My hobby and out of control obsession...
Discussion in 'Sports, Hobbies & Interests' started by nixon, Nov 8, 2017.
  1. Jul 4, 2020 at 12:06 PM
    #121
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    I’ve been looking. Nothing there. Might have to make a few calls around. Would love to get it running because I have ALOT of trees to cut down and my dinky craftsman probably wouldn’t survive
  2. Jul 4, 2020 at 12:08 PM
    #122
    empty_lord
    05 rollover special
    Supposedly some 10-10 starter covers or chain brakes might fit. But I’m not really wanting to spend and find out they dont! Lol
  3. Jul 4, 2020 at 12:15 PM
    #123
    empty_lord
    05 rollover special
    Ok... now this has me wondering if this is what happened to the saw I have... ive found little pieces of aluminum I couldn’t figure out where they were from. I bet the starter Grenada’s just like that one.. would explain why it was put away long ago... but they took the time to drain and the fuel and the carb... hmmm
    nixon[QUOTED][OP] likes this.
  4. Jul 4, 2020 at 4:26 PM
    #124
    empty_lord
    05 rollover special
    I haven’t tore into it to much. Apparently it’s points that are no longer available. I’ll dick with it as I can and figure out what it is. I have a feeling it’s the switch
  5. Jul 4, 2020 at 5:04 PM
    #125
    empty_lord
    05 rollover special
  6. Jul 5, 2020 at 5:23 PM
    #126
    nixon
    nixon [OP] New Member
    West Sunbury , Pa.
    2018,Cement Tundra CM Limited TRD
    For after market , I’d look at meteor . Word of advice , NEVER use a metal piston stop . Good way to punch a hole through your piston . Pull the plug , get the piston up above the exhaust port opening , and stuff the cylinder with some 1/8th inch cord to keep the piston from moving . And remember righty loosy on the clutch . But, before you trash the original jug , see if a machine shop can put an insert in it .
    Uhhhh....[QUOTED] likes this.
  7. Jul 5, 2020 at 5:28 PM
    #127
    nixon
    West Sunbury , Pa.
    That’s a really nice find !
    http://acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/7a0c5cc22d71ae4188256c2e0077863e
    y
    ou may be able to find what you need here ..https://www.leonschainsawpartsandrepair.com/store/c1/Featured_Products.html
    Or, at www.chainsawr.com .
    Also, if you give me a list of what you need for it , there’s a sawmill across the road from me . The owner’s dad was a McCulloch dealer . I have done a few favors for him ,and he may let me look through his parts stash for what you need . as far as the 10-10 starter fitting the 81 , I kinda doubt it . They were very different saws . The 10-10 was in the same family withe the 55,555, Pm700 .
    empty_lord[QUOTED] likes this.
  8. Jul 5, 2020 at 5:34 PM
    #128
    empty_lord
    05 rollover special
  9. Jul 5, 2020 at 5:39 PM
    #129
    Uhhhh....
    Uhhhh.... New Member
    Dave
    2016 Silver Limited DC
    7” BDS, 37s
    Thanks!
  10. Jul 5, 2020 at 5:50 PM
    #130
    nixon
    West Sunbury , Pa.
    Just going from memory , I believe they use a Timesert to restore the threads . Hopefully you’ll have the old girl healthy ,and running soon.
    Edit ...
    Check with some saw shops , they may be able to do the insert , or recommend a shop . When you reinstall the clutch and get the saw running ,engage the brake . It’ll help torque the clutch down . Also don’t run it with the clutch cover off until it’s been on a while . Things get pretty interesting if it pops off while at high rpm .
    Also , check youtube for the rope piston stop ,and clutch replacement procedures .
    They can be helpful .
  11. Jul 27, 2020 at 1:57 PM
    #131
    nixon
    West Sunbury , Pa.
    Just picked up this McCulloch PM700 Friday . New fuel lines ,clean the fuel , and bar oil tank , get the oil pump working , and she’s a runner . Very low time judging by the rim sprocket and general condition .
