My 2019 5.7 non-flex fuel takes a extra crank or two to start?
Discussion in '2.5 Gen Tundras (2014-2021)' started by IowaGuy, Sep 27, 2022.
  1. Sep 27, 2022 at 11:25 PM
    IowaGuy
    IowaGuy [OP] New Member
    Arizona by way of Iowa
    2019 SR5 upgrade MGM
    In Process
    Lately I have noticed that my 2019 truck with 62k miles seems to crank just a bit longer to start. It used to snap right off but now there is ever so slight of a delay every time. I use ethanol free "blue gas" in it and just changed the oil and put a new air filter in 600 miles ago. Any reason for concern or justhe truck showing its age and being a truck, anything to check or reset? I am in AZ and the battery is @ 3 yrs old. Oh, I am down to just below a 1/4 tank of fuel if that could have anything to do with it.
  2. Sep 27, 2022 at 11:52 PM
    Fourknights
    Fourknights Goin Coastal
    Georgia/Florida
    2019 sr double cab 4x4 5.7
    Coverking ballistic seat covers, dipped 4x4 emblem, intermittent wiper mod, Toyota bed mat, Toyota rear under seat storage, dirty deeds budget, icon rebound 17”, bfg ko2s 285/70/17, matte black uws low profile toolbox, grill surround painted matte black
    Was it a candidate for fuel pump recall?
  3. Sep 28, 2022 at 12:43 AM
    18" TRD Off Road Wheels
    Stock batteries are known to be crap. I'd start there. If you're feeling frisky, maybe swap the spark plugs out.
  4. Sep 28, 2022 at 6:29 AM
    IowaGuy
    In Process
    IDK? I am not aware of a recall or issues there. More info?
  5. Sep 28, 2022 at 7:01 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Check fuel pump recall, battery and clean maf
  6. Sep 28, 2022 at 7:12 AM
    IowaGuy
    In Process
    I looked up the fuel pump recall and any recal info from my VIN and it says my headlight wiring harness is the only one pending. (I am going to replace them with LED lights)
  7. Sep 28, 2022 at 7:38 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    go auto zone borrow a battery tester and see how many cca you still have on the battery, if you want the tip top performance you could change spark plugs too
    Edit, idk bout ur truck, but my spark plug gap was way off from factory
  8. Oct 4, 2022 at 6:40 AM
    4fingercarpenter
    4fingercarpenter New Member
    Ryan
    Tampa
    2020 Cavalry Blue Tundra
    Exhaust AFE modified intake BDS 8 inch lift Ironman 4x4 880lbs upgraded leaf spring 37x12.5x20 -24 D3 tune
    I had the same issue with my 2011, everything was either new or was in good shape. Upon further inspection and a 6 pack I noticed my grounding points in engine bay weren't looking the best, took them off lightly sanded them and where they touch the body and long start went away.
    IowaGuy[OP] likes this.
  9. Oct 4, 2022 at 11:24 AM
    Jaypown
    Jaypown New Member
    Justin
    Rubber City
    Battery
  10. Oct 4, 2022 at 12:09 PM
    IowaGuy
    In Process
    Is there a list or resource where I can find the grounds.
    Edit, are these locations correct?
    The battery to the internal fender
    The battery to the block of the engine
    Behind the mount of the motor and the engine rear to firewall
  11. Oct 4, 2022 at 1:02 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Don’t even needed, just add a 0 gauge wire from cab to frame, and frame to battery
