My hobby and out of control obsession...
Discussion in 'Sports, Hobbies & Interests' started by nixon, Nov 8, 2017.
  1. Apr 11, 2019 at 6:49 PM
    #61
    TiltedTundra
    TiltedTundra I am become death, destroyer of worlds
    MiddleWest
    2017 White TRD Pro
    more please!
  2. May 21, 2019 at 4:03 AM
    #62
    nixon
    nixon [OP] New Member
    West Sunbury , Pa.
    2018,Cement Tundra CM Limited TRD
    If someone ever offers you one of these , run away ... worst saw ever !
    The story :
    A neighbor brings over 3 saws . Two older Homelites ,and this yellow thing better known as a mini mac . I get the Homey’s going fairly quickly ,so it’s on to the mini mac . Bear in mind that you have to take this saw completely apart to do ANY thing beyond minor adjustments .( see the pics a couple of posts above ) So, after changing fuel ,and oiler lines ,rebuilding the carb , sealing the leaky fuel tank , it’s time to see if it’ll run .
    Well,it does . So while tuning the high end , the starter cone ( which is steel and bonded to very brittle plastic ) decides to drop into the flywheel at 10k+ ... That takes out part of the flywheel ,and it all comes out the top of the saw . That took out the fuel cap at the same time . Mind you , I’m holding this thing ! How any of that missed me for the most part ,and didn’t cause a fire is fortunate . Still haven’t found all the missing shrapnel .
    7932D241-C8A5-4E67-A703-BADD454BE986.jpg 46AE5012-3E33-4376-9DA8-BEB6ACD65165.jpg 8C84E14A-5307-4CDF-AD91-7950FC0D1A0D.jpg
    And the finished saw ... Going to tell the owner to put it on a shelf ,and not run it .
  3. May 21, 2019 at 4:24 AM
    #63
    nixon
    West Sunbury , Pa.
    Also picked this 572XPG up a few weeks ago . It’s really well suited to running a 28” bar . The heated handles will be nice on this old man’s hands come winter .52184F06-E086-43B6-B438-398FC56424A7.jpg3FC9B21B-05C2-4C36-B80D-114A07B40B78.jpg
  4. May 21, 2019 at 5:47 AM
    #64
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    ^ Speaking of hands there is no way I could dive into anything like that anymore!! Love seeing people that can and still do though. That is some fine fixin you have going on!! Ran into a few old saws here and there and seeing all of yours and others make me think I probably should have kept them. I gave them to the local saw guy that liked them as much as I did at the time, some were very heavy and I could only imagine carrying them all day???!! Thanks for your posts and keep on keeping on!!:)
    nixon[OP] and NewImprovedRon like this.
  5. May 21, 2019 at 2:36 PM
    #65
    nixon
    West Sunbury , Pa.
    Today’s collection of flogged OPE that found it’s way in for repair .. all ,except the Mac saw are good to go now . The saw will be good when I get a new purge bulb . They all got fuel lines ,carb resets ,cleaning ,etc .C10F5CDC-6E28-408E-8FB7-48C7E16DF870.jpg
  6. May 21, 2019 at 3:24 PM
    #66
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    I would like to say that you have a problem and should see a therapist. If they are any good can I have their number? I have a train problem I would like to talk to them about!
    nixon[QUOTED][OP] likes this.
  7. May 21, 2019 at 3:56 PM
    #67
    BlueDream
    BlueDream New Member
    2015 Tundra Dbl cab SR5 5.7
    6" procomp stage 3 lift, Method NV 18x9, Cooper STT pro 305/70R18, AFE air cleaner, LED fogs, Ranch hand Grille guard, Rhino liner, retrax bed cover, Flowmaster Duals, 15% Tint, vinyl chrome delete
    Nice!:thumbsup: I have a husky 460 Rancher with a 24" bar. These are awesome saws.
    Watt maker and nixon[QUOTED][OP] like this.
  8. May 21, 2019 at 3:58 PM
    #68
    nixon
    West Sunbury , Pa.
    I don’t think that professional help will work . Yesterday ,I had an appt. with my dentist . Next appt. ,he is bringing in his saws and chains for me to go through ... probably work out the same with a therapist ... :)
    landphil, Sunnier, Trooper2 and 2 others like this.
