My hobby and out of control obsession...
Discussion in 'Sports, Hobbies & Interests' started by nixon, Nov 8, 2017.
  1. Aug 11, 2020 at 3:53 AM
    #151
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    You don't have enough chains.
  2. Aug 11, 2020 at 6:15 AM
    #152
    nixon
    nixon [OP] New Member
    West Sunbury , Pa.
    2018,Cement Tundra CM Limited TRD
    You’re correct . But, I have 3 100 foot rolls in case I run real short ...
  3. Aug 11, 2020 at 4:12 PM
    #153
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    I wish i had even a small work bench area to work on my saws.Maybe 1 day
    nixon[OP] likes this.
  4. Aug 17, 2020 at 9:03 AM
    #154
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Still haven’t found parts for the other chainsaw. But found this old thing in the barn too. Appears to all be there. I might try to get it running this week
  5. Aug 20, 2020 at 5:03 AM
    #155
    nixon
    West Sunbury , Pa.
    Interesting saw ! Have never run across an IEL before . If the cylinder looks good ,and you hav spark , it’ll run . Should be appropriately loud to . On most old saws , I think the thing that they called a muffler was there just to keep you from getting your fingers in the cylinder . . .
    landphil and NewImprovedRon like this.
  6. Aug 20, 2020 at 6:48 AM
    #156
    empty_lord
    05 rollover special
    I’ve been stuck at Toyota school, but possibly tonight I’ll mess with it. Hope it does run. Seems like a neat old machine
  7. Aug 20, 2020 at 4:42 PM
    #157
    nixon
    West Sunbury , Pa.
    IEL’s are fairly rare on the saw forums . But they seem to be well regarded . Don’t expect it to turn a ton of rpm .Maybe 5-7k . Also when you make your fuel mix use 4oz (32-1) to a gallon for the first runs. It probably called for 16-1 back in the day . But, the oil used was 30w non detergent .
    NewImprovedRon likes this.
  8. Aug 21, 2020 at 7:09 PM
    #158
    empty_lord
    05 rollover special
    Hmm. The pioneer needs soaking in the cylinder but I don’t see damage. So it’s going to soak for a wee bit.
    But my Mcculloch. I want to get that sucker running. No luck finding recoil covers and a chain brake though. Know of any other models that had parts that would work?
    I also have no spark. But I believe the coils bad and that I can easily find NOS
  9. Aug 22, 2020 at 3:24 AM
    #159
    nixon
    West Sunbury , Pa.
    What model McCulloch is yours , is it a model 81 ?I’ll see what I can locate . No spark can be ,and likely is the problem with a saw of that vintage . This may help in locating parts for it http://www.barrettsmallengine.com/partslist/mccullochsuperpro81.pdf
    If you type mcculloch ,the name of the part ,and PN into your search engine ,sometimes you can find some hard to find parts .
    And there is no chain brake some on those .They could be bought with ,or without . I’ve got a model 15 that doesn’t even have a clutch cover . Throwing a chain can get interesting ...
  10. Aug 22, 2020 at 5:51 AM
    #160
    empty_lord
    05 rollover special
    It’s an SP81 the chain brake was there at some point. I can see the cover is setup for it. But the spring and handle are all gone. The coils cracked. Haven’t checked the condenser yet.
    nixon[QUOTED][OP] likes this.
  11. Aug 22, 2020 at 8:23 PM
    #161
    empty_lord
    05 rollover special
    Well the pioneer is seized solid still. I’ll let it soak more. But to do so I have to pull the carb. Putting it up for now. I believe it’s an old chrome lined cylinder so... who knows
  12. Aug 23, 2020 at 10:45 AM
    #162
    nixon
    West Sunbury , Pa.
    Old saws do take some perseverance at times . So, don’t give up on them . It’s pretty rewarding when you finally get to hear one of the come back to life .
    empty_lord likes this.
  13. Aug 23, 2020 at 11:00 AM
    #163
    empty_lord
    05 rollover special
    Oh I plan on getting er running.
  14. Aug 23, 2020 at 11:24 AM
    #164
    Hongkongwongdonf
    Hongkongwongdonf New Member
    Will
    Gastonia, NC
    2017 tundra limited
    5% tint. Black rhino arsenal 20x9.5 295/55/20 KO2.
    My dad has a Poulan he got when my brother was born, my brother is now 30. They don’t make them like they used to do they?
    NewImprovedRon and nixon[OP] like this.
  15. Oct 13, 2020 at 6:27 AM
    #165
    nixon
    West Sunbury , Pa.
    Picked up an early production 026 . ( oiler operates whenever the engine runs ) Had over170 psi compression . Changed the AV mounts ,Made a fuel line , drained out the swamp water from the tank ,new fuel filter ,rebuilt the carb , trued the bar . Runs very nice for a 24 year old saw . AE664619-C942-4EAD-9B22-2B38DBFD48B7.jpg4E76614C-A1DE-498D-87E0-BECD1F8B3598.jpg EEE2FB55-8271-45F0-8D9B-1F7835AA974F.jpgD3521CA2-18CE-428F-9D76-3B936E7C8CF8.jpg 5D206F5D-BD7E-41F8-B818-045EF48C2142.jpg
  16. Oct 13, 2020 at 6:34 AM
    #166
    nixon
    West Sunbury , Pa.
