Multiple beeps?
Discussion in '3rd Gen Tundras (2022+)' started by Kozzmosis, Feb 13, 2025.
  1. Feb 13, 2025 at 3:14 PM
    Kozzmosis
    Kozzmosis [OP] New Member
    Michigan
    2024 tundra 1794 Mesquite
    Timbren
    I like to keep the truck running when I go into a store. (In the winter or summer when it's hot) When I leave the truck to go in and I go to lock the truck with the key fab it gives out a multiple of beeps. Do the doors lock or not? I can't tell because I have the key fab on me and when I grab the handle it opens up, just wondering if the truck locks while the truck is running? Thanks
  2. Feb 13, 2025 at 3:15 PM
    tweezy
    tweezy New Member
    PA
    2024 Blueprint Tundra 1794
    I do the same thing often I believe all the doors remain unlocked and it beeps stating the key is not in the truck. More of an alert I believe
    22whatwedo likes this.
  3. Feb 13, 2025 at 3:16 PM
    TexasCabledawg
    TexasCabledawg New Member
    2024 Land Cruiser (had a ‘22 Tundra)
    I always shut it down, locked it then use the remote start to be in the safe side.
  4. Feb 13, 2025 at 3:31 PM
    Kozzmosis
    Michigan
    Timbren
    That's what I was thinking also. Thanks
  5. Feb 13, 2025 at 3:50 PM
    Blufin
    Blufin Seasoned member
    Bob
    Cape Cod,MA.
    23 WCP Capstone 26 WCP 4Runner Platinum
    I too lock it and start it with the fob ect...
    So since we are on the topic and I'll ask for a friend :D
    What if one was to leave it running and you have the fob and someone jumps in and takes off,will the truck turn off when it gets out of range, and if so what's the distance and has anybody tried this scenario?
    1lowlife likes this.
  6. Feb 13, 2025 at 3:53 PM
    Kozzmosis
    Michigan
    Timbren
    :notsure: good point
  7. Feb 13, 2025 at 6:49 PM
    Rockpig
    Rockpig You did what?
    08 Limited
    No idea what happens but try it by just leaving it running and walk down the street, see how far you get.
  8. Feb 14, 2025 at 7:57 AM
    TexasCabledawg
    I know that someone can drive off without a fob. My wife did that and I had to hurry up and call her and told her not to park and shut the truck off.
  9. Feb 14, 2025 at 9:21 AM
    Wolfhound89
    Wolfhound89 New Member
    2024 Tundra TRD Off Road
    It doesnt shut off if you drive off without the fob.
    To leave it running for a store or whatever you need to physically lock it with the key in the door handle. Then unlock it the same way.
  10. Feb 14, 2025 at 2:01 PM
    hinkle
    hinkle New Member
    aaron
    portersville, pa
    '23 Blueprint
    Try doing the three fingers on the front part of the door handle. That will lock all your doors.
  11. Feb 14, 2025 at 2:09 PM
    Kozzmosis
    Michigan
    Timbren
    Gotta try that
  12. Feb 14, 2025 at 7:54 PM
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    It will give a warning that they fob is not present. You can drive till you run out of gas or until you turn it off. You can't start it if it is turned off.
    Raven67 likes this.
  13. Feb 14, 2025 at 8:32 PM
    1lowlife
    1lowlife Toxic prick and pavement princess
    DADA
    THE GREAT STATE OF TEXAS
    On my 3rd Tundra 2005 DC 2014 DC 2026 CM Limited
    At least if you shut it off, lock it, and restart it with the key fob;
    The engine dies when you open the door, or it dies when you step on the brake to put it in gear, depending on your remote start.:thumbsup:
  14. Feb 14, 2025 at 8:42 PM
    mrlittlejohn
    mrlittlejohn New Member
    Michael
    2022 Toyota Tundra Limited
    Doesn't it shut off after a relatively short time if started by the FOB?
  15. Feb 14, 2025 at 9:01 PM
    22whatwedo
    22whatwedo New Member
    The Open Road
    22 SR5 TRD OR Army Green
    The dash says it will shut off after one hour of idling
  16. Feb 14, 2025 at 9:04 PM
    mrlittlejohn
    Michael
    Hmmmm, I thought mine shut off after a fob start and was much less than that. Does the AC blow cold with a fob start? In case I have my doggies with me and they can stay in the truck.
  17. Feb 14, 2025 at 9:08 PM
    22whatwedo
    The Open Road
    I dont know, I idle very little. But if you sit and idle in park, my truck flashes that message at me, but I don’t use my fob or app to start either.
  18. Feb 15, 2025 at 6:47 AM
    Matt2015Tundra
    Matt2015Tundra New Member
    2023 1794 CrewMax
    Remote start with the FOB or App shuts off after 10 minutes.
    mrlittlejohn likes this.
  19. Feb 15, 2025 at 4:03 PM
    22whatwedo
    The Open Road
  20. Feb 15, 2025 at 4:26 PM
    mrlittlejohn
    Michael
    that’s for when you are in the truck and start with foot on the brake.
    I don’t think that’s for remote starting.
    Blufin likes this.
  21. Feb 15, 2025 at 6:00 PM
    Blufin
    Bob
    Cape Cod,MA.
    Correct.
  22. Feb 15, 2025 at 7:14 PM
    22whatwedo
    The Open Road
  23. Feb 15, 2025 at 10:50 PM
    gdisarray
    10 minutes, just like the remote start in the app. Max times doing it in a row is 2 as well.
