Multiple misfires after rebuild ** FIXED **
Discussion in '1st Gen Tundras (2000-2006)' started by Brynden29, Jul 16, 2022.
  1. Oct 28, 2022 at 6:53 AM
    #631
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Legendary tenacity.
    des2mtn, dbittle and FrenchToasty like this.
  2. Oct 31, 2022 at 4:37 AM
    #632
    N84434
    N84434 In the Frozen Tundra
    Milwaukee WI.
    2001 Limited TRD
    I do like the way my shortys sound when I'm giving it the beans, though...:burnrubber:
    BubbaW[QUOTED] likes this.
  3. Oct 31, 2022 at 7:15 AM
    #633
    Rubberdown
    True that.
    hagrid[QUOTED] likes this.
  4. Nov 11, 2022 at 6:53 AM
    #634
    N84434
    Milwaukee WI.
    2001 Limited TRD
    @Brynden29
    Updates?
    Here's hoping you are on a path to enlightenment...
  5. Nov 26, 2022 at 7:16 AM
    #635
    Brynden29
    Brynden29 [OP] Just a guy who works on cars
    Brynden
    Bellville, TX
    1999 Mustang GT
    Happy thanksgiving guys! Sorry for the delays. What haven’t had much time with the holidays to work on it. I am having the same issue, but I still drive it. I think I want to check the timing of the cams. I have not checked that yet. I think I have the instructions in the manual. I just have to find it.
    Aerindel, N84434 and FrenchToasty like this.
  6. Nov 26, 2022 at 7:19 AM
    #636
    Just in case, here ... https://www.tundras.com/threads/cleaning-the-air-ducts-06-tundra.106641/#post-2751358
    Brynden29[QUOTED][OP] likes this.
  7. Nov 26, 2022 at 7:54 AM
    #637
    N84434
    Milwaukee WI.
    2001 Limited TRD
    @Brynden29 Glad to hear you're still fighting the good fight. It'll get figured out...
    Brynden29[OP] likes this.
  8. Nov 26, 2022 at 11:47 AM
    #638
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    So from what I read it looks like I can just remove the valve cover and rotate the engine over until the marks on the back of the cams touch. If they meet then the timing should be good. If not, then maybe I have something. It does not appear to matter where the timing marks are on the crank and cams for the timing belt. I assumed that the engine needed to be at top dead center and the camshaft marks should line up, but it doesn’t appear to be the case. Unless I am missing something.
  9. Nov 26, 2022 at 2:28 PM
    #639
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    Well, it looks like I am 2 teeth off on the cams. I marked the dots with yellow. I went around 2 times just to double check but it is off.
  10. Nov 26, 2022 at 4:45 PM
    #640
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC 2wd
    At least it looks like you've found the problem.
  11. Nov 26, 2022 at 9:51 PM
    #641
    Tundra2
    Tundra2 Zoinked
    Noah
    Western Kentucky
    Well, how are you supposed to fix that? Take the cams apart?
  12. Nov 26, 2022 at 10:05 PM
    #642
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Remove and re time. Not a huge deal. Just time consuming
  13. Nov 27, 2022 at 2:23 AM
    #643
    w666
    w666 D. None of the above
    Maryland
    04 Access Cab SR5 V8 4WD
    I wonder how that happened? Did you change the cam seals?
  14. Nov 27, 2022 at 5:40 AM
    #644
    N84434
    Milwaukee WI.
    2001 Limited TRD
    In Post 24 he mentions that he swapped the cam seals, along with every other seal on the engine. It's quite possible that in focusing on the front of the engine and cam gears, alignment marks on the back side were missed.
  15. Nov 27, 2022 at 5:59 AM
    #645
    dbittle
    dbittle Middle Age Member
    Huntsville AL
    2006 V8 RCLB 2WD
    Wow. Excellent work finding the issue! Good work!
  16. Nov 27, 2022 at 6:02 AM
    #646
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I pulled the heads and replaced the valve stem seals. I assume that I miss aligned the cams when I put them back in. Total bone head move.
    w666[QUOTED] likes this.
  17. Nov 27, 2022 at 6:35 AM
    #647
    w666
    Maryland
    Alright...problem solved! Maybe check the other side too?
  18. Nov 27, 2022 at 7:57 AM
    #648
    Hopefully problem solved. Man, imagine what you'd have paid if you'd let a shop find the issue...
  19. Nov 27, 2022 at 8:58 AM
    #649
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    For sure.
    I just can’t find if the marks are supposed to line up when the car is at top dead center.
