Must have/awesome mods under $100?
Discussion in '1st Gen Tundras (2000-2006)' started by Matty4wd, Nov 21, 2018.
  1. Dec 26, 2018 at 11:20 AM
    #91
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    I tightened the one with the arrow which didn’t help. Which others are for the window motor?
  2. Dec 26, 2018 at 12:03 PM
    #92
    Professional Hand Model
    Hand Protectors
    Just snug all of them down. Not too tight. Just snug them slightly a bit at a time until firm. Alternate doing all of them and come back and re-snug. You can also lift that plastic flap up from the bottom and reach your hand in there a feel around a bit for anything that has fallen or my be loose.
  3. Dec 26, 2018 at 12:05 PM
    #93
    FlightSimGuy
    FlightSimGuy New Member
    2006 Tundra SR5 V8 DC
    ICON 2.5 shocks with King 14" 700lb coils, Camburg UCAs, ICON V2.0 rear shocks.
    This reminds me, I think I need new window motors.
  4. Dec 26, 2018 at 6:22 PM
    #94
    yoneytan
    yoneytan New Member
    Asi
    14 CM
    That picture is not of my truck its a pic I found online so I can see where the bolts are located. Trying to figure out which ones are for the window assembly so I don't punch through the matting more than I need to.
  5. Dec 27, 2018 at 8:08 AM
    #95
    Hand Protectors
    I assumed such. Punching thru the matting will not change a thing. Just foil tape the cut out plugs back over. The screws for the tracks run vertically on each side of door. Won’t hurt to tighten everything.
  6. Jan 6, 2019 at 3:21 PM
    #96
    Hand Protectors
  7. Jan 19, 2019 at 5:10 PM
    #97
    Swalters
    Swalters Run your truck, not your mouth
    Sam
    Arizona
    "Attaque" - LT V8 4runner
    I don't think I ever posted my phone mount in this thread. Ram Mounts motorcycle mount bolted to the grab handle, an extension arm and a mount of your choice that is a ball mount (mine is a mob armor marball). IMG_20181226_133057.jpg IMG_20181226_133024.jpg
    Weagle, Darkness, TK1979 and 4 others like this.
  8. Jan 19, 2019 at 5:48 PM
    #98
    abcinv
    abcinv OEM (+) Junkie
    Tommy
    NW Georgia
    2006 Tundra 4X4 Limited Dbl Cab
    I posted this in a different thread but belongs here as well; about $10 worth of gun case foam..
    Weagle, TK1979, Matty4wd[OP] and 2 others like this.
  9. Jan 23, 2019 at 5:52 PM
    #99
    Whocares
    Whocares Member
    Bluetooth module for music. Plug and play, allows use of steering wheel controls ( forward and back song tracks ).
    Rica25, Matty4wd[OP] and FlightSimGuy like this.
  10. Jan 23, 2019 at 6:21 PM
    #100
    FlightSimGuy
    Been eyeing one of those. Which did you get?
  11. Jan 23, 2019 at 6:37 PM
    #101
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I put a JVC stereo in that came with a Bluetooth mic that I mounted on my A pilar. It works great and cost around $70 from Crutchfield.
    FlightSimGuy[QUOTED] likes this.
  12. Jan 23, 2019 at 10:16 PM
    #102
    FlightSimGuy
    That's another upgrade for down the road. Need a new stereo to replace this cheap aftermarket one.
  13. Jan 23, 2019 at 11:41 PM
    #103
    shhernandez74
    shhernandez74 New Member
    Samuel
    2017 Barcelona Red Tundra 4x4 SR5
    FRAC Driver side handle TRD Sway Bar Pop Lock Led Lights Seat Warmers Katzkin Bumper Step
    Body color mirror caps! 85 bucks on spark parts 26DE8072-B801-4098-AB74-84BCBB619691.jpg2D2325B5-11A3-44E4-9FB4-EA747C412A11.jpg
    Weagle, Norfolk757 and potoghi like this.
  14. Jan 24, 2019 at 3:52 AM
    #104
    FirstGenVol
    East TN
    2002 AC TRD 4x4 V8
    I mean, mine is honestly a cheap aftermarket unit but works great. I finally have bluetooth capability for both calls and streaming music. They were also doing a deal where if you buy the stereo you can get matching JCV speakers at half off. The speakers came out to $12.50 each after the discount. Install was a breeze.
    Whatever you do, I highly recommend Crutchfield.
    Here is the one I have.
    https://www.crutchfield.com/p_105KDR690S/JVC-KD-R690S.html
  15. Jan 24, 2019 at 3:55 AM
    #105
    Whocares
    Whocares Member
    So the one I bought seems to have been discontinued on Amazon. I found this one :
    Wyness Car MP3 USB/AUX 3.5mm Stereo Wireless Music Receiver Wireless Hands Free Auto Bluetooth Adapter Fit for Toyota (6+6) Pin Camry Tacoma Corolla Tundra RAV4 Lexus RX GS is https://www.amazon.com/dp/B06Y99V8T3/ref=cm_sw_r_sms_apa_i_iDAsCbPJ7YRN
    Similar in design.
