My 03 build
Discussion in '1st Gen Builds (2000-2006)' started by Brown Bear, Sep 7, 2017.
  1. May 8, 2019 at 10:16 PM
    #61
    Brown Bear
    Brown Bear [OP] New Member
    Nor cal
    03 TRD offroad
    -6" RCD lift in front. -Custom leaf springs in rear 4" lift. -17" race line, raptor wheels. -35" Goodyear Duratrac. -4.88 gears. -ARB rear air locker. -ARB air compressor and tank. -Custom front sway bar quick disconnect -Custom one piece driveshaft -Black Oak Led 40 watt ditch lights.
    Thanks. I haven't gotten around to the shackle flip kit yet. Work and life keep getting in the way. I will probably wait until I get new rear shocks. After doing more research, this is the flip kit I think I would go with. https://archivegarage.com/products/2000-2006-tundra-sfk I think you can get 1 to 1.5 inches of lift out if it .
    JustGotDuals[QUOTED] likes this.
  2. Jan 1, 2020 at 2:52 PM
    #62
    SOS CONCEPTS
    SOS CONCEPTS SOS Concepts
    I run AG shock relocation on my Tacoma. Their stuff is on point. He's also working on a relocation for the tundras now too.
  3. Jan 30, 2020 at 5:34 PM
    #63
    Wahali
    Wahali New Member
    2006 dc tundra
    Hey can you tell me where you got that leaf pack made? I’m in the market for a new leaf system.
  4. Jan 30, 2020 at 6:46 PM
    #64
    Brown Bear
    Nor cal
    03 TRD offroad
    I got them made at Sacramento spring. I live close enough where I was able to drop off my truck and hang out while they made them. It was a cool process watching them hand Forge the springs.
    http://sacspring.com/
  5. Feb 24, 2020 at 6:07 AM
    #65
    chrisb
    chrisb scumbag
    noblesville, IN
    06 AC 4x4
    Did you ever do a shackle flip? I see the AG kit is NLA and I've come across very limited info for doing one on my truck shy of fabricating something from scratch.
  6. Feb 24, 2020 at 8:26 AM
    #66
    Brown Bear
    Nor cal
    03 TRD offroad
    No. I haven't gotten around to it yet. Mostly because I'm pretty happy with the ability of my custom leaf springs. I already have 11.5 inches of travel. I would like to get a flip kit one day but it has been put further down the list of importance. This is a good option if AG has discounted them.
    https://www.ruffstuffspecialties.com/catalog/UNFLIP.html
    chrisb[QUOTED] likes this.
  7. Jun 27, 2020 at 8:14 AM
    #67
    Brown Bear
    Nor cal
    03 TRD offroad
    So it's been a while sense I have posted anything in my build page. Here are some of the things I have done recently. New timing belt and water pump. I had a torn inner cv boot so I put on new high angle cv's and new oem lower ball joints. 20200625_163316.jpg
    I replaced my headlights and bulbs due to the inevitable Sunrot. This is my trucks 3rd set of headlights. 20200313_111518.jpg
    I also built a bed rack for my 10ft Jon Boat. It is made out of Unistrut and some scrape steel from my wife's old treadmill. It is low profile and side lifts so I can have full access to my bed with out taking the boat off the rack. The boat sets low enough so its below the cab line so it won't take away any mpg. I used two heavy duty unistrut adjustable braces for the hinges. Two 150 lb gas struts help lift the boat out of the way. I still have some adjustments to do. I think I'm going to move the gas struts out further to get a little more lift out of them. 20191001_173951.jpg 20191029_144242.jpg 20191029_144122.jpg 20191029_144139.jpg 20200211_163322.jpg 2020-02-17 15.47.07.jpg 20200516_151658.jpg 20200621_104839.jpg 20200621_104855.jpg 20191129_091924.jpg
    5N0W808, Filthyphil, Voss and 10 others like this.
  8. Jun 28, 2020 at 9:47 AM
    #68
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    honestly, this is the coolest first gen I've seen. So freakin' Awesome!
    JC303, MS22, Darkness and 2 others like this.
  9. Jun 28, 2020 at 11:43 AM
    #69
    Brown Bear
    Nor cal
    03 TRD offroad
    Thanks bud. It's a slow work in progress that will probably never end.
    lsaami[QUOTED] likes this.
  10. Jun 30, 2020 at 9:03 AM
    #70
    Bkfreedom
    Bkfreedom New Member
    Nice truck! How do you like the 4.88 gears? I been reading mixed opinions on rather to go with 4.56 or 4.88 for 35" tires. Also you said you had problems with your stock driveshaft? RCD website says the stock driveshaft retained but I thought that didn't sound right given the 4" lift in the rear.
