My cats got stolen last night
Discussion in '2.5 Gen Tundras (2014-2021)' started by Muleycrazy13, May 22, 2021.
  1. May 26, 2021 at 12:18 PM
    #121
    Pics of 4wd vs 2wd with the rear plate. 3rd pic is the 2wd obviously. I'm going to play with a couple of ideas on mine for protection on the 2wd models.BC704F36-77B8-4682-8B18-7427AC3266B6.jpg 48FC67C6-B21A-4051-9949-090B2A8459F8.jpg 9C69D1D3-2B09-4AE9-B989-2D9985269D9B.jpg
    Mike59 and yoshi82 like this.
  2. May 26, 2021 at 12:23 PM
    #122
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    My post on another thread.
  3. May 26, 2021 at 12:38 PM
    #123
    BiggHertz
    BiggHertz DZTLIMO
    Chandler, AZ
    IG: dztlimo
    Stuff and Things
    Additional shots for rear cat coverage.
    -JS
    Tundrastruck91 likes this.
  4. May 26, 2021 at 6:44 PM
    #124
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    I don’t really want to wait for one. I did some measuring tonight. Called some metal distributors. A 4x4 sheet of 1/8 inch steel is $165. My plywood template is way less than that. Ratio math says under $100. I know....I know....engineers.
    Tundra14Platinum and equin like this.
  5. May 27, 2021 at 4:11 PM
    #125
    Muleycrazy13
    Muleycrazy13 [OP] New Member
    Buckeye, AZ
    2024 Chevy Silverado 2500HD Duramax
    Got my truck back yesterday everything is good and happy to report no issues. I am going to order a plate from Tyler just trying to decide between steel and aluminum? Any thoughts ??? I live in Az so salt isn’t a concern
  6. May 27, 2021 at 4:22 PM
    #126
    OnespeedTRD
    OnespeedTRD New Member
    Don
    San Diego
    2020 Tundra Limited TRD Off-Road
    275/70r18 Cooper AT3 XLT on SCS Ray 10s, Eibach Coilovers, DD 12" Exhaust, AJT Blackout Kit, Truxedo Pro X15, paint match/chrome delete.
    Depends on your needs and how you use the truck.
    Aluminum = a little pricier but lighter and no rust (and they look sweet all polished up). Not as durable overall if you plan to bash on them.
    Steel = cheaper but much heavier, can rust if not coated. More durable, steel slides better over rocks than aluminum.
    Here's Tyler's plates in polished aluminum:
    equin likes this.
  7. May 27, 2021 at 4:26 PM
    #127
    Muleycrazy13
    Buckeye, AZ
    Thanks for the info. Did you get 3/16 or 1/4” ?
  8. May 27, 2021 at 4:28 PM
    #128
    OnespeedTRD
    Don
    San Diego
    1/4". A little polish and a buffer and they shine up pretty nice.
  9. May 27, 2021 at 4:31 PM
    #129
    Rocko9999
    Rocko9999 New Member
    Do these plates trap heat and have any ill effects?
  10. May 27, 2021 at 4:44 PM
    #130
    OnespeedTRD
    Don
    San Diego
    I haven't noticed anything like that. In the other big thread about these plates someone took temps before and after and didn't notice a difference. Seems to be plenty of airflow through there, along with the little holes in the plate.
  11. May 27, 2021 at 4:50 PM
    #131
    Professional Hand Model
    Hand Protectors
    I’d run a short length of Chain Link Fence from frame to frame. SawZall Blade would be bouncing and snagging on each link in any attempt to cut leading to frustration. Light weight and cheap and readily available. Bolt up with washers and self tappers.
  12. May 27, 2021 at 4:52 PM
    #132
    OnespeedTRD
    Don
    San Diego
    Sounds reasonable. You go first and let us know how it turns out. We'll need pics as well.
    sensei likes this.
  13. May 27, 2021 at 4:56 PM
    #133
    Tundrastruck91
    Tundrastruck91 New Member
    2024 TRD Pro Terra Tundra
    Sad what we need to do
    Problem is every self respecting thief always has a pair of these ...
    Kobalt 8-in Bolt Cutters in the Bolt Cutters department at Lowes.com
    GODZILLA and Muleycrazy13[OP] like this.
  14. May 27, 2021 at 5:09 PM
    #134
    2mchfun
    Zero deductible on comprehensive and roll the dice. Odds are good it won't happen to you.
    Melikeymy beer likes this.
  15. May 27, 2021 at 5:13 PM
    #135
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    I crawled under my truck with the wooden template I constructed last night to check the fit. Was darn near perfect. When I draw the plans up I will add a 2 inch lip on the sides and front notch. I am thinking of getting it made out of perforated plate. Plenty of air flow and with any luck won’t have to locate the holes for bolts. If anyone wants the plans shoot me a message. There are places that will cut your plate pattern all over. I searched and found one in Houston a few miles from me. THe 4x4 sheet of 1/8 steel was like $165 and 3/16 aluminum was $212. They cut to fit so the price of the sheet you have cut should be significantly less.
    equin likes this.
