My 2001 TRD Access Cab Repair/Modify Thread
Discussion in '1st Gen Tundras (2000-2006)' started by N84434, Jul 27, 2020.
  1. Sep 8, 2021 at 3:43 PM
    #241
    N84434
    N84434 [OP] In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I do have that usb/OBD II cable, which is pretty much useless to me now…;)
  2. Sep 8, 2021 at 3:49 PM
    #242
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    1.4.1 or 2.0.4 firmware ?
  3. Sep 8, 2021 at 3:52 PM
    #243
    N84434
    Milwaukee WI.
    2001 Limited TRD
    that is a fantastic question…
    I’ll have to put the disc in and see what’s on it. I really don’t know. I can tell you I’ve had this copy of TIS and the cable for 10 or 11 years, so it may be the earlier version?
  4. Sep 8, 2021 at 3:59 PM
    #244
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    When/if you get a chance to check and if your PC is XP, there should be a file on the disk named "checking firmware.exe" that will tell you firmware version you have. I mention XP because that exe file will not run on Win 10 64bit. If it's 2.0.4, you might be surprised of those that might buy it from you OR get you another copy from someone(hint,hint) and have Techstream as a backup scantool ?
  5. Sep 8, 2021 at 4:01 PM
    #245
    N84434
    Milwaukee WI.
    2001 Limited TRD
    I know it’s a windows 7 machine.
  6. Sep 8, 2021 at 5:45 PM
    #246
    shifty` Oh, I have felt Cobain's sarcoma
    Understood guys. Thanks for the input. It looks like there's a virtual/hypervisor version of Techstream out there, easy enough to block a VM from getting internet; just remove the network adapter from the VM :)
    But yeah, looks like the mini VCI cables have gone up in price. Significantly.
  7. Sep 11, 2021 at 10:10 AM
    #247
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Bubba;
    I just went through the software that I have for the TIS program and the cable, and I don't see any info regarding which version it is. I have to assume it's going to be the earlier version.
    BubbaW[QUOTED] likes this.
  8. Sep 11, 2021 at 2:19 PM
    #248
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Well, I replaced the front ABS sensors and that took care of the ABS light, but still no speedometer or odometer.
    I isolated the pertinent sensors for speed, and it appears there are 2 speed sensors that the ECU uses. I'm getting a signal from the SP 2 sensor (accurate with the GPS on my phone) but nothing from the other sensor. That NC0 speed sensor must be on the input shaft for the transmission. It pretty much follows the engine RPM up until 2000 rpm, then it shows no signal. I'm assuming that's normal.
    At this point, I'm going to clean the connectors for each speed sensor on the trans and we'll see what happens.
    I just have to figure out which sensor is the one not working....
    bmf4069 and Lil Steve like this.
  9. Oct 17, 2021 at 6:25 PM
    #249
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Time for a fall update... Truck has been running great for a while now. I was running errands last week and while on the freeway, I noticed my speed jumped up to 110!
    So, I figured the speed sensor finally took a dump. I ordered a new one, and installed it...
    Then quickly realized the speed was off by about 10 mph. Woops..
    I had to swap the drive gear from the old sensor to the new one, to correct the speed, and that fixed it!
    Not sure why the gears were different, as the replacement sensor was the correct application, but the replacement's gear was maybe 1/8 inch taller than the original, so the gears didn't mesh at all. After pressing the old gear onto the new sensor, I was back in business...
    Love this truck!
  10. Oct 17, 2021 at 6:32 PM
    #250
    N84434
    Milwaukee WI.
    2001 Limited TRD
    One more thing.... I've been fighting the ABS pump running at speeds below 5 mph and finally realized my left front wheel sensor wasn't registering speeds that slowly. So, after replacing the LF wheel speed sensor, no more buzzing ABS pump while coming to a stop... Super happy I'm getting all the minor bugs worked out.
    Tundra2, des2mtn and steved0xTD like this.
  11. Oct 17, 2021 at 7:05 PM
    #251
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    Did you go OEM or aftermarket on the sensor?
  12. Oct 17, 2021 at 8:00 PM
    #252
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Aftermarket unit from Rockauto.
  13. Oct 17, 2021 at 9:34 PM
    #253
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    shit i forgot i need to dig out the OEM sensors and see if i have one that fits your truck...
    Tundra2 likes this.
  14. Oct 18, 2021 at 1:23 PM
    #254
    dathornt
    dathornt New Member
    2004 Tundra
    fairly stock
    having the same issue and am curious how you determined it was the front left?
