My experience with largest tires on stock trd pro setup
Discussion in '2.5 Gen TRD Pro (2014-2021)' started by mallard75, Feb 19, 2017.
  1. Mar 3, 2022 at 8:06 AM
    drdriller
    drdriller New Member
    So, can you run 305/65 r18 on stock trd pro wheels and setup with no rub?
  2. Mar 3, 2022 at 8:26 AM
    PermaFrostTRD
    Northern NY
    Probably not - it depends on the actual tire dimension (not just the nominal one). Also tire pressure, alignment, etc. More than likely you will rub on either the UCA or front sway bar.
    Real world example: I run a 295/70/r18 Mickey Baja Boss AT. It's a very wide tire for its size/specs (also a heavy one but that's not important here). Spec sheet says 11.7" width but I bet it's almost 12". I rub slightly on the front sway bar at full lock.
    bulldog93 likes this.
  3. Mar 3, 2022 at 9:36 AM
    The Towse Tundra 2.0
    The Towse Tundra 2.0 New Member
    Loy
    2021 Lunar Rock Tundra TRD Pro Crewmax
    TRD Inlay Package, Spray-in Bedliner, Cargo LED Light, Power Tailgate Lock, Center Console Safe, MX4 Bakflip Tonneau Cover, CaliRaised LED Rock Sliders, Nitto Ridge Grapplers 275/70/18, Rigid Industries Amber Fog Light Covers, Coachbuilder TRD Pro lift kit
    275/70/18 Nitto Ridge Grapplers on my 2021 Pro. Never had an issue with rubbing. People forget that when you increase tire size you lose some of the travel in the suspension. Bigger is not always better. My tires are the same width as stock but are a 1/2” taller. It’s as close to stock as I can get without compromising the suspension.
  4. Mar 3, 2022 at 11:00 AM
    zasdds
    zasdds New Member
    2021 Platinum Crewmax
    Do you run wheel spacers? I just ordered these tires for me 2021 Platinum that I will pairing with Toytec 2.0 Boss Lift. Wondering how significant a rub at the sway bar is. Will be running the TRD sway bar up front as well, not sure if the dimensions on that are different.
  5. Mar 3, 2022 at 1:11 PM
    PermaFrostTRD
    Northern NY
    No spacers. I have a TRD OffRoad, unsure if there's a different dimension aspect to it. I forgot to mention I'm running Fox 2.0 adjustable coilovers set at 2" of lift up front too.
    zasdds[QUOTED] likes this.
  6. Mar 11, 2022 at 7:54 AM
    bstringrandy
    bstringrandy New Member
    Randy
    Middleburg, FL
    2021 Tundra TRD Pro
    I’m running Nitto Ridge Grapplers 285/70/R18s on my stock TRD Pro. No rubs whatsoever!
  7. Mar 11, 2022 at 2:51 PM
    RusPro21
    RusPro21 Pro is gone! But I’m still here.
    Don
    Pa.
    2021 Pro!! Nitto’s Tyger blades, Arc audio!
    I’m running the same and no rub issues. But I’m keeping same size tire and adding the westcott lift. Maybe down the road I will go bigger but for now they will do. Looks good!!
    bstringrandy[QUOTED] likes this.
  8. Mar 11, 2022 at 3:14 PM
    woofhauler
    woofhauler New Member
    Pacifica, CA
    285/75R18 285 width (about 11.2) and 35 inches. No rub at all at full lock or flex
  9. Jun 9, 2022 at 6:27 AM
    Sierra_Nevada
    Sierra_Nevada New Member
    Kansas City
    2020 Magnetic Gray Platinum
    TRD Pro Fox Suspension, SCS Ray 10 Wheels, BFG KO2 275/70 R18
    How much ride difference did you notice between these and the stock tires on paved roads? Are these a lot rougher? I just bought the FOX suspension and 18 inch wheels for my Platinum because it rides like a brick with my current setup. I'm in the market for tires now, but want to avoid anything that severely degrades the ride quality. Thank you.
  10. Jun 9, 2022 at 11:08 AM
    ncomeau35
    ncomeau35 New Member
    North of Boston
    2019 White Toyota Tundra TRD PRO
    Nitro Ridge Grappler 285/75/18
    I truly love these tires! My initial thought was they would be loud on the highway, but to my surprise, they are not. The fox suspension makes the ride quality of the truck so nice!!! If you go with the same set up i did, Nitro ridge grappler 285/75/18 you will need to remove the front spats (small plastic pieces attached to the bumper) as they will rub in reverse, but after removing, no more rub!! The tire set up makes the truck stance look so much better, and way more aggressive/beefy!!! I get loads of compliments!!
    bulldog93 and Sierra_Nevada like this.