    Take out stock head unit, plug in module, and that's it. For me, the audio quality through BT is far better than aux input. Great addition/ improvement.
    FlightSimGuy and Matty4wd[OP] like this.
  16. Jan 24, 2019 at 6:55 AM
    #106
    FlightSimGuy
    I'll check that out. I like these as well:
    https://www.bestbuy.com/site/jvc-6-...Wu4TdBAQP-iwENKaVmySU1ea7d8otgQ4aAqaYEALw_wcB
    I was thinking about getting one but may just wait until I get a new stereo.
  17. Jan 24, 2019 at 7:50 AM
    #107
    Whocares
    Whocares Member
    Im not very tech savvy so I like keeping it simple and stock, hence the module. I guess im one of the few that actually like Toyotas "dated" technology.
  18. Jan 26, 2019 at 7:58 AM
    #108
    abcinv
    Tommy
    NW Georgia
  19. Jan 26, 2019 at 10:07 AM
    #109
    j0331
    j0331 New Member
    2016 Tundra
    I've got the GTA car kit in my truck. Sounds ok and it's really easy to install, but sometimes i have a problem with the Bluetooth connecting automatically when i start my ride up. i just have to disconnect the Bluetooth from my phone and reconnect and it works fine from there on.
  20. Jan 26, 2019 at 10:10 AM
    #110
    FlightSimGuy
    BT is always sketchy no matter what it is.
  21. Jan 26, 2019 at 10:25 AM
    #111
    abcinv
    Tommy
    NW Georgia
    Thanks for letting me know; think I'll pull the trigger on this kit.
    What did you do with the AUX cable you gained and did you go ahead and setup the USB charging cable (optional)?
    I'm thinking of using the two blanks below the ash tray for these; would love to see pics of someone already doing something like this.
  22. Jan 26, 2019 at 11:22 AM
    #112
    Whocares
    Whocares Member
    Same here, different module. I paid $30. Oh well.
  23. Jan 26, 2019 at 8:54 PM
    #113
    j0331
    j0331 New Member
    2016 Tundra
    Didn't use the AUX cable cause i got it for BT and i didn't use the USB cable either. i think its worth the investment
    Rica25 likes this.
  24. Jun 19, 2019 at 6:14 AM
    #114
    adrian.bee
    adrian.bee New Member
    Maine
    05 AC 4X4
    I had the same thought, except my blank is next to the cargo lamp button. There has to be something like this that would work.. https://www.amazon.com/USB-Mount-Cable-Extention-Motorcycle/dp/B00VAIEAUM/
    Has anyone done that before?
    I also noticed the GTA kit has an old 20 pin connector, pretty annoying to have to use that many adapters.
  25. Jun 20, 2019 at 1:52 AM
    #115
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    Found my black billet grill for $50 and got a modern TOYOTA grill emblem in white for $40. Both from Amazon.
  26. Jun 20, 2019 at 3:23 AM
    #116
    KarmaKannon
    KarmaKannon Master of None
    Utah
    2006 Double Cab w/long travel
    Some junk
    I installed Bluetooth for well under $100.
    I used the aux adapter without Bluetooth (in hindsight I could have gotten the one with Bluetooth I think)
    -wyness part number 5864134764 (Toyota 6x6 aux adapter)
    Then I used a chargeable Bluetooth adapter that used a mini USB.
    To power the Bluetooth I used a wired (two wire) 12v DC to mini USB plug. This was wired to a key switched 12v+.
    The mini USB always stays plugged in and keeps the Bluetooth charged. The Bluetooth shuts off after a few minutes without being connected. So I get out of the truck, walk away, and the Bluetooth turns off. When I get back in the truck I just hit the pair button on the Bluetooth and it pairs.
    (Pics to come)
  27. Jun 27, 2019 at 10:50 AM
    #117
    adrian.bee
    Maine
    05 AC 4X4
    Thanks for this, do you have pictures that you wouldn't mind sharing? Definitely want to install something similar.
  28. Jun 27, 2019 at 6:47 PM
    #118
    KarmaKannon
    Utah
    Some junk
    I just updated my post with a picture of the actual Bluetooth unit. Not much to see but I like the way it turned out. I just drilled a hole in the little tray to run the wires and I used some hook and loop to mount the Bluetooth.
  29. Jun 28, 2019 at 6:15 AM
    #119
    adrian.bee
    Maine
    05 AC 4X4
    Thank you sir! Definitely a clean setup. I have the bench seat so I'd need a different mounting solution, but definitely a great idea.
  30. Jun 28, 2019 at 9:05 AM
    #120
    arctictundra8577
    arctictundra8577 New Member
    Eric
    Ontario, Canada
    2005 tundra sr5
    where did you get that cassette adapter?
