My Front Blinkers Anger Me
Discussion in '2.5 Gen Tundras (2014-2021)' started by Silv333, Jan 12, 2019.
  1. Apr 4, 2020 at 5:40 AM
    #391
    JohnLakeman
    Outside of Weird, TX
    2017 MGM DC TSS 4.6L
    If you're talking about an upgrade to the 2018+ TRD Pro style headlight housings, then keeping the original DRL function of your combined DRL/turn signal amber is optional. @iHacker thread shows how to depin or cut the DRL wire, which leaves turn signal function unchanged. The 2018+ housings have white LED DRL, so the DRL function is no longer required in the turn-signal bulb. Some leave the DRL wire so the the turn-signal bulb still operates with the LED DRL.
    If you're asking if you can have your original style DRL (turn signal bulb) in white and the turn signal in legal amber, the answer is NO, because the bulb is not smart enough to decide when it should be white or amber as needed.
  2. Apr 4, 2020 at 5:54 AM
    #392
    Blazing Blue
    Blazing Blue New Member
    The vled switchbacks are when you use the hdrl controller.
  3. Apr 4, 2020 at 5:59 AM
    #393
    JohnLakeman
    Good information for @MOT3L6 and everyone using vleds. Thanks for the correction.
  4. Apr 4, 2020 at 6:49 AM
    #394
    DjSamthrax
    DjSamthrax Master Certified Toyota Product Specialist
    Minnesota
    2020 TRD Pro Tundra, 8371 Club
    Coachbuilder Pro Kit, 35x12.5 BFG KM3s, Baja S8 hood mounted, Rago Lo-Pro Brackets sitting empty at the moment, Rago Dash Divot Plate, AJT Stuff, LED Lighting throughout, TRD Intake, Bedliner, Tint, Full front PPF, SPS Graphene Coating, and dropped the B out of JBL ;-)
    Put in the JDM ASTAR turn signals in factory 2020 Pro headlight. No hyperflash and holy brightness batman. Best $20 mod imo
    panicman, CCLJ03 and Durania like this.
  5. Apr 4, 2020 at 7:50 AM
    #395
    johnxmccoy
    johnxmccoy New Member
    Grove City, Ohio
    2019 Crew Max
    I just ordered these for my 2019.
  6. Apr 4, 2020 at 10:39 PM
    #396
    Maadcaap
    Maadcaap White Tundys
    Rancho Cucamonga, Ca.
    2019 Trd Pro
    275/70/18 KO2
    7440 or 1260 ?
  7. Apr 9, 2020 at 6:24 AM
    #397
    NuTundra18
    NuTundra18 New Member
    Jimmy
    2020 TRD Pro CM - MGM
    Toyota OEM Hard Flip Tonneau, Predator Steps, Driver Grab Handle, Console Sage, Spray Berliner.
    Has anyone installed the JDM ASTAR LED turn signals in the front turns and add in VLED red 921 rear turn signals? I'm going crazy trying to get all this to work with VLED resistors. I've come to the realization that Tundras in the new models like resistors on all 4 corners to work I just want to make sure that a VLED VLR-6 on each rear turn signal will work with the JDM ASTAR LED front turn signals. Any advice is appreciated.
  8. Apr 9, 2020 at 7:46 AM
    #398
    MOT3L6
    MOT3L6 New Member
    Dustin
    Nebraska
    2015 CM Inferno TRD PRO
    Truck Covers USA American Roll Cover with Yakima Tracks, Nestah Firestick Antenna, Husky Liners X-Act, iHacker harness, 2019 TRD PRO LED Headlights, BD Squadron Fog lights-amber wc
    I just meant if I was going to keep amber drl. i noticed on the vled extreme had this note "Not for use in DRL applications where the high mode is constant." but I didn't notice anything on the triton amber
  9. Apr 9, 2020 at 8:57 AM
    #399
    JohnLakeman
    Since that is a question dealing with vled product limits, I would consult vled tech service directly.
    MOT3L6[QUOTED] likes this.
  10. Apr 9, 2020 at 12:54 PM
    #400
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    I just installed these and they make a huge difference!
    Best $20.00 mod!!!
  11. Apr 10, 2020 at 2:35 AM
    #401
    Maadcaap
    2019 Trd Pro
    275/70/18 KO2
    Witch ones did you buy?
  12. Apr 10, 2020 at 4:33 AM
    #402
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    JDM ASTAR I cannot believe the difference. Plug and Play
  13. Apr 10, 2020 at 5:44 AM
    #403
    JohnLakeman
    Just to be clear, no aftermarket LED is plug and play for ALL Gen3 Tundra models.
    From what I've read here, aftermarket LEDs work without resistors only in the front for 2018+?. Some have "theorized" the resistance is built into certain aftermarket LEDs so resistors are not required. That is incorrect, there is no resistance built in. The user just got lucky that his Tundra's brain doesn't need additional resistance for the fronts to function properly with LED bulbs (no hyper-flash).
    When that 2018+ owner decides to convert the rears, then they have problems and are forced to add resistance to the circuit. The rears have always been incandescent. Correct resistance only needs to added at one location in the circuit, not necessarily at all four corners. The vleds I shopped had a proprietary resistor and harness for each location. They are very high quality, but the vled resistors are going to be required at every corner for 2017 and earlier, and you're going to pay much more.
