My number one complaint about my '19
Discussion in '2.5 Gen Tundras (2014-2021)' started by Pac12AfterDark, Nov 21, 2021.
  1. Nov 21, 2021 at 9:53 AM
    Pac12AfterDark
    Pac12AfterDark [OP] New Member
    Why the hell are these GD windows so slow up and down?!
    I searched this forum to see if there is a faster motor I could install but came up with nothing. Anyone have a solution?
  2. Nov 21, 2021 at 10:55 AM
    2mchfun
    Maybe activate the switch a few seconds earlier.
    JLS in WA, hagrid, Bob_Wiley and 21 others like this.
  3. Nov 21, 2021 at 12:00 PM
    Pac12AfterDark
    Or push the switch down faster?
    redhat, Trooper2, snivilous and 4 others like this.
  4. Nov 21, 2021 at 12:07 PM
    Blueknights75
    Ron
    Clayton, NC
  5. Nov 21, 2021 at 12:07 PM
    2mchfun
    Try being thankful you have a truck with a switch and windows. It could be far worse!
    Ely010606, Jaypown, WILLINH and 2 others like this.
  6. Nov 21, 2021 at 12:33 PM
    TundraMcGov.
    Jofus
    Burpinham, Babalama
    2015 MGM Limited 2x4 Sequoia
    Eggzactly right. My daily driver. Take a look at these window operators. The inhumanity is beyond calculation.
    Avi8or, Y0TA PR0, batman900 and 22 others like this.
  7. Nov 21, 2021 at 12:43 PM
    Pac12AfterDark
    This has been incredibly helpful, thank you for your detailed and thought provoking responses.
    hagrid, Black Wolf, GeoJoe and 12 others like this.
  8. Nov 21, 2021 at 2:34 PM
    Half track
    Half track New Member
    Rob
    Western Nevada
    2020 Silver Tundra SR5 TRD, 38 gal tank
    Tow Mirrors
    Check your battery and cables. Low battery or bad connection can cause this problem.
    snivilous and Pac12AfterDark[OP] like this.
  9. Nov 21, 2021 at 2:55 PM
    ddact
    ddact New Member
    2019 5.7L 4WD SR5 DC FFV - Black
    Have you compared them to the speed of another Tundra? Just to be rule out an actual problem? I know on my 2019 they're as fast or faster then any other vehicle I've had.
  10. Nov 21, 2021 at 11:27 PM
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    F150 windows are faster
    IsaiahCanada likes this.
  11. Nov 21, 2021 at 11:35 PM
    AlaskanAssassin
    AlaskanAssassin I now walk into the wild
    David
    Alaska
    2020 DC TRD-OR, Cement
    I’ve thought the same thing, especially in the Alaska cold. Not sure if this is normal but even though mine is auto down it often stops 2/3 off the way down requiring me to push it again. I’ve had quite a few awkward drive-thru moments when I’m reaching out to grab a coffee as it’s rolling down only for it to stop and I bump into it.
    Mater and Dr Doobie like this.
  12. Nov 22, 2021 at 3:56 AM
    War Machine
    War Machine SSEM # 5 3MW
    Thoughts and prayers.
    Mater, gosolo, plumber802 and 13 others like this.
  13. Nov 22, 2021 at 4:46 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
  14. Nov 22, 2021 at 4:59 AM
    Cody1060
    Cody1060 New Member
    Ken
    Mid Michigan
    2021 Tundra 1794
    Why do you have three peddles? Gas, brake, what's the third one for?
    Window accelerator!
    Katblackdiesel likes this.
  15. Nov 22, 2021 at 5:10 AM
    2mchfun
    The open/close speed could be doubled by limiting the travel by 50%.
    Saltyhero13 likes this.
  16. Nov 22, 2021 at 5:19 AM
    1UP
    1UP Truck Gang
    I too have a 19. My #1 complaint has about 20 sub bullets and will cost me another +20k in mods.
    So your actually doing pretty good.
    2mchfun likes this.
  17. Nov 22, 2021 at 6:32 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    Thanks man!
  18. Nov 22, 2021 at 6:40 AM
    alpinepro4
    alpinepro4 What is your MPG Today!
