My best MOD so far....Sound system.
Discussion in 'Audio & Video' started by BTBAKER, Feb 6, 2018.
  1. Apr 20, 2018 at 11:37 AM
    #61
    louscrw
    louscrw all jacked up on Mt. Dew
    Lou
    Warner Robins, Ga
    2023 F150 Raptor
    I like them. The tweeters of the front components are mounted in the factory dash location. The front center channel is disconnected. I think they’re pretty damn clear, but I’m sure there are audiophiles out there that would disagree. They’re not terribly cheap, but nowhere near expensive in my opinion. The subs are awesome. The JL tw3 are a great shallow mount subwoofer.
    Watt maker likes this.
  2. Apr 20, 2018 at 11:54 AM
    #62
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Good deal. Thank you
  3. Apr 20, 2018 at 1:55 PM
    #63
    smooosh
    smooosh This place costs me too much $
    2018 TRD Offroad Limited Crewmax.
    Ongoing project
    No unfortunately. You would have to change out the head unit and amp and run wires/splice into existing speaker wires. with JBL the amp/head unit work together.
  4. Sep 12, 2018 at 9:42 PM
    #64
    bamelanc
    bamelanc New Member
    Orange, Texas
    2018 Magnetic Grey Platinum 4x4
    Addictive Desert Designs Stealth Fighter bumper w/ 40" Baja Designs Onyx6 arced dual control combo light bar and Smittybuilt X20 Comp 10k winch. Baja Designs S8 10" amber fog lights. sPod Control for lighting and compressor. ICON Stage 3 Suspension with tubular UCA set at 3". ICON Alloys Six Speed 17" machined/satin black wrapped in 285/75/17 Nitto Ridge Grapplers. TRD Performance Intake. TRD Cat Back Exhaust. LED Kit inside and out. ARB onboard compressor. Amp Research Power Step w/LED kit. Retrax XR Pro bedcover. Armadillo Bed Liner. Tint - 35/5/5 ceramic. Center Console Safe. Weather tech mats.
    Is there any way to access vehicle customization if you remove the factory HU? Door Lock Settings, Lights Settings, Other Vehicle Settings. These are the only things I could see that I may not be able to access when removing the factory HU. Also, does anyone know if the factory HU will play FLAC files?
  5. Sep 12, 2018 at 10:34 PM
    #65
    blizz86
    blizz86 New Member
    Which focals did you use?
  6. Oct 31, 2019 at 10:58 AM
    #66
    thetaxguy
    thetaxguy New Member
    2019 White SR5 CM TRD OR
  7. Nov 1, 2019 at 7:37 AM
    #67
    ScooterInNV
    ScooterInNV New Member
    Robert
    San Antonio, TX
    2019 VooDoo Blue TRD Pro
    Lift, AMP steps
    Which one did you go with? Have a link?
