Multiple misfires after rebuild ** FIXED **
Discussion in '1st Gen Tundras (2000-2006)' started by Brynden29, Jul 16, 2022.
  1. Jul 25, 2022 at 10:43 AM
    #211
    Brynden29
    Brynden29 [OP] Just a guy who works on cars
    Brynden
    Bellville, TX
    1999 Mustang GT
    Thanks so much. I have a plan: I ordered a new ECU, it was fairly cheap, and a new wiring harness, also pretty cheap. I figure, I plan on keeping the truck forever so it might be good to have some spare parts if my ECU and harness are good. I am going to disconnect the alternator and swap the ECU, the easiest thing to try first. Then I will go with the wiring harness.
    I really appreciate all you guys help and suggestions. This has been a journey, hopefully I am getting to the end, but I will get there at some point.
    Aerindel and shifty` like this.
  2. Jul 25, 2022 at 3:46 PM
    #212
    e30cabrio
    West Valley, Phoenix, Az.
    Boosted 2013 Sequoia TRD FAUX
    I'm sorry you have this mess. I never cease to be amazed by the solidarity that members here have.
    Good luck, sorry, I have no suggestions.
  3. Jul 26, 2022 at 11:32 AM
    #213
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I just turned the ignition on with the engine off and the battery light was on, with the alternator connected. Should the battery light turn off with the ign on and the engine off?
  4. Jul 26, 2022 at 11:41 AM
    #214
    BubbaW
    Bubba
    Where Eagles Nest
    04 DC LTD 4X4 4.7 V8
    T150 Lover
    With the alternator connected, IGN ON/ENG OFF, it's normal for the Batt light to be on, along with a few other indicator lights.
    Under normal conditions, the second I turn the key to IGN ON, all the below lights are lit.....after 3 beeps?, the ABS goes out and after 5 beeps?, the AIR BAG goes out. The SEAT BELT simply continues flashing and BATT, A/T OIL TEMP, CHECK ENG stay on steady !
    from my 04 IGN ON/ENG OFF....
  5. Jul 26, 2022 at 11:46 AM
    #215
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    Ok, I unplugged the alternator and the battery light was not on with ign on eng off. It still has the same misfire though with the alternator disconnected.
  6. Jul 26, 2022 at 12:04 PM
    #216
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    What’s odd is when I run the truck without the alternator plugged in the battery light doesn’t come on. Shouldn’t the ECU notify me somehow the alternator isn’t working?
  7. Jul 26, 2022 at 12:07 PM
    #217
    It may only come on once the voltage in the battery drops.
  8. Jul 26, 2022 at 12:38 PM
    #218
    My experience in the '06 supports this theory.
    The alternator shorted, was 100% not working. I noticed battery was lower than normal a few blocks into my ride, and continued getting lower as I drove to work. Batt light didn't come on until it dropped below like 8v-9v, and at that point I was pulling into the LAPS (NAPA) to get a new battery.
    After installing the new battery, the added voltage caused something in the alternator to get red hot and catch fire. That was a fun day.
  9. Jul 26, 2022 at 12:48 PM
    #219
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I have the connectors to the ECU out in the engine bay. I want to test for continuity between the ignition coil and the ECU. Which pin do I use to test? Which pin should go to the coils?
  10. Jul 26, 2022 at 12:59 PM
    #220
    BubbaW
    Bubba
    Where Eagles Nest
    T150 Lover
    Just did some checking and looking at the EWD. I was wrong earlier with this statement....
    The warning light will not work with alternator not plugged in, it needs pin 1(yel-grn) to even work.
    While checking the backside of the Instrument Cluster and IGN ON/ENG OFF, one side of the charging light bulb is 12vdc and other side sees a GND, light on. With ENG ON, altenator working, one side of bulb is still 12 volts but other side instead of a gnd, it's 12vdc also....2 hots, no current flow.
    I'm pretty sure that's why I have seen some folks saying we can not change our incandescent charging light with an LED.
  11. Jul 26, 2022 at 12:59 PM
    #221
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    It’s normal. The internal regulator is the alternator is what turns the battery light on or off. The ECU does not control the alternator on your truck.
    Brynden29[QUOTED][OP] and BubbaW like this.
  12. Jul 26, 2022 at 1:38 PM
    #222
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
  13. Jul 26, 2022 at 1:39 PM
    #223
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    They seem good to me. The only thing I didn’t do was swap all the injectors from one bank to the other. Should I do that?
