My 2001 TRD Access Cab Repair/Modify Thread
Discussion in '1st Gen Tundras (2000-2006)' started by N84434, Jul 27, 2020.
  1. Dec 14, 2020 at 7:56 AM
    #181
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    All 3 first gens I've owned have been between 190-194. Two of them had brand new radiators and thermostats. I think PHM just has a special deal with the radiator cooling karma gods.
  2. Dec 14, 2020 at 8:00 AM
    #182
    Filthyphil
    Filthyphil Lions Not Sheep
    Phil
    2000 Toyota Tundra TRD 4.7
    My truck runs 188 if its really cold out but normally I see 190-192 cruising.
    N84434[OP] likes this.
  3. Dec 14, 2020 at 2:14 PM
    #183
    Professional Hand Model
    Hand Protectors
    I’m wondering if the Lower Temp Mojo is in the Prestone Flush? All things considered this is the only thing different I’ve done compared to everyone here (unless you guys have and didn’t say I wouldn’t know). I never did one before so have no baseline comparison.
    Reviewers stated higher Heater/Blower Temps and lower rad temps with the oils and light rust being removed. Some reviewers said did not do a thing. I’ll take a freebie when I can get it. Like I said I thought 195-200° was normal.
    ***Edit: Nothing was wrong with the old radiator. I even cut into it for inspection. Looked brand new inside on the section that was cut up.
    N84434[OP] and Filthyphil like this.
  4. Dec 14, 2020 at 5:06 PM
    #184
    N84434
    N84434 [OP] In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    Ran some errands today and even got the truck washed! Im loving this snow-less December here in Wisconsin...
    Anywho, I did notice the overflow tank was pretty much dry this morning, so I bought a gallon of Zerex 50/50 and filled it to the line. I wonder if my radiator was a little low? Driving around the temps stayed around 184-186, but did venture up near 190 as well.
    I don't know.... I'm calling it good...:thumbsup:
  5. Dec 15, 2020 at 8:41 AM
    #185
    rock climber
    I didn't do the prestone flush on either of my radiator replacements so maybe that is what did it. (I still think it's the cooling gods you gained favor with)
  6. Dec 15, 2020 at 8:45 AM
    #186
    Hand Protectors
    Yes. And everyones ‘Thoughts and Prayers’ for a cooler globe are helping. I feel bad for all those years of having a hot radiator. I think the Horned Chick Pea Harvest will be better this year.
    Filthyphil likes this.
  7. Dec 17, 2020 at 8:29 PM
    #187
    love2rv
    love2rv New Member
    Garry
    2003 Tundra 4x4 Stepside
    Wow that was an interesting read and impressive work! I don't have those skills and applaud you.
    In one post you mentioned converting the interior lights to LED, I just bought a 2003 Limited 4x4 StepSide and the lights in the center stack are really dim even with the brightness at full, might even have a few dead so I would like to fix that and would go LED when I crack it open.
    If you did this LED conversion do you have any details about the bulb sizes needed? Where you got them? Any help really would be appreciated. If not no worries, I will use the search tool and am sure to find something here.
    Again, good work!
    N84434[OP] and Tundra2 like this.
  8. Dec 18, 2020 at 5:26 AM
    #188
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Thanks much. With the onset of winter here in Wisconsin, I've decided to forgo swapping the interior lights until next spring. I will be posting the work here in my thread, but there are a number of really good threads that discuss interior LED swaps already.
    Search and ye shall find...
  9. Dec 23, 2020 at 6:01 AM
    #189
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Short update here.
    I had a headlight burn out, so I picked up some LEDs for the Tundra. I'm very Happy with the output. They do a great job of illuminating the road and the beam seems to sit low, so I'm not blinding drivers in front of me:thumbsup:
    here's a couple pics I grabbed last night taking the trash can out...
    You can see where the beam cuts off on the tree.
    This next shot is not the best photo, as this makes them look much brighter than they are.
  10. Dec 23, 2020 at 7:07 AM
    #190
    love2rv
    love2rv New Member
    Garry
    Which LED Headlight bulbs did you go with?
  11. Dec 23, 2020 at 8:02 AM
    #191
    N84434
    Milwaukee WI.
    2001 Limited TRD
    two2cal and Tundra2 like this.
  12. Dec 23, 2020 at 8:46 AM
    #192
    love2rv
    love2rv New Member
    Garry
    Thank you! Merry Christmas!
  13. Jan 12, 2021 at 1:22 PM
    #193
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Time for a mid-winter update... the trucks been running great. About a week ago, I noticed a slight oil smell while driving.
    You guessed it. Valve covers started seeping. I figured I'd just tighten the bolts a little and buy myself some time.
    The first bolt I started snugging up snapped right off...:frusty:
    At that point I knew I was going to replace the gaskets, so I figured I'd remove the VCs and get ready for the inbound parts.
    I ended up snapping a total of 8 bolt heads off while removing the covers...:annoyed: I was able to use an easy out on 2 of them to remove the remaining bolt, but the other 6 I had to drill out and re-tap. Unbelievable.
    It took me most of yesterday to drill out the bolt remnants and tap the holes. Working in a 35 degree garage was not fun, but I made the best of it.
    I slopped some paint on the covers just to freshen them up and ended up replacing the worst of the hardware for the coils and Valve covers.
    This morning I installed my newly acquired Tonneau Cover the Festivus Trolls left me, and went for a shake down run. Got home and had no drips, no leaks and no smells..:thumbsup:
    On to the pictures.....
    This was after snapping the heads off on the first few bolts on the driver side.
    After getting the cover off, it was time to repair... Tapping the holes...