    Pat
    2017 TRD Pro Cement DC
    Baja Designs Squadron Sport Fog lights, ARE CX Series Topper, Alcan Springs , DAP Tune, Coach Builder +1 Shackles, Headlight Revolution Supernova V.4 LED bulbs, HR LED interior bulbs. General Grabber ATX 275/70/R18
    I put a supercharger in my door. Fast as hell now:bikewhoops:
  19. Nov 22, 2021 at 6:45 AM
    Terndrerrr
    Terndrerrr 924000 miles to go
    Music City
    6UR-FE
    I second the suggestion to find another Tundra and clock its window speed. Mine are fine. I wish all 5 were auto up/down like my 4Runner, but whatever.
    Either there's a problem and yours are actually slow, or whatever vehicle you're comparing it to was on the fast side.
  20. Nov 22, 2021 at 6:55 AM
    Jernik
    Jernik New Member
    Jeremy
    2020 MGM Tundra Crewmax
    Good Lord, Man! That's just plain uncivilized! :rofl:
    I wonder if the OP has a white Tundra?
    Katblackdiesel and Darkness like this.
  21. Nov 22, 2021 at 7:07 AM
    andnyleswillriot
    andnyleswillriot Not Remote Working
    Breckenridge, CO
    2016 DC w/ Black Topo Topper
    Toytec 3" w/2.5 Coilovers. SPC UCA's. Method Roost Bronze Wheels. 35" BFG KO2's. SPC Upper Control Arms. 2019+ TRD Pro Grill. LED headlight bulbs. 2020 OEM LED Fog lights. Tech12volts Remote Start. MobArmor Magnetic Phone Mount. Topo Topper.
    Might be the most first world problem thread I've seen. Jesus...
    AlaskanAssassin likes this.
  22. Nov 22, 2021 at 7:11 AM
    EatSleepTacos
    EatSleepTacos New Member
    Randy
    West Valley, AZ
    2020 Crewmax SR5 TRD Sport
    I added this module to make all the windows auto up/down when controlled from the drivers seat. It also allows you to control them from the key fob and they'll also automatically roll the windows up when you park and lock your truck. It's pretty nifty. It could help with the slowness simply because you won't have to be paying attention to it, just tap the button and move on.
    https://www.3wliners.com/product/toyota-tundra-window-control-module-low/
  23. Nov 22, 2021 at 7:13 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
  24. Nov 22, 2021 at 8:16 AM
    Pac12AfterDark
    Thanks I will check this out and clock it against other tundras as other suggested.
    EatSleepTacos[QUOTED] likes this.
  25. Nov 22, 2021 at 8:54 AM
    Saltyhero13
    Dr Doobie and Darkness[QUOTED] like this.
  26. Nov 22, 2021 at 10:05 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    3.3 seconds down/4.2 seconds up for my drivers window with the truck on. Just tested it for you while I was waiting in the drive thru.
    Bob_Wiley, snivilous and 1UP like this.
  27. Nov 22, 2021 at 10:25 AM
    YeeYeeTundra
    YeeYeeTundra Earl Dibbles III incarnate
    Ohio
    2018 Quicksand CrewMax Limited TRD
    Extang tri-fold tonneau cover, havoc hs2 steps, A1 tow mirrors, TRD RSB, weathertech mats, 24' Puma BH travel trailer, Yeti 75, LineX
    I'm assuming no one's told him about the transmission cooler?
    I'm just kidding. Thank goodness it's not that. The windows are slow on the tundra I'll admit, however, if I could choose between a better stereo or window speed I'd choose the sound of music over wind the majority of time.
    Dr Doobie, JuanTon21, Oey12 and 3 others like this.
  28. Nov 22, 2021 at 4:58 PM
    PeakIT
    PeakIT Old Member
    Utah
    2019 OR Tundra Double cab
    Coachbuilder 3” shackles, King extended travel, SPC upper arms, 5:29 gears, FN FX rims,35"tires, leer shell, grill
    My 2019 is super slow too on all the windows . like my full sized border Collie can jump out before the window goes up.
    Pac12AfterDark[OP] likes this.
  29. Dec 20, 2021 at 5:26 PM
    RuralYota
    RuralYota New Member
    Ben
    2014 Tundra SR5 CM 4x4
    I’m getting very annoyed by my ‘14 SR5’s slow windows. Seems weak compared to my brother’s 1999 F250, which still go up and down at an impressive rate, and are a larger window. Surely we can do better with aftermarket motors? Anyone out there tried it yet?
    Yep, I know. First world problem, and if things keep going like they are, we soon won’t even be a first world country anymore, so this will likely fix itself…..
  30. Dec 20, 2021 at 5:31 PM
    alb1k
    Left Coast
    05 2WD DC w/ attitude
    It's good
    Just found this, could mature into an awesome thread. Fair start, but alas, slow going...
