My Front Blinkers Anger Me
Discussion in '2.5 Gen Tundras (2014-2021)' started by Silv333, Jan 12, 2019.
  1. Jan 17, 2019 at 8:46 AM
    #61
    JoshuaA
    JoshuaA Canuck Member
    Southern Ontario
    Blaaack 2.5G
    Putco is the best one, I’ve seen lots of other brands and DIY on trucks out there that look like beads, with some burnt out. Putco looks like a solid light, 3y warranty.
    If you buy a Curt 55384 harness with it, it’s mostly plug and play, you just have to tap the reverse wire in the stock hitch after that.
  2. Jan 17, 2019 at 8:56 AM
    #62
    Brian0414
    Brian0414 Doomsday
    Tucson, AZ
    2017 Tundra Limited 4x4
    - Winjet Black/Smoke Fiber Optic LED Tail Lights Bilstein 5100
    JoshuaA[QUOTED] likes this.
  3. Jan 17, 2019 at 9:05 AM
    #63
    JoshuaA
    Southern Ontario
    Blaaack 2.5G
    Forgot to mention, I have towing mirrors with side blinkers that help a little too (if you’re in Canada, the OEM ones are only $177 each side from ToyotaPartsDirect.ca)
    Y0TA PR0 likes this.
  4. Jan 17, 2019 at 1:27 PM
    #64
    TundraNoCo
    TundraNoCo New Member
    Northern Colorado, FoCo
    2018 Toyota Tundra Platinum
    Bed lined, tinted all 5 windows, hose clamped tailgate, toolbox, steps, ESP rear seat storage bins, dash cam, anytime camera switch, console safe, pop a lock for tailgate and wheels/flares, sway bar. I have Techstream if anyone local needs it.
    As a result of this thread, I ordered the Lasfit bulbs in the link earlier in this thread. I would say they are a good 75% brighter in daylight. I took a video, but don't really have a way to post it. So, my 2018 Platinum had incandescent amber turn signals, that only illuminated for turn signals. These Lasfit bulbs act the exact same way. Replacing the turn signal bulbs with the Lasfits did not in any way affect the LED running lights that are on the perimeter of the headlight. So, the only change is the level of brightness for the turn signals. I mention this as there seemed to be a bit of confusion. Overall, for $20, I don't think you could go wrong. I've had a couple of people say that they could hardly see my turn signals (prior to LED replacement). Makes me want to put LED bulbs in EVERYTHING!
    LevelUp, spyshot and Grandaddy like this.
  5. Jan 17, 2019 at 1:38 PM
    #65
    TundraNoCo
    I took a screen shot of the video. The bulb on the passenger side is a Lasfit LED. The drivers side is an incandescent factory bulb. Keep in mind, the sun is shining on the passenger (LED) side, and the drivers side is in the shade. The passenger side with the LED is still brighter.
    Boosted4runner and georgiey22 like this.
  6. Jan 18, 2019 at 12:05 PM
    #66
    mossmanfj40
    mossmanfj40 New Member
    Craig
    Pittsburgh, PA
    2014 Tundra CM 1794 version
    Toytec/Eibach 3/1, Vector 5 wheels with 295/70/17 Coopers
    mart1nezdaniel likes this.
  7. Jan 18, 2019 at 2:21 PM
    #67
    Grandaddy
    Grandaddy New Member
    Roanoke Rapids NC
    2018 Tundra Limited CrewMax 4x4
    none
    Thanks for starting this post. I have wondered if it was just me that thought the turn signals on my 2018 limited were inadequate. I'm ordering a set of bulbs now from Amazon . Thanks again.
    r1-superstar likes this.
  8. Jan 18, 2019 at 2:28 PM
    #68
    fulanoderock
    fulanoderock New Member
    Ventura County
    2018 Toyota Tundra TRD Sport
    Been following the thread....just to confirm the JDM ASTAR bulbs won't need resistors installed correct? Plug and play?
  9. Jan 18, 2019 at 4:32 PM
    #69
    r1-superstar
    r1-superstar Kailua Boy
    DB
    UTAH
    Correct!
  10. Jan 18, 2019 at 4:36 PM
    #70
    Phadedbeard
    Phadedbeard New Member
    Ma
    16 Quicksand TRD Pro
    Do the lasfit need a resistor?
  11. Jan 18, 2019 at 4:49 PM
    #71
    SnrDisregardo
    SnrDisregardo New Member
    Wade
    IL
    2018 Platinum CrewMax 4x4
    TRD Sport Suspension, TRD Front & Rear Sway bar, TRD Pro Shift knob, Charcoal Filter Delete, aFe Pro Dry S w/SABM, LineX bed, Remote Start, OEM tonneau cover, DIY pop'n lock, DIY TRD cold air intake, TRD skid plate, DD SS3 amber fogs, HotShot Offroad Hot Tails, 2020 OE radio with tech12v amp and sub.
    Nope. Now I have a 18 with the factory LED headlights, if that has anything to do with it.
  12. Jan 18, 2019 at 5:30 PM
    #72
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    Do you have LED tail lights too?
  13. Jan 18, 2019 at 5:30 PM
    #73
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Aries Side Bars, DeeZee low profile tool box, weathertech mats, TRD RSB
    evening, sort of late in the post. I too thought that the front turns were weak, decided to go all out and do the VLED's. Problem solved with a 3 year warranty. Didn't have to disassemble the front of truck, just plug and play with VLEDS and resistor that screws in. Now no question that the on coming traffic can see my intentions to turn in front of them. Going on 4-5 months and that worry is gone. Can't recommend them enough. Thanks @BlueBottle for the coaching, with VLED lower cost bulbs in the back and can see the reflection of the stop signs from a block away. Am Happy with the result, no doubts that others see my intentions.
