My Front Blinkers Anger Me
Discussion in '2.5 Gen Tundras (2014-2021)' started by Silv333, Jan 12, 2019.
  1. Jan 25, 2019 at 1:29 PM
    #151
    Phadedbeard
    Phadedbeard New Member
    Ma
    16 Quicksand TRD Pro
    Lasfit do hyperflash on my 16 pro finally got around to installing them can anyone confirm no hyperflash on the JDM Astars?
  2. Jan 25, 2019 at 2:20 PM
    #152
    1933Oseries
    1933Oseries New Member
    Portland Oregon
    2018 Double Cab SR5 TRD Off Road
    Just installed the JDM Astar 1260 bulbs on my 2018 DC SR5 TRD Off-road with the LED headlights. Took 10 minutes and they work perfectly. Impressively bright. I haven’t addressed the rear blinkers yet.
    Pudge and nixon like this.
  3. Jan 25, 2019 at 4:38 PM
    #153
    fisherman951
    fisherman951 MT dreams
    Tony
    2017 crewmax 4x4
    Vled has a promo 15% off order WM15 is the code. It’s on their site
  4. Jan 26, 2019 at 9:23 AM
    #154
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Just braved the 16 degree weather and installed JDM astar bulbs and I have hyper flash. Guess I'll need resistors. That sucks.
    2015 platinum with 2018 headlight and ihacker harness.
    equin likes this.
  5. Jan 26, 2019 at 9:33 AM
    #155
    Pudge
    CT
    Seems that trucks 2018-19 that came with stock LED headlights do NOT get hyper flash with LED blinker bulbs but anyone who used a harness for 2014-2017 DOES get hyper flash. Anyone with a LED headlights conversion NOT get hyperflash?
    rebmo and equin like this.
  6. Jan 26, 2019 at 9:57 AM
    #156
    Pudge
    CT
    I can confirm that they do hyperflash on my 15. I think the guys without hyperflash are 2018 and newer. Us guys who did the LED conversion will get hyperflash unless we use resistors.
  7. Jan 26, 2019 at 9:59 AM
    #157
    Pudge
    CT
    I wonder if @iHacker could start including the option for a pre installed resistor for those who want to install LED turn signals. I'm sure plenty would pay for that, I sure would have.
  8. Jan 26, 2019 at 4:03 PM
    #158
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    NO Hyperflash on my 2018 Sport with the JDM's!!!!!! :eek:
  9. Jan 26, 2019 at 4:05 PM
    #159
    Phadedbeard
    Ma
    Yeah seems as though the 2018s and up are good to go with the non canbus bulbs or no resistors but us earlier guys are going to have to go that route.
  10. Jan 26, 2019 at 4:23 PM
    #160
    r1-superstar
    DB
    UTAH
    I don't think the ones I got do.
    Taken from the description on Amazon:
    ***Note you might need to add 50W 6-Ohm load resistors or change flasher rely to prevent the LED bulbs from hyper flashing.***
    Pudge likes this.
  11. Jan 26, 2019 at 4:49 PM
    #161
    flying dave
    flying dave New Member
    NC
    Received my order from VLED's today.
    Installed the 3rd brake light. Love it.
    Installed the 6 led reverse lights. Love them. However, not sure which way might be better to index them as you can rotate the led's in the housing. With the LED's vertically oriented or horizontally. At the moment, they are horizontal.
    Now on to the topic at hand. I ordered the V6 Triton's as well as the resistors. I have dealt with led's in other situations and have found them to be polarity dependent. With that thought in mind I thought I would try one first without the resistor. Success, no hyper flash. Removed it and installed the set screws and the foam washer and reinstalled it. Damn. Now I have hyper flash. Disconnected it at the factory plug and rotated it 180 degrees. Boom, back to normal. Installed the other side and had hyper flash the first time I connected it. Rotated the plug 180 degrees and again, NO hyper flash. I am keeping the resistors for now in case I replace the rear turn signal lights with more VLED bulbs which I have read may cause the problem.
    SO, if you have hyper flash with a bulb that others say they do not then ROTATE IT 180 DEGREES and try again. That may be all you have to do. I have an '18 with the led headlights. YMMV....
    Oh, one last thing. These things are f'n bright!!! I stared a little too directly at it when first hooking it up and I think I can still see it 2 hours later when I close my eyes... lol...
    Vr0ck and Phadedbeard like this.
  12. Jan 26, 2019 at 5:00 PM
    #162
    Pudge
    CT
    I did try to rotate mine but it didn't work out. I think pre 2018 need resistors unfortunately
  13. Jan 27, 2019 at 8:42 AM
    #163
    Donkeypunch
    Donkeypunch New Member
    Not true my 2019 had hyperflash with the V6 Triton bulbs when tried without the resistor pack.
    RoujePN and Pudge like this.
  14. Jan 27, 2019 at 8:45 AM
    #164
    Pudge
    CT
    Do you have full LED headlights? It seems to be guys with the OEM LEDs do not have hyper flash issues. Anyone who has or converted from halogen headlights are having the issue.
    equin likes this.
  15. Jan 27, 2019 at 8:45 AM
    #165
    Donkeypunch
    Of course. It’s a 2019 CM Platinum
    Pudge[QUOTED] likes this.
  16. Jan 27, 2019 at 8:47 AM
    #166
    Pudge
    CT
    Well there goes my theory lol
  17. Jan 27, 2019 at 8:48 AM
    #167
    Donkeypunch
    Could be because it’s a Platinum? IDK. But also maybe cause I converted ALL lights to VLEDs.
