Must have/awesome mods under $100?
Discussion in '1st Gen Tundras (2000-2006)' started by Matty4wd, Nov 21, 2018.
  1. Nov 24, 2018 at 1:48 PM
    Professional Hand Model
    Hand Protectors
    First gen for sure. Not experienced with second gen so I cannot say. It really helped my braking hugely.
  2. Nov 24, 2018 at 1:52 PM
    Hand Protectors
    They make the OEM replacement cases which do not contain the internal buttons/keyboard. You just swap the internals into the new case. I like the OEM as its smaller and rounded. Yours looks cool though. Does it require programming?
    dudesy likes this.
  3. Nov 24, 2018 at 2:01 PM
    Swalters
    Swalters Run your truck, not your mouth
    Sam
    Arizona
    "Attaque" - LT V8 4runner
    Nope, literally what you just said. Swap internals into the AJT case. They even provide the Allen wrench for the screws.
  4. Nov 24, 2018 at 2:10 PM
    Casper421
    In the woods
    06 DC
    Only the 1st gen. The brake bias is built into the master cylinder on the 2nd gen specifically cause it has calipers in the rear instead of wheel cylinders.
  5. Nov 24, 2018 at 2:38 PM
    Hand Protectors
    Ok. My buttons for 2002 look different than yours.
    Matty4wd[OP] likes this.
  6. Nov 24, 2018 at 2:54 PM
    Matty4wd
    Matty4wd [OP] Young Tundra Enthusiast
    San Antonio, Texas
    2005 Tundra Limited
    Maybe you dont have the dealer installed system??
  7. Nov 24, 2018 at 3:19 PM
    Hand Protectors
    Not sure. I have the same two fobs that came with the original purchase. No writing on them. Just two black buttons in a dark gray case.
  8. Nov 24, 2018 at 3:20 PM
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
    Pic?
  9. Nov 24, 2018 at 3:20 PM
    Hand Protectors
    Will do tomorrow.
    Matty4wd[QUOTED][OP] likes this.
  10. Nov 24, 2018 at 4:06 PM
    Swalters
    Sam
    Arizona
    There were some fobs that differed, and of course aftermarket. My old ones had the Toyota logo on them
  11. Nov 25, 2018 at 7:57 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    Just over $100 but my favorite "cheap" mod is the Scangauge2. Having that really changed the way I understood my truck.
    An under $100 option is the Ultragauge. I got one recently but haven't really figured it out yet, haven't taken the time to calibrate it.
  12. Nov 25, 2018 at 10:28 AM
    Hand Protectors
    OEM Key Fob
  13. Nov 25, 2018 at 10:32 AM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    If you're rolling on bigger tires then I would say a matching spare
    NUDRAT and Matty4wd[OP] like this.
  14. Nov 25, 2018 at 12:06 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    I picked up two spare 35s for under hundred for both with 80% tread life left anf DOTs still in service. Its a spare....no need to buy new.
  15. Nov 25, 2018 at 12:35 PM
    Hand Protectors
    Tighten your window track bolts (10mm) located on your door jamb just 12” below the latch. 1/4” turn eliminated window rattle at speed when windows were rolled half down. FREE!
    Tundra2, dvani, TRDblvd and 8 others like this.
  16. Nov 25, 2018 at 2:28 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Yes Sir!
    Rica25 and OR18TRD[QUOTED] like this.
  17. Nov 26, 2018 at 7:27 AM
    because_wumbo-truck
    because_wumbo-truck TTC#036 & 1st Degenerate
    Jon
    Houston, Texas
    2006 AC Tundra Limited 4x4 v8
    flowmaster 40, DDI injectors, sliders, bumper
    I'm just happy to finally have working key fobs for this truck lol and they didn't break the bank
  18. Nov 26, 2018 at 7:29 AM
    because_wumbo-truck
    Jon
    Houston, Texas
    Same as my 99 taco
  19. Nov 26, 2018 at 7:30 AM
    #49
    because_wumbo-truck
    Jon
    Houston, Texas
    I still need to program my scangauge to read trans temp
  20. Nov 26, 2018 at 3:47 PM
    #50
    lsaami
    lsaami Let ‘er buck
    Minnesota
    2000 Tundra 4x4 "$1100 Build"
    What information do you get with the scangauge? Trans temp? Engine oil temp?
  21. Nov 26, 2018 at 4:55 PM
    #51
    Matty4wd
    San Antonio, Texas
    2005 Tundra Limited
  22. Nov 26, 2018 at 5:06 PM
    #52
    Darkness
    Luis
    All over SoCal
    The darkest
    It's really dark
    @lsaami
    It can monitor 4 things at a time. Normally I run:
    Real time MPG
    Trip average MPG
    Load
    Intake air temp (or calculated horsepower for fun)
    It can do trans temp for most years but I don't care about that. It can do several other cool items. It can do 0-60 times and I think quarter mile times, and reads/clears engine trouble codes.
    FirstGenVol, Matty4wd[OP] and lsaami like this.
  23. Nov 26, 2018 at 5:45 PM
    #53
    War Machine
    War Machine SSEM # 5 3MW
    Plus one for the keysmart. Love mine.
  24. Nov 28, 2018 at 7:53 PM
    #54
    pwgfalcon
    pwgfalcon New Member
    Replaced Steering Rack Bushings with
    Energy Suspension 810104G Steering Rack Bushings
    Cost with tax $29.00
    My Labor 0 And worth every cent.
    Easy job with lots of bang for the buck.
  25. Nov 30, 2018 at 6:51 PM
    #55
    Hand Protectors
  26. Dec 3, 2018 at 1:29 PM
    #56
    Swalters
    Sam
    Arizona
    The fog anytime mod is relatively cheap (some wire and connectors) and is so worth it. Just did it over the weekend and it's fucking awesome to be able to control my fogs whenever I want.
  27. Dec 7, 2018 at 10:48 PM
    #57
    potoghi
    potoghi Tundra4Life
    Hawaii
    United States
    Check out that upgrade :rolleyes:
    kgb4187, Jerry311SD and Matty4wd[OP] like this.
  28. Dec 8, 2018 at 5:16 AM
    #58
    Fishman57
    Fishman57 New Member
    Wayne
    Bucks County, PA
    This is my next addition. Can’t wait to do it, one it warms up a little.
    potoghi likes this.
  29. Dec 8, 2018 at 2:52 PM
    #59
    Hand Protectors
    The 02’ SR5 came OEM with this ability. Nice option. I usually keep mine on all the time in conjunction with when the headlamps are on for evening driving.
  30. Dec 8, 2018 at 7:41 PM
    #60
    Swalters
    Sam
    Arizona
    Oh nice! Stupid they didn't just continue that through the years. I love having them on anytime