  14. Jan 18, 2019 at 6:35 PM
    #74
    mossmanfj40
    Craig
    Pittsburgh, PA
    No on the led tails. Stock. The headlights are the new led OEM headlights.
  15. Jan 18, 2019 at 6:45 PM
    #75
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    looking at the VLED website the search engine says that there are no bulbs for the 2018's. that is not true after talking to their tech support the 7443 bulb will fit the front of our trucks. (call for confirmation). wasn't happy with the offerings of the rears in the various companies, kept the factory housings and just replaced the bulbs. Rather awesome in light production. Project finished.
    1BlinkGone likes this.
  16. Jan 18, 2019 at 7:19 PM
    #76
    Phadedbeard
    Ma
    Well the lasfit bulbs showed up today we will see how it goes tomorrow.
  17. Jan 18, 2019 at 9:19 PM
    #77
    ninjajay
    Spoolston, TX
    good ol' tundras.com, pointing out things I previously had zero interest in and leading me to buy more things for my truck that I "was buying new to keep mostly stock"
  18. Jan 18, 2019 at 9:19 PM
    #78
    1BlinkGone
    1BlinkGone New Member
    Amber or switchback? thx!
  19. Jan 19, 2019 at 3:57 AM
    #79
    darkknight2014
    darkknight2014 Mods mods and more mods!!
    Phil
    New york
    2014 tundra sr5
    20" Cooper STT Pros on md rims, quadfire lights, pro grille, leather interior, navi, retrofitted headlights, blacked out chrome, TRD sway bar, hypertech interceptor, k&n air intake, Banks exhaust
    After reading these post i never realized how dim the signal bulbs were. Just ordered the lasfits from Amazon. Pretty cool that i dont need a resistor for it. Once again thanks to the tundy community for sharing good info.
    r1-superstar and reelcracker like this.
  20. Jan 19, 2019 at 7:26 AM
    #80
    Turtle
    Turtle New Member
    Tommy
    Louisiana
    18 TRD 4x4 CM MGM
    Amber.
  21. Jan 19, 2019 at 11:33 AM
    #81
    bornwild2791
    bornwild2791 New Member
    Brent
    2017 TRD
    LED Interior Kit - 2018 OEM LED Headlight Upgrade - LumaWerx LED Reverse - Morimoto XB LED Fogs
    georgiey22 likes this.
  22. Jan 19, 2019 at 12:10 PM
    #82
    panicman
    panicman Everyone remain calm.
    Eric
    2018 SR5 CM TRDoffroad MGM
    Mine arrived yesterday. I’ll throw them in my ‘18 SR5 today and confirm they are compatible with no resistor needed.... or not...
    fulanoderock[QUOTED] likes this.
  23. Jan 19, 2019 at 12:21 PM
    #83
    georgiey22
    georgiey22 Moving to Idaho
    2019 Tundra | TRD Sport | Cavalry Blue | Crew Max
  24. Jan 19, 2019 at 1:59 PM
    #84
    panicman
    Eric
    Installed! No resistor is needed and these dudes are quite bright- “hurt-to-look-at” bright.
    I do not have hyper flash.
    My video would not lend anything to this thread that the previous ones didn’t.
    For 20 bux, no shipping fee, and less than 5 minutes to install, the only mystery left is durability and bulb life. If I can remember to do it, I’ll hunt this thread down and update it when the day comes.
  25. Jan 19, 2019 at 2:04 PM
    #85
    escuzi_me
    escuzi_me Shut up baby, I know it!
    William
    Nashville, TN
    2019 Super White TRD Pro
    Thought I was the only one who thought this. I know I'm late in this thread, but for what it's worth I got the Triton's off vleds.com and they are BRIGHT. Added their resistors and they work flawlessly. It was a pain to install though having to take off the whole headlamp to access the bulbs. 2019 Pro and everything fits perfectly.
    In daylight with the lamps on..
    equin and r1-superstar like this.
  26. Jan 19, 2019 at 7:53 PM
    #86
    16TRD
    16TRD New Member
    Norcal
    2016 White crewmax
    How are these working out? I was debating these vs vled tritons? Have a link to which one? Seen several 7440 on their site.
  27. Jan 20, 2019 at 4:31 AM
    #87
    niscur38
    niscur38 New Member
    Lasfits worked great in my 2019! Looks so much better.
    darkknight2014 likes this.
  28. Jan 20, 2019 at 6:30 AM
    #88
    NickyF25
    NickyF25 New Member
    Nick
    SE Pa
    2017 Platinum 4x4 Silver Sky-Sold
    So you have to take off the whole headlamp to just replace the bulb. The genius engineer that designed that should be tarred and feathered, just plain stupid. I have the 18 LED headlights and was thinking about doing this but don't feel like having to take off grill, panels, and remove headlights just to change a bulb, at least outside in the PA winter.
  29. Jan 20, 2019 at 7:53 AM
    #89
    niscur38
    niscur38 New Member
    Wait...I didn’t take my whole headlight out to change the bulbs! It took like 10 mins tops for both sides!
  30. Jan 20, 2019 at 8:09 AM
    #90
    r1-superstar
    DB
    UTAH
    No you don't. The entire process takes less than 4 min.