  14. Apr 10, 2020 at 5:53 AM
    #404
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    Well, when I plugged them into the fronts, they played. I didn't add anything for the back.
    Works for my needs with no issues. Thanks for your concerns.
    rebmo likes this.
  15. Apr 10, 2020 at 6:00 AM
    #405
    NuTundra18
    Jimmy
    That has been my conclusion also. I have the JDM Astars up front and I’m about to add the Vled 921 and VLR-6 resistor in each rear, just trying to find out if the VLR-6 is enough resistance with JDM bulbs up front and was wanting confirmation from someone that did it. Thx
  16. Apr 10, 2020 at 6:05 AM
    #406
    JohnLakeman
    Not concerned, and I'm happy they worked for you. Now, if you later decide to convert your rears, and experience hyperflash, maybe you'll remember this conversation. For 2018+, with no hyperflash for LEDs in the fronts, a single 6 ohm, 50W resistor in the rear on each side is likely the solution. You're not thinking about it now, but maybe later...
    My purpose was to keep those with earlier trucks from thinking JDMAstars will plug and play, then question why they have hyperflash when using a combination of JDMAstars and vleds.
    New2Tundra, panicman and Boerseun like this.
  17. Apr 10, 2020 at 6:09 AM
    #407
    JohnLakeman
    Just curious...Why use JDMAstars in the front and vleds in the rear? If you're willing to take a chance on cheap aftermarket LEDs in the front, why would you spring for high-dollar LEDs in the rear? Are you using vleds with the proprietary resistor?
  18. Apr 10, 2020 at 6:22 AM
    #408
    NuTundra18
    Jimmy
    I would be doing that. I tried both versions of the front VLEDS with T-Adapter resistor kit so I didn’t have to splice and it did not fix the rear like it does on 2017 models and older. I just gave up and sent everything back and just put in the JDMs up front. I’m finally making progress and have come to the conclusion that the tears each need a resistor regardless what’s up front. I have to either bite the bullet and crimp the wires with vled kit or wait until June when they advised me they are releasing a PNP 921 kit with resistor. I may go back with VLEDs up front once I order up the tears. No doubt they have awesome quality stuff.
  19. Apr 10, 2020 at 6:34 AM
    #409
    JohnLakeman
    I reread your post, and was preparing a reply. For a 2020, you probably did not need a resistor for only the fronts. Adding additional resistance with the vled resistor is what messed things up for you, causing you to send it all back.
    With the JDMAstars up front, you can convert the rears either with another aftermarket LED like the Nakobo I used (bottom of the page), and by adding a generic "China Queen" 6 ohm resister at the rear. OR, you can use the vled with their proprietary 6 ohm resistor. Results will be the same. Quality may be higher with the vled, but the cost will definitely be higher.
    Edit: @NuTundra18 Looks like that Amazon link for the Nakobo LED is defunct. Do an Amazon search for LED 915/921, you'll have to select from whats available comparing watt rating.
  20. Apr 10, 2020 at 6:42 AM
    #410
    NuTundra18
    Jimmy
    Ok thank you so much, I appreciate the feedback and help.
  21. Apr 10, 2020 at 9:19 AM
    #411
    Maadcaap
    2019 Trd Pro
    275/70/18 KO2
    Which size.. 7440 or 1260..
  22. Apr 10, 2020 at 9:33 AM
    #412
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    7440
  23. Apr 10, 2020 at 9:35 AM
    #413
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    I should of said thanks for the feedback. I didn't mean to be cocky or anything like that.
    I apologize.
    JohnLakeman[QUOTED] likes this.
  24. Apr 13, 2020 at 7:22 AM
    #414
    trucksareforgirls2
    trucksareforgirls2 New Member
    Northeast USA
    2020 Voodoo Blue TRD Off-Road
    Some blinker fluid may fix that...
    -T
  25. Apr 20, 2020 at 11:12 AM
    #415
    Tag520
    Tag520 New Member
    CT
    '20 Army Green Tundra Trd Pro
    So JDMAstars work for front blinkers of a '20? I'm not interested in the back right now. Amazon says they do not fit my '20. Just want to confirm before buying
  26. Apr 20, 2020 at 11:15 AM
    #416
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    They worked for me.
  27. Apr 20, 2020 at 11:28 AM
    #417
    Tag520
    Tag520 New Member
    CT
    you have a '19...did Amazon claim it didn't fit your lights either?
  28. Apr 20, 2020 at 11:40 AM
    #418
    johnxmccoy
    Grove City, Ohio
    2019 Crew Max
    That's correct.
    Tag520[QUOTED] likes this.
  29. Apr 20, 2020 at 11:57 AM
    #419
    TWJLee
    TWJLee No Thanks
    J
    Midwest
    2020 Limited DC TRad OR 2020 F150 5.0 single cb 2001 Tacoma 4x4 2.7 5spd AC cab
    GFC Borla XS Ceramic Tint 2” lift on Fox 2.0 -aal- Methods on 33
    I put them on my 20 and its fine- took them off my ‘19 before trading
  30. Apr 20, 2020 at 4:11 PM
    #420
    Tag520
    Tag520 New Member
    CT
    ty guys...just ordered them