    Also , free !! 63E019B1-F80F-4C23-A7C1-204CCC96F6BF.jpgABCB3BB2-CC22-4A09-9C83-F57F77C77F13.jpg72D47FD5-EF21-4119-A2BF-83F8DD152982.jpgA86BD6C9-9154-40C4-AEEC-EB473484C140.jpg
  12. Jul 27, 2020 at 2:13 PM
    #132
    HARPER306
    HARPER306 New Member
    SK, Canada
    2020 Voodoo TRD Sport CM
    I don't know anything about chainsaws, never used one in my life. But this was an enjoyable thread to read through. Thanks :hattip:
    nixon[OP] likes this.
  13. Jul 27, 2020 at 2:36 PM
    #133
    Ace402
    Ace402 New Member
    2011 Tundra 4x4 SR5
    ADS 2.5 RR front and rear. MCM UCA & Shackles
    I’ll play. Here is my saw right after I brought it home.
  14. Jul 27, 2020 at 2:44 PM
    #134
    Uhhhh....
    Dave
    7” BDS, 37s
    Thoughts? It's available on Craigslist. It doesn't run - I may take a stab at trying to get it running, though I value my limbs too much to ever actually use it for cutting. If nothing else - cool thing to have. Model 917.60043
    NewImprovedRon likes this.
  15. Jul 27, 2020 at 4:25 PM
    #135
    Uhhhh....
    Dave
    7” BDS, 37s
    Thanks. Just picked it up. Piston is seized. Little project for me. Not sure if I can get it running but I’ll try & if not no loss - still pretty cool saw.
  16. Jul 27, 2020 at 5:37 PM
    #136
    MS22
    MS22 New Member
    02 Tundra 4x4
    This was my Stepdad's, after he passed my Mom gave it to me and it's been sitting in my garage for about 6 years. It turns over real easy and all I know is that it wouldnt stay started. After coming across this thread it's encouraged me to get to work on it. :thumbsup: Probably start by ordering a carb rebuild kit and go from there. 20200727_174251.jpg
    nixon[OP], Ace402 and Uhhhh.... like this.
  17. Jul 27, 2020 at 6:27 PM
    #137
    Garrett0105
    Garrett0105 New Member
    Garrett
    Evergreen
    2011 DC TRD
    no red-heads? :notsure:
  18. Jul 28, 2020 at 5:26 AM
    #138
    nixon
    West Sunbury , Pa.
    That was made for Sears by a company called Roper . Other than that , I haven’t a clue about it . Cool saw though !
    Edit ... http://acresinternet.com/cscc.nsf/ed1d619968136da688256af40002b8f7/b8ae0a0a1b001e8988256bb7005238ad
    I
    f you have spark ,and the cylinder ,and piston aren’t roached , you can likely get that beasty working . It generally involves evicting critters from the fuel and oil tanks ,and new fuel lines and carb work . Good luck ,and enjoy !
    As to finding parts , type “ Sears 917.60043 chainsaw “ into your search engine . You should get some info on it . Also try chainsawr.com And leans chainsawpartsandrepair.com
  19. Jul 28, 2020 at 5:48 AM
    #139
    nixon
    West Sunbury , Pa.
    You talking J-Red ,Dolmar ,or the more expensive two legged versions of red head ? :)
  20. Jul 28, 2020 at 5:55 AM
    #140
    nixon
    West Sunbury , Pa.
  21. Jul 28, 2020 at 6:40 AM
    #141
    Uhhhh....
    Dave
    7” BDS, 37s
    Thanks for the info!
  22. Jul 28, 2020 at 6:55 AM
    #142
    Uhhhh....
    Dave
    7” BDS, 37s
    I haven't had a chance to take a good look at it yet, but it won't crank. Piston possibly seized. I can move the chain back & forth a little bit - bout an inch or two (haven't tried loosening the bar tensioner to see if that helps). But the flywheel is completely seized - took off the flywheel cover last night & that thing wouldn't budge.