    N84434[OP] likes this.
  15. Oct 18, 2021 at 2:43 PM
    #255
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Hi Dat..
    My Autel MK808 can read each of the 4 wheel speed sensors individually, and at low speeds, the left front was reading 0 mph. Initially, I didn't think that was a problem, but I woke up one night and had an epiphany!
    If you replace the sensor, it will work correctly....
    so, I did and it does..
    Hope that all makes sense
    Lil Steve and bmf4069 like this.
  16. Oct 19, 2021 at 5:33 AM
    #256
    dathornt
    dathornt New Member
    2004 Tundra
    fairly stock
    appreciate your response. I should purchase one of those. I have a 2004 Tundra and I have been trying to find a method that would isolate the bad sensor rather than replacing the sensors blindly. I believe it is the front left but hard to say. Again, thank you.
  17. Oct 19, 2021 at 5:45 AM
    #257
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Autel makes a good product. It was just shy of 500 bucks, but it does a boatload of reading/resetting/testing. More than I wanted to spend, but well worth it...
  18. Oct 19, 2021 at 11:25 AM
    #258
    Lil Steve
    Lil Steve Living the dream
    Gilbert, AZ
    2002 Tundra SR5 Access Cab 2WD V8
    You're making it really difficult for me to resist buying another tool I don't need, but want. I have it in my rainforest wish list, ready to pounce at the first sign of weakness. But first, I must go out and get the new DeWalt DCF913B, because, well, I think I need it. :rofl:
    Tundra2 and N84434[QUOTED][OP] like this.
  19. Oct 19, 2021 at 1:36 PM
    #259
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Hey, put it on the 6 month plan interest free! Something like 85 bucks a month!
    Or do like I did and tell your wife it was cheaper to spend the money than taking to a shop..:spending:
    Tundra2 likes this.
  20. Oct 19, 2021 at 4:14 PM
    #260
    Lil Steve
    Gilbert, AZ
    Solid plan. But first things first. Keeping it Tundra related as well!
    N84434[QUOTED][OP] likes this.
  21. Oct 19, 2021 at 4:50 PM
    #261
    Yeah, looks like other less-costly solutions are a bit bulky, or so I found out this last weekend. Got the whole Techstream thing to work w/o issued but man that's a lot to lug around. Kinda makes things like that Autel look like it could totally be worth the coin.
  22. Jan 2, 2022 at 1:25 PM
    #262
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Time for a mid winter/ start of the new year update...
    I hit 180,000 miles yesterday on the way home from work. No fanfare, it just kept chugging along.
    With my kitchen remodel project taking up most of 2021, the body work that I wanted to take care of took a back seat, so my plan for this year is to get back on the truck.
    I probably put less than 500 miles a month on it, since my Volt is the primary commuter car I use. So, at this rate, I don't think I'll ever see 200K...
    But, hey, that way it'll last well into retirement!
    One thing I've noticed is the amount of road noise coming from around the left rear door when I'm on the freeway. Not sure if that's normal or not..
  23. Jul 17, 2022 at 8:21 PM
    #263
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Finally had some time to sit down and update this thread. I had a failure in the right rear body mount, so I ordered a replacement and after waiting a couple weeks for the part, it finally showed up.
    While I was waiting for the part, I took the opportunity to remove the old, rusted mount.
    I had to use a 90 degree grinder to get the rusted hardware out, and finally got the old mount out.
    Next step was to clean up,the existing mount surface
    After cleaning up and painting the surface for the new mount, the new one went in..
    After getting the mounts installed, I wrapped the mirror caps with a chrome wrap, because the clear and paint was pretty rough on both mirrors.
    The body side moulding was all lined up again after the new mount was installed.
    The last thing I wanted to do was to get the 05-06 grill installed, which meant trimming the front facia between the headlights.
    The grill mounted perfectly inplace of the original, except for the trimming of the facia.
    This being said, I think I'll be putting the truck up for sale soon. I'd like to move in a different direction. I've been eyeing Porsche Cayman's for a while, and once the truck sells, I think I'll be hunting for one. I miss having a sports car. The last one I had was my 300ZX 10 years ago. I'm not sure what to ask for it yet. It's got some value, but I'll have to be realistic.
  24. Jul 17, 2022 at 8:32 PM
    #264
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    I’ve been looking at Caymans the last 6 months, so many Boxers so few Caymans. I’ve had an itch for one as well for a while, just can’t stomach this current market.