  14. Jul 26, 2022 at 2:43 PM
    #224
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    So I swapped all the injectors, same issue. While I was in there I checked the intake manifold bolts. They were a little loose so I was hoping that was the issue. Apparently not. What is odd is that while I am driving it there are no misfires in the live data. Only at idle or when I am stopped. And now it is just a couple. I am still quite baffled by this. I am back to my thought about driving it more. But I just don’t know.
    Oh, and my speedometer and odometer don’t work. Any suggestions on what to check?
  15. Jul 26, 2022 at 3:27 PM
    #225
    Idle air control valve, maybe? Is there one on the 2UZ-FE?
  16. Jul 26, 2022 at 3:31 PM
    #226
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    So I took it for another drive and now I am getting a P0100-MAF error. Do you think this could all be because my maf died?
  17. Jul 26, 2022 at 3:47 PM
    #227
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    Nevermind. I just took it around the block again and the only code I have is a P0330 knock sensor. Probably because the idle is so low it is shaking the engine and car and the sensor thinks it’s knock.
    How do I get it to idle higher?
  18. Jul 26, 2022 at 4:17 PM
    #228
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    Well, I cleared the codes and took it around the block again. I got the knock sensor code but no misfire codes. Could the knock sensor be confused because I have open pipes and it is LOUD when I drive?
  19. Jul 26, 2022 at 4:18 PM
    #229
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    One thing to remember is that the codes are the ecu’s best guess at the cause of what it is seeing. I would get the fsm procedure to check the MAF and the throttle position sensor as well.
  20. Jul 26, 2022 at 4:31 PM
    #230
    Jack McCarthy
    Bill
    North of Boston
    02 Tundra AC SR5 V8 4x4
    Take it out of drive and put the vehicle in neutral when you come to a stop. Won’t increase rpms, but it’ll take the load off the drivetrain.
    I would also recommend a bottle of dry gas.
  21. Jul 26, 2022 at 4:48 PM
    #231
    “J”
    “J” New Member
    NC
    2021 Tundra SR Barcelona Red
    Thinking outside the box, does your truck have an EGR valve? If so start the truck and let it idle and smack the egr with a dead blow hammer or like item. Old trick from years ago.
    My gut says your issue is something that was removed and reinstalled in the rebuild. Not that my gut has not been wrong. But I keep thinking that’s where the issue is.
    JuanTon21 and shifty` like this.
  22. Jul 26, 2022 at 4:54 PM
    #232
    Anything that measures air (MAF), meters air (throttle body, IAC), measures combustion on the back side (O2) could be the culprit.
    JuanTon21, dbittle and FrenchToasty like this.
  23. Jul 26, 2022 at 5:03 PM
    #233
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    The maf code is gone. I disconnected the maf while the truck was running to see what happened and it died. I’m sure that’s why the code came up. I cleared it and it’s not back.
    One question, how important is it to tighten the crank bolt to the correct torque settings? I only used a little impact gun on it and forgot to tighten it all the way. Could that be affecting the timing gear at the crank?
  24. Jul 26, 2022 at 5:04 PM
    #234
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I don’t believe it has an EGR valve, but good suggestion. I agree with you, but I don’t know what it could be.
  25. Jul 26, 2022 at 5:28 PM
    #235
    Aerindel
    Aerindel New Member
    Montana
    Its important that it not come off...but the keyway will keep it in time until that happens.
    KNABORES and FrenchToasty like this.
  26. Jul 27, 2022 at 4:05 AM
    #236
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I can’t find an idle air control valve. I found an idle control valve but it is expensive and I don’t know where it lives.
  27. Jul 27, 2022 at 7:10 AM
    #237
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    Just following up, I drove it to the muffler place today and I got 2 codes, knock sensor (I hope it will go away once I get an exhaust) and P0500 - VSS fault (which makes sense since my speedometer and odometer are not working. No misfires which is great. I wonder if tightening up the intake manifold did the trick.
    KNABORES likes this.
  28. Jul 27, 2022 at 8:31 AM
    #238
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    So where do I find the VSS? Is it the one in the wheel hub or is there one in the transmission?
  29. Jul 27, 2022 at 8:32 AM
    #239
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    This is a little like performing surgery on someone that took an ass-full of #9 shot out of a 10 gauge.
  30. Jul 27, 2022 at 8:34 AM
    #240
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    It does feel a little like that. Hopefully the issues are almost all gone.