    I'll have time to disassemble this weekend/next week. I guess I'll start by taking off muffler & see how the piston looks & go from there.
  23. Jul 28, 2020 at 9:22 AM
    #143
    nixon
    West Sunbury , Pa.
    Pull the muffler to see if the piston is scored . If not , pour some fuel mix , liquid wrench , or pb blaster into the cylinder . Do the same on the carb side ( open the throttle when you do it so that a good amount will get to the reed block.) . Let it sit for a day ,or so . Pour out what you can into a jar so that you can see if it brought any junk with it . Repeat that once ,or twice . Gently move the FW to see if it is helping .
  24. Jul 28, 2020 at 5:52 PM
    #144
    Uhhhh....
    Dave
    7” BDS, 37s
    No real muffler. And no spark arrester or any sort of screen to keep crap out:
    The result of that:
    I don’t see any scoring, but I can’t get over all the crap in there.
    nixon[OP] and jewsNbrews like this.
  25. Jul 28, 2020 at 7:08 PM
    #145
    Garrett0105
    Garrett
    Evergreen
    2011 DC TRD
    Jumped on the J-Red train last winter when everyone was unloading the old stock. The 2166 with the chamfers ground out and an opened muffler has really surprised me. Well balanced, good weight, highly recommend!
  26. Jul 28, 2020 at 9:07 PM
    #146
    EAK
    EAK New Member
    KY
    ‘15 White 1794
    BAMuffler 8” SS Bilstein 6112/5160 Icon UCAs
    I had some tree work done recently and this beast was brought out. Sounded like a dirt bike.
    NewImprovedRon, Navi and nixon[OP] like this.
  27. Jul 29, 2020 at 4:20 PM
    #147
    nixon
    West Sunbury , Pa.
    OnSaws of that Period ,that was about par for the course as far a mufflers . Use some low pressure air to remove tat stuff from the exhaust port . Keep soaking the cylinder . From what little I see , it doesn’t look scored . Try some stuff down the plug hole ,and let it sit for a couple of days .
  28. Aug 3, 2020 at 3:36 AM
    #148
    nixon
    West Sunbury , Pa.
    Local farmer dropped this off to get running . Didn’t have much wear . So it’s a low time saw .
    U.S. made 61cc Poulan . Heavy for it’s size . But tough saws with tons of torque . He got it for $10 ,plus the $5 ,I charged him for fuel and vent lines . 2D4945F5-8D4D-4C4F-B126-FABBECEEFC67.jpg5E32E8EF-334B-4A2B-A216-397F81413523.jpg
    NewImprovedRon and jewsNbrews like this.
  29. Aug 3, 2020 at 4:31 PM
    #149
    nixon
    West Sunbury , Pa.
    Just picked up this one tonight .MAC 125CP . 16D699F2-B1C5-4026-8CE5-BC262BF13B86.jpg 52285A46-22CD-4CB4-B3A6-C5DE1B999D28.jpg 55630BC0-F978-45F1-BAD2-7C54207E796C.jpg Ran when put up . It’ll make a winter project . not bad for free . Just for scale , the saw above it is PM700 wearing a 20” bar .
  30. Aug 11, 2020 at 3:24 AM
    #150
    nixon
    West Sunbury , Pa.
    Just dissected a McCulloch 10-10S . Scored piston . The cylinder cleaned up nicely . So, all I have to do is locate an OEM piston ,and rings . Also added some more bench space to the shop last week . ( every thing to the right of the tool chest . BD4D9381-EE77-4106-A0CE-0B34DDAE4FD9.jpgD35AE5ED-0787-4FD9-AA38-E4ECA181C9B6.jpg493C6855-A085-4363-84E3-3D292B4A25A3.jpgB6D913D1-344A-4294-B608-A5A020FF5292.jpgF18A74F0-B436-4E16-8A50-B64AF054D200.jpg