  11. Jun 30, 2020 at 10:03 AM
    #71
    Brown Bear
    Nor cal
    03 TRD offroad
    I do like having it re geared with 4.88's. Although I only really drove it about a mile or two with 35's and stock gears. But having 35's with the 4.88's I can't tell much difference from when I had the stock tire size and stock gears. I actually I think it drives better then it did before I did the lift and bigger tires. My issue with the drive shaft was I had a chatter when I would take off from a stop. The rcd lift kit comes with a 1in drop spacers to lower the center carrier bearing. But it's really not enough. So I welded an additional inch of Steel to give it 2 inchs of drop to make the two-piece driveshaft more of a straight angle. I also used pinion angle shims to get the right pinion angle which helped a lot. But I still had a little bit of a chatter. That's when I decided to go with the one piece driveshaft. The only problem is newer Vehicles particularly the tundra are very precise with pinion angles. Even half a degree off and you can have issues. With the one piece driveshaft it eliminated my chatter from a stop but I do get a vibration around 90 miles an hour. But that's okay with me cuz I never really drive that fast. The weird thing is there's a old guy that lives down the road from me that has an 06 Access Cab with the 6-inch rcd lift. He told me he bought the brand new off the showroom floor with the 6-inch rcd lift already on it. He said he has had no issues with any vibration or chatter. He doesn't even know what gears are in it either. But he did say it's not lacking in power.
    Voss and Darkness like this.
  12. Jun 30, 2020 at 10:17 AM
    #72
    Casper421
    In the woods
    06 DC
    Do you remember if you had stock 3.91’s or 4.10’s?
  13. Jun 30, 2020 at 10:32 AM
    #73
    Brown Bear
    Nor cal
    03 TRD offroad
    I believe it was 3.91s If I remember right.
    Casper421[QUOTED] likes this.
  14. Jun 30, 2020 at 1:31 PM
    #74
    Bkfreedom
    Ok so ultimately the stock drive shaft will work you just hear a little bit of chatter on just acceleration? Did your mpg drop dramatically or not to much after the regear? Thanks!
  15. Jun 30, 2020 at 2:38 PM
    #75
    Brown Bear
    Nor cal
    03 TRD offroad
    Yes stock Driveline will work. The chatter I had I don't really think would cause any issues other than being annoying. My gas mileage actually stayed about the same if not a little bit better. But I do drive my truck like an old man. Slow accelerations and I don't speed very much. It's actually kind of hard to tell because since lifting my truck it has become a weekend warrior and not a daily driver. Every time I drive it I seem to have either a boat and a bunch of camping gear in the bed or I'm towing one of my other boats or out 4 wheeling.
  16. Aug 6, 2020 at 1:32 PM
    #76
    zgurrola21
    zgurrola21 New Member
    Zyan
    2001 Toyota Tundra SR5 TRD OFF-ROAD
    Brown Bear, What’s the specs on your rim such has how wide it is and the what back spacing did you choose and the offset?
  17. Aug 6, 2020 at 4:46 PM
    #77
    Brown Bear
    Nor cal
    03 TRD offroad
    They are 17x9 with 4.5in backspace -12 offset. The lift kit suggest having a 4-inch backspacing. I read reviews though saying there still might be some rubbing on the frame so 1 Inch spacers are suggested. So I decided to go with a 4 1/2 inch backspacing with a 1-inch spacer. This way I'm only a half an inch over the recommended versus a whole inch. If that makes sense.
  18. Aug 6, 2020 at 5:51 PM
    #78
    zgurrola21
    Zyan
    Glad you responded, I was speaking with a representative that sells the RCD lift kit and he told me the reason to go with 4” back spacing is because it would be rubbing on the steering right which he means the tire and the knuckle would be rubbing but I didn’t believe him because I have 4.5” back spacing on my current rims but or course maybe he suggested that was because a new spindle was coming into play and that’s why maybe it was 4” back spacing but I remembered that you have the lift kit and so I wanted your input on what rims you have, I was planning on doing 18x9 4.53 backspacing with -12 offset on 305/65/18 tires. I don’t mind the rubbing on the frame since I’m already rubbing on the frame currently with my 285/75/16. So my question is does your 35” tires rub onto the knuckle, does it make contact with any suspension components, I don’t mind the rubbing on frame.
  19. Aug 6, 2020 at 5:52 PM
    #79
    zgurrola21
    Zyan
    For you 1” spacer, you don’t rub correct?
  20. Aug 6, 2020 at 7:21 PM
    #80
    Brown Bear
    Nor cal
    03 TRD offroad
    I did have to take off my front mudflaps, and trim the corner of the front bumper. I do still rub just a hair on the corner of the wheelwell where the mud flap was. But that was only when my tires were brand new. Other then that I don't rub on anything else. 2020-08-06 19.18.23.jpg
    Filthyphil likes this.