    And yet another hole that needed drilling and tapping. I saw those markings on the intake cam, and was wondering what they referenced? Any thoughts?
    Here it is all back together.
    The bed cover was a breeze to install, and it looks pretty good on there.
    Here's to many more months of enjoyment!:cheers:
    Galladanb, 300BLK, bmf4069 and 8 others like this.
  14. Jan 24, 2021 at 8:00 AM
    #194
    babydaddy
    babydaddy New Member
    Craig
    2000 Tundra LTD
    All of your mods look great. I envy your patience. Lookin good!
  15. Jan 24, 2021 at 8:07 AM
    #195
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I have Tonneau Cover envy...can you share the details (make/model/PN, etc.)?
  16. Jan 24, 2021 at 2:32 PM
    #196
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Thanks very much! I bought a very basic cover off eBay. I found a seller with decent feedback and hit the B.I.N. button.
    I bought this one:
    https://www.ebay.com/itm/FOR-2000-2...-COVER/163393329648?ssPageName=STRK:MEBIDX:IT
    super easy to install, didn’t break the bank and it looks good.
    The one thing I had to rectify was the hardware. The kit came with 6X1.0 bolts that were about 25mm long and too short for my bed rail edges. I ended up buying 35mm length bolts that were a little better quality. All of .68 cents each.
    w666[QUOTED] likes this.
  17. Jan 24, 2021 at 2:40 PM
    #197
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Thanks Craig. It was enjoyable to work on it all last summer. I appreciate the kind words!
  18. Feb 15, 2021 at 5:20 AM
    #198
    N84434
    Milwaukee WI.
    2001 Limited TRD
    It finally happened... My wife was running to the store, the truck was in the driveway, so I said " take the Tundra.... it'll be better in the snow..." Keep in mind this is literally the first time she has driven it.
    When she came home, she pulled up to the garage and managed to hit the corner of the house. We have brick, so no damage there, but the truck?
    Looks like I have some painting to do....:annoyed:
    Admittedly she felt bad, and has decided never to drive the truck again.:thumbsup:
    Filthyphil and des2mtn like this.
  19. Feb 15, 2021 at 10:48 AM
    #199
    jimf909
    jimf909 Battery almost dead...
    Washington or Idaho
    '03 Tundra SR5 AC 4.7 TRD w/LSD
    Dead stock with oem 16" starfish wheels. We'll see how long that lasts. :) Topper of unknown origin.
    I really like this thread and your work adding a few years to this truck's usefulness. Bummer on the scratches but they look like a cakewalk for you.
  20. Feb 15, 2021 at 11:11 AM
    #200
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Thanks Jim. This spring, I'll be doing these scratches and now I've got a reason to tackle the dents in the corner of the bed and the right rear door....
  21. Feb 15, 2021 at 5:49 PM
    #201
    Stuck in the '00s
    Stuck in the '00s Experienced member
    Mikey
    SE Wisconsin
    2004 Phantom Gray DC 4X4 Limited Tundra
    Western plow, custom bed
    Of course you'd find a silver lining...glad it was nothing worse.
    N84434[QUOTED][OP] likes this.
  22. Feb 15, 2021 at 6:34 PM
    #202
    N84434
    Milwaukee WI.
    2001 Limited TRD
    True... glad it was nothing worse. This gives me a chance to brush up on my body work skills o_O:(
  23. Mar 30, 2021 at 9:49 AM
    #203
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Time for an early spring update....
    When I bought the truck last January, it only had one sorry sounding horn (low tone) and it was not very loud.
    So, I found a set of replacement horns on line and grabbed em. Easy to install and now I have a much better sounding "Get out of my way!"
    I also started installing my lights on the hood and bumper. I haven't wired them in yet, I'm still not completely sold on the Ditch lights thing, although I do like how they look.
    It's been a solid driver all winter. Just have to make sure to exercise the 4WD actuators every so often. I'm starting to gather some tools and supplies to tackle the dents and scratches on the right side of the bed, where my wife hit the house (she still hasn't driven it since then).
    I gotta say.. I love this truck!
  24. Mar 30, 2021 at 10:39 AM
    #204
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Woops..... forgot the pictures...:confused:
    The old rusty horn.
    New horns installed.. Sound great.
    Here's the light bar installed on the bumper cover
    Close up of the Ditch lights
    And a view of the whole dang thing. I still need to wire everything in. I'm just not sure about the Ditch light placement.
  25. Mar 30, 2021 at 11:17 AM
    #205
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    This has been a fun read! Great job on the frame and cleaning everything up. I had a Tacoma that I spent some time cleaning off the frame and repainting before it got too bad but nothing anywhere near what you did here. I see the Rodney sticker btw, MCM fan.
  26. Mar 30, 2021 at 11:23 AM
    #206
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Much appreciated.. Yeah, I've been watching MCM for 5-6 years. Love those guys..
  27. Mar 30, 2021 at 1:23 PM
    #207
    Hand Protectors
    @Glock 40 the horns not working.
    Galladanb likes this.
  28. Mar 31, 2021 at 1:58 PM
    #208
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    I think that horn should aim down to minimize rain, right?
  29. Mar 31, 2021 at 6:18 PM
    #209
    N84434
    Milwaukee WI.
    2001 Limited TRD
    You are probably correct. I’ll adjust them tomorrow..
    Thanks for the Eagle eye..:hattip:
  30. May 20, 2021 at 9:47 AM
    #210
    rockmup
    rockmup New Member
    Todd
    Greenwell Springs LA.
    Great thread.
    So how long before you pull the cab so you can do as good a job on the frame as you did the rear ? lol
    bmf4069 likes this.