  25. Jul 18, 2022 at 4:51 AM
    #265
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    I love how you make replacing the body mount seem so easy. Did you have to loosen the front mount to jack it at least 3 inches and get the new one in there? What jack point did you use?
  26. Jul 18, 2022 at 6:23 AM
    #266
    Sad to hear! I saw this on Porsche recently. https://www.reddit.com/r/Justrolledintotheshop/comments/w1fan6/guess_where_the_starter_is/
    That was enough to make me want to avoid anything new they're selling like the plague. To change the starter, you've got to drop the entire drivetrain out of the car, separate the transmission, then flywheel, and finally you have access to the starter. 24-27 hours labor for a professional mechanic, supposedly.
    This seems to be the norm with German cars starting in the early 2000s, I can't do it anymore.
    I saw on national news yesterday, there's an expectation the used car market is about to be flooded due to a massive spike in repossessions, expect prices to fall.
    Just avoid anything that was assembled after mid-2020. Every manufacturer (Toyota inclusive) is seeing a larger than usual spike in quality control, recall issues.
    Meanwhile, on the Cayman topic, tidbits of advice from others that's dated, but valid with almost any German car, although these were specifically targeted at Caymans.
    Filthyphil[QUOTED] likes this.
  27. Jul 18, 2022 at 10:19 AM
    #267
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Yeah, I forgot to mention that.... I did pull the bolt out from the forward mount. I used a piece of 4X4 wood and simply jacked up the cab using a flat area under the body. Worked perfectly. I was able to get the new mount in with no problem.
  28. Jul 18, 2022 at 10:28 AM
    #268
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Some good points here... As is evident from this thread, I do my own work, so I won't have to budget for every shop visit. I'll be looking at cars from 2009-2010 in the 30K range, not terribly expensive.
    I haven't looked, but I wonder how often the starter fails on a 987? I haven't seen it listed as a common problem area for the car..?
    As we all know, Toyota starters have scared a good number of people away, but how often do they actually fail?
    Nothings set in stone yet.. I also like the 370Z.
  29. Jul 18, 2022 at 10:56 AM
    #269
    I've still never owned a Nissan, but drove my ex-g/f 240SX and that thing was a blast. everything else I've driven or ridden in felt way too plasticky for my taste.
    You bring up a good point about the 987 starter. I think that case is probably a byproduct of the pandemic labor/parts shortages. A lot of things got rushed to market w/o proper QC just because the demand was so high, manufacturers wanted to get things on the road, even if not perfect. It's not dissimilar from what video game houses are doing with games this day, rushing to market when the game won't even run until you download patches for an hour, then install them.
    If you're sticking in the late 00's / early 10's I don't think this will be a problem for you, though. I mean, the serviceability on German cars will always be what it is: Labor that's best done by the dealership, requires specialized tools in many cases, and fixing one thing leads to needing to do adjacent repairs like replacing an oil-related gasket on a crankcase just because you changed the alternator, or needing to reprogram the ECM because you changed the battery (just went thru that on my neighbor's 2011 BMW x5).
    I think by the time 2007 hit, the automobile world changed. radically. There's a reason I have an '06. It has just enough features, but it didn't quite jump the shark yet. Shy of the starter being where it is, this truck has been exceptionally serviceable.
    If I could pick up anything in that arena, I'd probably get another MKIV generation VW or Audi of the same general year, maybe a pre-2005 Porsche. Once you replace all the rubber and plastic tubes in the VW/Audi at least, they tend to be pretty solid and not too much of a PITA to work on. Endless supply of parts too.
  30. Jul 19, 2022 at 2:05 PM
    #270
    DesertRoads
    DesertRoads Telecom Guy
    Utah's West Desert
    2005 DC SR5 V8 4WD LSD & TOW PKG
    LED Lights Galore. Mostly Stock
    Really nice build/refurbish on your Tundra! You've done a great job replacing, and fixing your truck to the way you want it. I have always had issue owning a vehicle that's been abused, so I've always done the best I could to refurbish it the best way I know how. Even with all the work you've put into it, it's still significantly cheaper than a brand new Tundra. I was on the fence on wanting a 1st or second gen Tundra, but given the smaller mid-sized feel of the first gen, that's what I wanted to go with. I looked at the current body style Tacoma's, and the first gen Tundra still offers more elbow room, and of course a V8. Once again, great work on your rebuild!
