrac spindles and atlas leaf Springs to make it a 4invh lift but then again would want to do 6inch lift would it work either 4 or 6 using the spindles and Fox 2.0s any advice would be appreciated different brand shocks or leaf Springs but want to do it in parts shocks then go to spindles and leaf springs
  2. Apr 16, 2017 at 12:56 PM
    Spacer lift? Stay away from wont get much shock travel not a suspension guru myself but jus from getting info from guys here also you'll feel every bump on highway with spacer lift im sure someone else will chime in n help out
    Law323 and Payaso 9394[OP] like this.
  3. Apr 16, 2017 at 1:15 PM
    Check out toytec.com boss kit
  4. Apr 16, 2017 at 10:13 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Yeah I saw that one but not sure if they be better or not as good as the fox ones don't want Nutting to pricey or to much if it not much off roading
  5. Apr 16, 2017 at 10:14 PM
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    ^^^^^^X2
  6. Apr 16, 2017 at 10:19 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Aight so two down for the boss kit but would it work with my spindle and leaf pack I want to get later on also
  7. Apr 17, 2017 at 8:37 AM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    I got my Rockstar 2s with 33x12.5r18 if I go to the 4 or 6 inch later I'll do 35s cooper stt pro
  8. Apr 17, 2017 at 8:38 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Toytec.
    You can run 35's on a 3/1 and toytec boss goes up to 3.5 or 4 IIRC
  9. Apr 17, 2017 at 7:57 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
  10. Apr 17, 2017 at 8:21 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    I was thinking those spindles with these shocks or coilovers and a custom atlas Springs for either 4 or 6 inch lift got a baby right now so don't know it 6 wld be to high but he'll grow and it won't matter later Screenshot_20170417-201854.jpg
  11. Apr 17, 2017 at 8:22 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    But for now just getting shocks to level it out and have better ride then do the spindles with leaf pack
  12. Apr 17, 2017 at 8:36 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    20170417_203406.jpg how it sits right now
    Jsena likes this.
  13. Apr 17, 2017 at 9:46 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Cuz it get pricey shocks are like 1g spindles 500 to 600 then leaf pack I think like another 600 n up plus maybe need ucas not sure there 6 to 700 and would want to buy new tires copper stt pros 35s so it just all add up so if I do it in parts it doable shocks then do spindles,leaf pack,tires
  14. Apr 17, 2017 at 10:31 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Yeah I get you I think there 6 sumthin backspacing not sure got to check they shld be 18x9s I think but I'll check I was forgetting bout that thanks gntundra
  15. Apr 17, 2017 at 10:32 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    And the other 98 ha jk yeah but I just hate the ride right now with stock suspension I flop around the whole street
  16. Apr 17, 2017 at 11:02 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Yeah boss kit looks clean or even the ultimate lift kit is nice just still like fox a lil better not sure why
  17. May 13, 2017 at 12:50 PM
    Payaso 9394
    Ricky
    La Puente CA
    Tint, 33x12.5r18
    Got the wheel specs
    18x9
    Offset 30
    Backspace 6.18
    Max load 2500
    Center bore 100.5
    So I'm Guna end up going with four inch lift I got recommended 2.5 icons but idk they pretty pricey