  18. Jan 27, 2019 at 8:51 AM
    #168
    Pudge
    CT
    I have no clue. Seems to be hit or miss on the issue. I guess the answer is stick with halogen or have resistors on hand
  19. Jan 27, 2019 at 8:53 AM
    #169
    Donkeypunch
    I don’t know why ppl are crying against the resistor like a plague. Just get or use them for crying out loud.
    vegas4x4, RoujePN and Pudge[QUOTED] like this.
  20. Jan 27, 2019 at 8:55 AM
    #170
    Pudge
    CT
    I have never used them. Seems easy enough, plug and play would be nice for sure, especially when its 8 degrees outside. I'll be installing resistors when it warms up in CT
    RoujePN likes this.
  21. Jan 27, 2019 at 10:34 AM
    #171
    danz75
    danz75 New Member
    Everett, WA
    18' Cement SR5
    OEM LED headlights, Rigid SAE foglights, Go Rhino RB10 running boards, ARE Classic CX
    My 2018 SR5 did not come with LED headlights. I bought the 2018 toyota LED headlights and used the iHacker harness. The JDM Astar bulbs installed without any resistors did not hyperflash on mine.
  22. Jan 27, 2019 at 12:53 PM
    #172
    flying dave
    NC
    I'm willing to bet this is the reason. I've got nothing against the resistors other than its 30 bucks I didn't have to spend and its 2 more things in the chain that aren't needed. I'll find out when I upgrade the rears at some point. The K.I.S.S. way of thinking resonates with me because I am the sofa king...
  23. Jan 27, 2019 at 3:32 PM
    #173
    mossmanfj40
    mossmanfj40 New Member
    Craig
    Pittsburgh, PA
    2014 Tundra CM 1794 version
    Toytec/Eibach 3/1, Vector 5 wheels with 295/70/17 Coopers
    Is it possible that the OEM blinker relays are.........different ? Just pondering.
    Myhobbes25 likes this.
  24. Jan 28, 2019 at 6:08 PM
    #174
    KELZ84
    KELZ84 New Member
    Kelly
    RGV,TX (McAllen)
    2016 Toyota Tundra SR5 TSS Off Road
    TTC MEMBER #0193 2.5 Bilsteins struts (front) JDMstar led lighting inside Lazarstar spot lights Auxbeam LED headlight bulbs Auxbeam LED fog light bulbs 1.25” Spidertrax wheel spacers OEM fender flares
    So lol hyper flash for sure on halogen lights? I dont have LEDs
  25. Jan 29, 2019 at 7:31 AM
    #175
    LyonKing
    LyonKing No way Bells is bigger than Waimea bro...
    2019 White TRD Pro
    Nitto Ridge Grappler 295/70/18 KMC XD135 GRENADE OR Light Bar - Rigid Flush mount reverse lights - Rigid Diamond Back HD Tonneau Cover AMP Research Powerstep OEM Wireless Charger Husky Liners X-act Contour mats Interior LED Swap Center Console Organizers 6 3/4" Antenna Pioneer 7" HU - AVH-W4400NEX Graco Nautilus 3-in-1 Car Seat
    I just order the JDM ASTAR's for my '19 Pro, for the fronts only...will report back on hyper flash when I can fit my banana racks in to install them.
  26. Jan 29, 2019 at 7:35 AM
    #176
    15whtrd
    15whtrd Mr. Blonde
    This sounds like a pain in the ass. Which is why I will probably never upgrade LOL
  27. Jan 29, 2019 at 10:02 AM
    #177
    mossmanfj40
    Craig
    Pittsburgh, PA
    Got my Putco Plug and Play resistors in the mail yesterday. They do not look anything like the picture they have listed for part 240008. I was hoping for a clean looking connector on each end with a black box in the middle type look. Not at all what I got. The website does state that the picture you see may not represent what you actually end up with. Nevertheless, I took the jumbled wire/connector setup out to the truck (it is cold) and plugged it into the ihacker harness that I have and the turn signals worked fine. I left the turn signals on for probably 5 minutes while I fumbled with my big old man hands to get the fricking connector with the bulb back into the headlight..........the bulbs then began to dim and eventually went out. Not sure if it is the bulb or the resistors. I checked all my connections and they appeared good. So.................I just pulled the leds out and said to hell with it. Put the incandescent bulbs back in. I will play with it more on a warmer day. Bottom line is that it appears as though resistors will work with the ihacker harness. Not sure if led's heat up so much that the overheat ? The resistors were not extremely hot to the touch.
  28. Jan 29, 2019 at 8:59 PM
    #178
    Silv333
    Silv333 [OP] Patriot
    NJ-NC-MD-NC
    2018 Cement Crewmax TRD Off Road
    Greek, German, Chinese, Japanese, whateva....
  29. Jan 30, 2019 at 7:05 PM
    #179
    zerch911
    zerch911 New Member
    San Antonio, Texas
    2016 Sky Silver Limited 4x4
    TRD Exhaust, 2018 Pro LED Lights, Bilstein Shock Leveling 6112 & 5160s, TRD Pro Color Matched Grill, Morimoto XB LED Fogs, 305/55/20 BFG KO2, Fuel Maverick Wheels
    Thanks for the update... I am by no means an electronics expert but it seems strange the LEDs would overheat (especially in the cold weather). Seems more like a failure of the resistor. If it happens again (when you try it again), I would try removing the resistor harness and plugging directly back to the iHacker harness to see if the LED works again. Maybe a process of elimination to figure out the issue.
  30. Jan 30, 2019 at 7:09 PM
    #180
    mossmanfj40
    Craig
    Pittsburgh, PA
    Good suggestion and I will do exactly that. Appreciate the suggestion.