  21. Aug 6, 2020 at 7:39 PM
    #81
    zgurrola21
    Zyan
    Awesome, I was just concerned because I didn’t want any suspension components rubbing onto the rim or tire since the representative was freaking me out a bit cause I was going for 4.5” backspacing rather than 4” on what they recommend
  22. Aug 6, 2020 at 7:43 PM
    #82
    Brown Bear
    Nor cal
    03 TRD offroad
    You should be good with 4.5 backspace but you will need a 1in spacer. I think 3.5 backspace is the best size if you don't want spacers. I only went this route because I got a killer deal on my wheels.
  23. Aug 6, 2020 at 7:48 PM
    #83
    zgurrola21
    Zyan
    I don’t want spacers because I’ve heard they tend the break due to so much stress, I don’t mind the rubbing on the frame if that’s what your implying to get a 1” spacer but my brother does want spacers, has your failed on you or? What do you recommend if I do go with that route and as well is your set up leveled with the fender flares or the rims and tires sticking out from the fender flares?
  24. Aug 6, 2020 at 8:22 PM
    #84
    Brown Bear
    Nor cal
    03 TRD offroad
    I have not had any issues with my 1in spacers. Most of the issues with spacers come from people with 3in+ spacers on heavier trucks. Or people that forget to retorque there spacers on every tire rotation. Imo pushing out the tire puts the same amount of stress one the wheel bearing weather it from the wheel or the spacer. My tires do stick out about a inch. This is the best pics I have of how much.Screenshot_2020-08-06-20-04-49.jpg 20180527_152548.jpg 20181010_154926.jpg
    Voss, Filthyphil and JC303 like this.
  25. Aug 6, 2020 at 8:27 PM
    #85
    Brown Bear
    Nor cal
    03 TRD offroad
    I would definitely recommend putting new lower ball joints in. If you do decide to go with the rcd.
  26. Aug 6, 2020 at 8:50 PM
    #86
    zgurrola21
    Zyan
    Oh okay great then that’s definitely an option for the spacers and yeah I’m going to put new ball joints. I had two break on me already in 2 years because my suspension isn’t made for a lift kit so it’s putting a lot of stress onto the ball joints. Thank you so much for replying, very much appreciated. Have a great day man. Love your build
    Brown Bear[OP] likes this.
  27. Aug 6, 2020 at 8:57 PM
    #87
    Brown Bear
    Nor cal
    03 TRD offroad
    No problem.
  28. Feb 16, 2021 at 9:38 AM
    #88
    scotted3
    scotted3 New Member
    Sick trucks fellas. Im wondering if you can help a rookie out. BrownBear: for sake of convo, I basically have your exact truck ( limited not SR5 tho), and its all stock.
    The shocks are 20 yrs old obviously, and front sags. I want it as level as possible but ppl are telling me putting spacers on can have long term consequence. A level kit could potenitially work but doesnt help w my need for shocks. I was hoping I could achieve both with just the right set of shocks.
    Considering i want to improve shock absoorbtion on the road + level/lift the front -- would you have any Recs for me at all? Im gettting so much mixed recs from people that have never worked on my truck model in the first place. I do not want to degrade drive quality at all.
    I dont need a huge lift and trying to drop no more than 1000-1500 on this for now ( gotta save for a canopy + rack system).
    THese are the two I have come down too ( see below). MOST have recommended these bilsteins but they say i can lift it any higher than 1.5 " due to some reason specific to my make n model --- Does that make sense??
    Bilstein -- https://www.1stgenoffroad.com/store/p769/Bilstein/OMELiftLevelKit.html#/
    rough country -- https://www.customwheeloffset.com/s...?year=2002&make=Toyota&model=Tundra&drive=4WD
    is RC good quality -- do you know?
    Thanks for your consideration
    scott
  29. May 25, 2021 at 1:51 AM
    #89
    2000TundraTRDPRO
    2000TundraTRDPRO New Member
    Desi
    Honolulu, Hawaii
    2000 tundra limited 4x4 4.7 V8
    So far 3” leveling kit 265/70/17 Firestone Destination MT2 Tailgate reverse camera 7” double din deck 2020 wood grain steering wheel Full sound system 2020 TUNDRA OEM Alarm FOR NOW
    Does the 35’s rub? I’m planning on doing the same 6” maybe a little higher lift with the coil overs I’m getting.... I see that you cut the front lower bumper and I did the same to mines but I’m wondering if the rear part of the the front fender will rub... I am going with 14” rims also so I’m pretty sure that’s a little different then your set up. Beautiful truck tho
  30. May 26, 2021 at 9:30 AM
    #90
    des2mtn
    SW
    2004 Black DC Limited 4x4
    Tonto cover
    What's your plan for accomplishing this? 13WL calipers barely clear 16" wheels + weights and I don't think 13WEs would clear 15" wheels.