    Actually you said a lot there . The old Poulans were U.S. made ,and very well built . In fact the made a lot of stuff for Craftsman . If you find an old Craftsman saw ,and the model # begins wit 358 , it’s a Poulan ,and is generally worth fixing up .
  17. Oct 13, 2020 at 7:09 AM
    #167
    nixon
    West Sunbury , Pa.
    Thanks ! I repair a lot of these . This one was a guy’s “ loaner “ and spent a lot of time sitting in a case ,and neglected . I made him a real reasonable offer for it . As a side note , his Dad showed up here with two saws . A Husky 353, and a Stihl 029. The 353 was just a clean up chain sharpening and carb limiter reset . The 029 had had some hack do carb work . Put a decent rebuilt HD18 carb on it , replaced some missing pieces ,cleaned it up ,and sharpened the chain . Put it in the case that the 026 came in . Gave it all back to him . He’s 87 , raised a great family ,and still cuts firewood ! No charge . . .m
    Trooper2 likes this.
  18. Oct 13, 2020 at 10:27 AM
    #168
    nixon
    West Sunbury , Pa.
    Yeah, well , it’s my attempt to make amends for spending my youth , and money gambling, drinking ,and chasing women . The rest of it I wasted ... :bananadance:
  19. Dec 14, 2020 at 2:18 PM
    #169
    nixon
    West Sunbury , Pa.
    Well, the urge to et another saw struck again . This is the bar it will wear .
    And these are the only pics I have of it ,as it is Michigan being woods ported .
    22AC040E-4287-4EBA-AB9C-ABDD7983E6BD.jpg E6753052-4521-4552-9C02-C5AE75A204F9.jpg
    should be a fun saw . 60cc weight ,70cc ported performance .
  20. Dec 14, 2020 at 7:46 PM
    #170
    Toptalktoyota
    Toptalktoyota New Member
    2020 DC SX
    Well I just have to say that I love chainsaws about as much as I love Toyota. My introduction to chainsaws was when I was 17 working for the depart of the interior. It was a Stihl and was an amazing saw, no clue what model but just made a lasting impression on me as a young guy just getting into working mode.
  21. Dec 14, 2020 at 9:07 PM
    #171
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    My trusty old Husky L65 that was still my go-to saw until this spring. Camping, a load or two if firewood per year, it never missed a beat other than a piled up brake band which are NLA, and rare /expensive used. Older than I am, not sure by how much.
    My brother (who has a similar hobby as @nixon ) found this guy, put a carb kit in it and new fuel line, and sold it to me for too cheap. Almost unused condition.
  22. Dec 15, 2020 at 3:59 AM
    #172
    nixon
    West Sunbury , Pa.
    @landphil both of those are nice saws . That 61 looks mint ! I’ll keep an eye out for a brake band for your saw . Sometimes guys are parting out saws ,or will swap parts , just for shipping cost .
    landphil likes this.
  23. Dec 15, 2020 at 10:20 AM
    #173
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    That would be awesome, much appreciated.
  24. Dec 28, 2020 at 6:37 PM
    #174
    Toptalktoyota
    2020 DC SX
    :popcorn:Like this thread. Hope some more comments come soon.
  25. Jan 9, 2021 at 8:53 AM
    #175
    nixon
    West Sunbury , Pa.
    A611733A-6B3C-4428-A1F5-487CCA5274EB.jpg 49AD0735-7D62-469C-996B-DCA34C0EBA2A.jpg EBC7897A-C45B-45BF-B92A-83F25262C9AD.jpg AB773F1D-E466-42B3-8506-514E8C41BFE2.jpg C5788940-7E5F-4E1B-940E-F9AE749853D2.jpg Well things have been real slow . Winter kills chainsaw usage here . But , I was thinking about re-ringing my 372xp . So, I have torn into it today . I have been also thinking about a chainsaw work vice . I’d pretty much decided to have one made . They are hard to come by ,and not inexpensive. ($350)
    There was a drawing for one on one of the forums , so just for grins ,I entered my name . It was a shock to find out I’d won it !
  26. Jan 9, 2021 at 9:29 AM
    #176
    nixon
    West Sunbury , Pa.
    B16C3339-EE32-49F7-AA7B-6E357C197E03.jpg F02476F9-0C2D-4B98-BC13-1EEE570C4CA6.jpg New rings ..
    Uhhhh.... likes this.
  27. Jan 9, 2021 at 9:40 AM
    #177
    Uhhhh....
    Dave
    7” BDS, 37s
    I didn't know I needed that. That thing is cool!
  28. Jan 9, 2021 at 9:45 AM
    #178
    Uhhhh....
    Dave
    7” BDS, 37s
    I googled chainsaw vise, but all that came up were stump vises. Do you know where can I look for one, see the price, and not buy it?
  29. Jan 9, 2021 at 11:36 AM
    #179
    nixon
    West Sunbury , Pa.
    @Uhhhh.... You won’t often see them advertised . They are usually made in small numbers ,or individually .
    The contact info is :
    Tree Monkey Performance Saws , 715 450 0494 ,Augusta ,Wisconsin .
    His name is Scott Kunz . The price is $350 shipped .
  30. Jan 9, 2021 at 2:03 PM
    #180
    Uhhhh....
    Dave
    7” BDS, 37s
    Thanks! And awesome you won one :)