  9. May 21, 2019 at 4:08 PM
    #69
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    U might be able to help me out. I have a stupid lawn mower that only starts if I spray starter fluid in to the carb. Then I can shut it off and it starts again. If I try to start it the next day it’s a no go again u till I spray starting fluid in the carb again. I took off the carb and cleaned it and gas tank as well bought some 91 gas and added sea foam and it started up right away. Let it sit for a week and stupid thing will only start with starting fluid again. What is my problem lol
  10. May 21, 2019 at 5:46 PM
    #70
    Ajkkane
    Ajkkane Old fart.
    Nj
    2014 CM SR5
    My throttle cable came loose. The nut and bracket that holds the cable tight to the carburetor came loose.
    nixon[OP] likes this.
  11. May 21, 2019 at 7:36 PM
    #71
    Northbound Train
    Northbound Train Masshole
    Glenn
    Western MA
    Black 2016 SR5 Double Cab 4x4 5.7
    I used to do small engine repair, those mini macs and Eager Beavers were definitely the worst design for repairing. Having to remove the engine to do something as simple as replace the carb diaphragm was rediculous.
  12. May 21, 2019 at 7:45 PM
    #72
    Beastmode1794
    Beastmode1794 Masshole
    2019 tundra 1794 edition smoked misquite
    I got a husqvarna 440 and a stihl 391 love them both but once I got the stihl it's hard to pick up the husky 20190521_224155.jpg
  13. May 21, 2019 at 8:09 PM
    #73
    fisherman951
    Tony
    2017 crewmax 4x4
    I’ll have to check that out. Thank you
  14. May 22, 2019 at 4:52 AM
    #74
    nixon
    West Sunbury , Pa.
    Without seeing the carb , it’s gonna be a WAG . But , you are losing the carbs prime overnight ( if it has a purge bulb ) ,or your choke isn’t working ( likely cable out of rig as was suggested ) .
    Sunnier and NewImprovedRon like this.
  15. May 22, 2019 at 4:55 AM
    #75
    nixon
    West Sunbury , Pa.
    You just ain’t used the right Husky yet ...:popcorn: . :)
    Watt maker likes this.
  16. May 22, 2019 at 4:57 AM
    #76
    Beastmode1794
    Ooh I know they make great saws I just got the baby one haha
  17. May 22, 2019 at 7:23 AM
    #77
    fisherman951
    Tony
    2017 crewmax 4x4
    Thanks for the info. It doesn’t have a purge bulb that’s what sucks. I’ll post some pics and sorry I’m not trying to change ur topic of the thread but just trying to get help before I scrap this stupid lawn mower lol
  18. May 22, 2019 at 8:24 AM
    #78
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    Heh, heh...Chainsaws.
    There's a real personal assault weapon that gets zero attention from politicians and teen-twits alike. "School Sawing"...Now that would work off some hormones while achieving some real notoriety.
  19. May 22, 2019 at 2:24 PM
    #79
    nixon
    West Sunbury , Pa.
    Actually they both ,along with ,Echo ,and Makita ( Dolmar ) ,all make some pretty decent stuff if a person picks the right equipment for the tasks they will be doing .
    pull the fuel bowl off ,and check the bowl ,and jet for trash . The jet is actually the bolt that hold the bowl on . It’s hollow with a small passage on the side for fuel to pass through the carb . Could be partially blocked with sediment . Also ,it doesn’t look like your choke is closing all the way . That’s about all I can come up with from the pics .
  20. May 24, 2019 at 7:39 AM
    #80
    BlueDream
    No doubt! These millenials are dumber than a box of rocks, and about worthless when its comes to any kind of labor, I know, i try to use them for help around the property and end up doing it myself.
  21. May 24, 2019 at 7:41 AM
    #81
    BlueDream
    ya. after looking at my husky and your stihl, i got a little jealous. That stihl saw is badass. I might have to upgrade and get one of those.
    Beastmode1794[QUOTED] likes this.
  22. May 24, 2019 at 7:58 AM
    #82
    MARanger
    MARanger Lost in the woods
    Andy
    Home of Friendly's Ice Cream
    2017 Super White SR5 DC 4X4
    Nice thread. When I was climbing I ran Stihl only and had a 092 for climbing, had 026 for bucking and an old 066 for felling. Now I only have my 311 And I picked up an Echo 360T for when I do a climbing job for friends. Do miss the 066 though.
  23. Jun 23, 2019 at 2:02 PM
    #83
    nixon
    West Sunbury , Pa.
    A guy I fix saws for found this ,and gave it to me . It is 80cc’s ,built between 1962 and 1967 . Got it de-munged ,made some adjustments ,and it fired up. Needs some minor stuff to make 100% useable .