  20. Nov 27, 2022 at 9:46 AM
    #650
    NewImprovedRon and FrenchToasty like this.
  21. Nov 27, 2022 at 9:55 AM
    #651
    empty_lord
    05 rollover special
    The dual dots on one side, single dots on the other should mesh together. That’s all that’s needed there. Then set timing with the belt on the timing belt
  22. Nov 27, 2022 at 10:12 AM
    #652
    N84434
    Milwaukee WI.
    2001 Limited TRD
    @Brynden29 Maybe this will help??
    I found it in the Alldata info for our truck.
    Release the oil from the front bearing caps.
    Using SST, rotate the camshaft timing tube from left to right 2 to 3 times within its WT-i range (25°) and use a waste cloth to collect the oil from the camshaft timing oil control valve installation hole.
    SST 09960-10010 (09962-01000, 09963-00400)
    NOTICE: Approximately 20 cc (1.2 cu inch) of oil will be ejected. Take care not to spill it.
    [​IMG]exhaust camshaft with a wrench.
    (2)Secure the sub-gear to the main gear with a service bolt.
    Recommended service bolt
    HINT: When removing the camshaft, make sure that the torsional spring force of the sub-gear has been eliminated by the above operation.
    [​IMG]oil control valve filter and 2 camshafts.
    [​IMG]Open In New TabZoom/Print
    d. Remove the RH camshafts.
    (1)Bring the service bolt hole of the sub-gear upward by turning the hexagon head portion of the exhaust camshaft with a wrench.
    HINT: When removing the camshafts, make sure that the torsional spring force of the sub-gear has been eliminated by the above operation.
    (3)Set the timing mark (1-dot mark) of the camshaft main gear at approximately 10° angle by turning the hexagon head portion of the exhaust camshaft with a wrench.
    (4)Uniformly loosen the 22 bearing cap bolts in several steps, in the sequence shown.
    (5)Remove the 22 bearing cap bolts, 4 seal washers, oil feed pipe, 9 bearing caps, camshaft housing plug, strainer and 2 camshafts.
    HINT: Arrange the bearing caps for RH and LH sides.
    25. DISASSEMBLE EXHAUST CAMSHAFTS
    a. Mount the hexagon head portion of the camshaft in a vise.
    NOTICE: Be careful not to damage the camshaft.
    b. Using SST, turn the sub-gear clockwise, and remove the service bolt.
    SST 09960-10010 (09962-01000, 09963-00500)
  23. Nov 28, 2022 at 5:46 AM
    #653
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    I’ve been driving my truck with this issue, do you think it is safe to drive with the cam gear timing off? It drives terrible and has no power but can I hurt the motor?
  24. Nov 28, 2022 at 9:49 AM
    #654
    EvilMilkshake
    EvilMilkshake New Member
    05 AC Limited 4x4
    shifty` likes this.
  25. Nov 28, 2022 at 9:50 AM
    #655
    empty_lord
    05 rollover special
    Misfires will cause premature wear to the pistons and cats. Enough pre detonation can lead to shattering the piston or destroying rod/main bearings
  26. Nov 28, 2022 at 10:16 AM
    #656
    N84434
    Milwaukee WI.
    2001 Limited TRD
    But how much actual driving has it done? I would assume nothing too detrimental has been done.... yet..
  27. Nov 28, 2022 at 10:17 AM
    #657
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    Unfortunately no, I did not put the service bolt in. But I will this time.
    Jack McCarthy, shifty` and N84434 like this.
  28. Nov 28, 2022 at 10:19 AM
    #658
    N84434
    Milwaukee WI.
    2001 Limited TRD
    Well, here's hoping this can get squared away with no residual damage..:hattip:
  29. Nov 28, 2022 at 11:14 AM
    #659
    Brynden29
    Brynden
    Bellville, TX
    1999 Mustang GT
    Since I didn't put the bolt in the first time, is there anything I need to do to the cam once I get it out? Or can I just put a service bolt in, pull them out, line them up correctly, and then put it all back together?
  30. Nov 28, 2022 at 12:13 PM
    #660
    EvilMilkshake
    05 AC Limited 4x4
    If it's rotated, you probably won't be able to get the service bolt into both sprockets. You'll need to take out the cam, rotate/disassemble it, then put the service bolt in. I've never not put the bolt in a scissor gear, so I'm not sure. Doesn't look like the cam is too complex from that video, so here's hoping.
    N84434, shifty` and NewImprovedRon like this.