  16. May 27, 2021 at 5:17 PM
    #136
    They do not. I took temps when I put mine on...no issues at all.
    Rocko9999[QUOTED] likes this.
  17. May 27, 2021 at 5:19 PM
    #137
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    Only problem with this is an insurance claim. Nothing is free. When your policy renews they will start getting theirs back. I have learned from bad experience that you don’t call the insurance unless you have to. Better to pay what you can out of pocket (to some extent).
    Luckydog likes this.
  18. May 27, 2021 at 5:20 PM
    #138
    I have steel on mine. These trucks are so powerful that it doesn't notice the weight. It didn't even notice when I added 300 lbs in bumper weight. It's different than adding tire weight.
    2mchfun likes this.
  19. May 27, 2021 at 5:52 PM
    #139
    2mchfun
    If I can afford to pay 45 grand for the truck, all the gas it drinks, and I can buy expensive flimsy skids, then chances are I can afford insurance.
    AggiePhil and Hbjeff like this.
  20. May 27, 2021 at 6:00 PM
    #140
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    Chances are......great thing about America. You can give YOUR money to whoever YOU want to.
    2mchfun[QUOTED] likes this.
  21. May 27, 2021 at 6:10 PM
    #141
    2mchfun
    When everyone has skids then they will probably just start stealing those and selling them used to the same people.
  22. May 27, 2021 at 6:41 PM
    #142
    OnespeedTRD
    Don
    San Diego
    Dan, you sure do provide a different perspective on things. Not always helpful or relevant, but certainly different
    BGoodiE and Tundra234 like this.
  23. May 27, 2021 at 6:42 PM
    #143
    kbark likes this.
  24. May 27, 2021 at 7:20 PM
    #144
    2mchfun
    Just a different way to say thieves have been around since the beginning of time, and they will not be going anywhere. Protect your cat conv. then they might just drag the saw blade down the side of your paint because you rained on their parade. Maybe not helpful, just another thought. Personally, my sliders are going to have a couple of cross members that connect both sides to each other, one being behind the transfer case and one under the oil pan. It will be really easy to add an expanded metal shield to each of them. So, for $300 I will have both HD sliders and cat conv. anti theft devices.
  25. May 27, 2021 at 8:50 PM
    #145
    tundras00
    tundras00 New Member
    Try 2 months and 2 weeks for me. Just got mine back 2 days ago after sitting at the dealer. I installed Tyler's plates the very same day.
  26. May 27, 2021 at 9:00 PM
    #146
    tundras00
    I would say if he somehow wasn't so lacking in communication I would have had my plates a week before the cats were stolen. I was playing tag with him for awhile and when he answered he would say he would contact me. 2-3 weeks later he did, but I had already given my money to Tyler whom was clear on ETA.
    AggiePhil likes this.
  27. May 28, 2021 at 5:57 AM
    #147
    Mad Max
    Mad Max New Member
    Max
    2021 Tundra Limited
    Your like me. spend 100 hours, to find out you saved $50 and still not as perfect as the guy who sales them by the 100's. Both plates (front and back) from Valhella uncoated (like yours will be when your done cutting them out) ready to bolt on with fasteners are $4?? pick up. He is in Houston also. At max you will save $100 and run around waiting for the material, waiting for the plasma or water jet cutter. Just spent 50 hrs building a drop axle for a jet ski trailer, have about $120 into it. metal all over place, guess should have bought one for $89......................
    AggiePhil and Rocko9999 like this.
  28. May 28, 2021 at 6:01 AM
    #148
    2mchfun
    Sometimes it's about the journey. The lessons learned, the blood, the sweat, the tears. I happen to like Journey too, Hey Alexa...
    BGoodiE and Kbar691 like this.
  29. May 28, 2021 at 7:07 AM
    #149
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    You nailed it. In the end, it isn’t about saving the money....because you aren’t saving a lot. I like a project. Same reason I chose to rip the dash out and remove the chrome and silver. Other things....I totally rebuilt a bad boy buggy that was ruined in Harvey a few years back. Most recently I bought a big jon boat and refurbished it. Added removable seats and removable platforms so I can leave it outdoors and it won’t rot. Fun project for sure! Next I am busting out tile in my house and installing wood floors. I have roofed houses. I have built outside buildings. Lots of stuff. I know so many people that can’t do any of these things. Well....they call me when they need help. Another benefit is I can pass these to my son as well.
    2mchfun likes this.
  30. May 28, 2021 at 7:09 AM
    #150
    AL_TUNDY
    AL_TUNDY New Member
    The Land of Nye
    2005 Tundra
    Cat theft deterrent before it was a "thing"