    No chain brake , clutch cover ,or chain catcher ,and a hard nosed ( no nose sprocket ) bar . E19EFA0D-AE02-4887-9CCD-ECC7CD50BE06.jpg6B7060CA-358F-426E-8F2C-0B7407944452.jpg732FB28B-075C-40AB-A90C-0A1EA0BC993F.jpgF4C3EB03-DD3B-42F9-83F6-F1E4F3684F3D.jpg9420049E-282F-4EE2-B381-A9157C238C06.jpgA32BC176-8987-4BD2-A201-0EFC34475681.jpg
  24. Mar 1, 2020 at 9:52 AM
    #84
    nixon
    West Sunbury , Pa.
    Haven’t had many interesting saws to work on lately . But a guy brought me this one that won’t start after sitting for years . It’s actually got very little run time on it judging by the cylinder ,and spur sprocket wear . Just needs a carb rebuild ,and it should be good to go .FA55AF83-97B1-4C90-AECD-B98F67C55FCF.jpg
    BigSkyTaco and NewImprovedRon like this.
  25. Mar 1, 2020 at 10:12 AM
    #85
    Rob's Inferno
    Rob's Inferno New Member
    2017 SR5 crewmax 4x4 Inferno
    Awesome.Love the Mac's.I have a few Macs myself.You can never have too many saws lol.
    NewImprovedRon and nixon[OP] like this.
  26. May 14, 2020 at 4:24 AM
    #86
    nixon
    West Sunbury , Pa.
    A guy I do chains for gave me these . A homelite C52 ,and a Shindiawa 488 . They Homey is going to take some time ,and research .The Shindiawa was straight gassed ,given that the piston is scored on the exhaust , and intake sides . It’ll make a great truck saw .EC0262E5-A247-42A2-859B-455EC2923623.jpg 9C35BFB7-6EB5-456A-803E-22D356C84B00.jpg 2C9C7E12-44FA-4E97-A1E0-14B4B0682F6E.jpg 69A89060-D61D-4111-A7D5-290CD8FE5D54.jpg AF53D86E-A6AE-409E-B5A5-49DB84AA031F.jpg
    NewImprovedRon likes this.
  27. May 14, 2020 at 8:50 AM
    #87
    ZPhilip
    ZPhilip Custom title here
    Philip
    West Chester, PA
    2015 Platinum Super White Crewmax
    Harrop supercharger, TRD Pro Fox suspension, CB +1 shackles, 295/70-18 Toyo ATIII, TRD Pro forged rims
    94696B30-9579-4A78-8D16-88617D100996.jpg A39E921E-8E0E-4396-A49C-6842C9A42B79.jpg Great thread. My neighbor gave me a Husky 61 Rancher from 1979. Got it running with fresh gas after sitting for 11 years. I put some minor work into it and it runs badass. Oh and chain brakes were optional back then!
    she also gave me all the original brochures and flyers, which is just as cool as having a chainsaw older than me.
  28. May 14, 2020 at 9:51 AM
    #88
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    I'm really interested in saws. I just bought a new Echo 620P with a 24 and have not even started it yet. I need a better set up to file with. Mine is pretty outdated. If you guys were going to buy one what would you get??? The grinder set ups that I have been around make everything to hard to file on afterwards
  29. May 14, 2020 at 11:45 AM
    #89
    Hammerdog
    Hammerdog YCMTSUP
    Robbie
    Louisa VA
    2018 tundra sport crew max
    Tint Bed cover Red Tow Hooks TRD Intake 7 inch BDS 22x12’s 35 Toyo’s Rigid ditch lights RC light bar in bottom grille One bad ass stereo
    I hate to say it but I’m intimidated a little by a chainsaw. I’m damn good with other tools and working on vehicles, etc but the only couple times I used a saw I felt uncomfortable. I need to cut some trees around my house to clean up some stuff but I’d have to get me a new saw and give it another try.
    GODZILLA and nixon[OP] like this.
  30. May 14, 2020 at 3:56 PM
    #90
    Sunfish
    Sunfish New Member
    17 4X4 CM Limited
    If you use one long enough there is going to be an incident. They are not toys and will send you to the ER PDQ. I always try to have a clear escape route and stay focused as to the wind. Keep in mind this is a chore you need to be in shape for after a couple tanks of fuel / oil take a break and look everything over good before going at it again. More than once I have had spring poles and butt ends jump right at me.
