MTwiford's Audio Build
Discussion in 'Audio & Video' started by MTwiford, Aug 17, 2017.
  1. Aug 21, 2017 at 6:11 AM
    MTwiford
    MTwiford [OP] The second mouse always gets the cheese
    2025 Platinum TRD Magnetic Gray
    Here are a few pictures of the wiring to the factory harness. Im going to fabricate some type of rack to mount the JL processors to at some point. Need to buy a router table though.
    IMG_0754.jpg IMG_0755.jpg IMG_0753.jpg IMG_0757.jpg IMG_0758.jpg IMG_0759.jpg
  2. Aug 26, 2017 at 2:49 PM
    MTwiford
    Subs are in. I went with JL TW3s.
    ADD48D73-DE46-4F77-905A-EB3DB01435C0.jpg C4F47BA1-6E04-4CF3-BA95-67056F4E46A4.jpg D1331A10-F63B-4785-ABE8-3B680FF1B41B.jpg 89748012-C5DC-4343-906C-7F87E2781DDF.jpg
    CJ21 and Newm like this.
  3. Oct 24, 2017 at 9:27 AM
    mcoyken
    mcoyken New Member
    2017 Platinum Tundra
    Do people generally disconnect the dash speakers and just run 2 sets of components off the new amp?
  4. Oct 24, 2017 at 9:46 AM
    MTwiford
    Its all personal preference and depends on the equipment you buy. If you have good components for the front, you dont really need anything else. You can buy other speakers for the rear, but you are not going to hear them. But you can replace the dash speakers and run them to a separate amp if you like. All comes down to how much you are willing to spend. For me, the Focal KX2's are so loud that I cant even turn them all the way up and drive that way.
  5. Oct 25, 2017 at 3:13 AM
    MikeyMTBs
    MikeyMTBs New Member
    I too disconnected the dash speakers. I am running Infinity Kappas and they are so clear and have such a great stage, that the dash speakers just muddied he everything.
    TheBeast likes this.
  6. Nov 1, 2017 at 5:21 AM
    Cfincke
    San Antonio
    @Danimal86 - did you see this build, very similar to what you and I are doing. This definitely helped me understand the JBL harness to the JL Fix.
    MTwiford[OP] likes this.
  7. Nov 1, 2017 at 11:11 AM
    non-ricer
    non-ricer New Member
    2018 Cement Crewmax limited
    This thread is awesome. It’s going to help me out so much. Thanks for starting this thread!
  8. Nov 1, 2017 at 11:40 AM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
    I did. Very good post showing the the connections. I don't have the jbl system, hopefully it will be a little easier for me since i'll be yanking out the factory amp.
  9. Nov 8, 2017 at 5:28 AM
    MTwiford
    It will definitely be easier without the JBL system.
  10. Nov 8, 2017 at 5:41 AM
    BlueBottle
    BlueBottle not a PRO
    '16 Platinum 4x4
    See fine print
    This is great @MTwiford thanks for sharing.
  11. Nov 8, 2017 at 6:13 AM
    MTwiford
  12. Dec 10, 2017 at 6:45 PM
    tundriver
    tundriver New Member
    Puyallup
    2017 Tundra Crewmax Limited
    Linex Bed Spray, Tint matched, Truck Gear tonneau cover,6112 Bilstein and 5100.Black Rhino Warlord on Nitto G2.
    @MTwiford , nice post. Did you replace speakers wires on this build?
  13. Dec 11, 2017 at 5:54 AM
    MTwiford
    Yes, I ran all new JL Audio wiring. 16g for the components and 12g for the subs
    Heatonrx likes this.
  14. Dec 14, 2017 at 5:26 AM
    MTwiford
    Sorry, 14g for the components
  15. Dec 22, 2017 at 12:40 PM
    JoeJob
    JoeJob Drummer for Booty and the Hoe Fish
    Joe
    New England
    2018 Tundra Limited CM Silver Sky
    TRD rear sway bar, console organizer, stubby antenna, LEDs for cabin, cargo, license plate, and reverse lights, power-fold mirrors, Westin nerf bars, full stereo upgrade. Future - color-match grill surround/bulge, mirror caps, handles, plasti-dip badges.
    Nice write-up! I will be keeping an eye on it as I will be picking up a 2018 Limited in April and I will most likely end up with the JBL system. Question: Are you just using the JL FIX/TWK volume control for Sub level or are you using it for master volume as well? I have read that the factory volume works fine as long as the factory system doesn't have volume-dependent EQ. I can't find anywhere that states whether or not the Tundra JBL system adjusts EQ based on volume.
  16. Apr 8, 2018 at 8:40 AM
    Heatonrx
    Heatonrx New Member
    Did you end up finishing off the spot you put your amp? I'm doing the same thing but also putting my Fix86 back there to. I thought maybe I'd just cover a piece of board w/ carpet. Not sure if the truck carpet on the sides will be good enough or trim it in wood and cover w/ carpet too. Your project look great.
  17. Apr 8, 2018 at 7:29 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
  18. Apr 10, 2018 at 12:53 PM
    MTwiford
    I havent yet. I recently purchased a router and Im going to start messing with making a trim piece for it once it warms up. Im also going to make a box frame for the amp to sit in. Probably going to use recessed magnets to easily connect/disconnect the trim piece in case I need to get to the components. Thanks!
  19. Apr 10, 2018 at 7:35 PM
    #49
    Heatonrx
    Heatonrx New Member
    Thanks for posting your wiring. James from Tech12volts told me not to hook the sub inputs. I asked why but he hasn't replied yet. He's been a great help setting my harness up. Did you leave this like your pic? Not sure why I wouldn't use the sub input from the oem amp to the Fix86.
  20. Apr 10, 2018 at 9:48 PM
    #50
    Eclipsed & Floating
    I’m right where I need to be
    Voluptuous Whitey
    Are you not nervous about the amp overheating in the foam?
    By the way....I have the exact same audio build with the exception of the crossover and TWK, which I’m not sure I’d know how to use. I don’t have your skill so I had it all installed by someone else, but I’m like you....I want quality sound over anything else. I don’t need to rattle any houses but I do like to hear a ckean sound when cranked up
  21. Apr 14, 2018 at 6:34 AM
    #51
    Heatonrx
    Heatonrx New Member
    James says the output for the sub from the JBL amp is "dirty" and it can cause clipping. He said not to use it. Since I ran the output to my Fix86 in the harness I set up I might try it both ways.
  22. Apr 15, 2018 at 9:41 AM
    #52
    Firepilot
    Firepilot New Member
    Great thread, I have a New Limited 2018 Tundra with the JBL with nav. I do like the features it has but not the sound.
    I traded a 2017 Double cab SR5 and had the Kenwood ddx9903s, Hertz front components, Hertz Coax in the rear and a JL 10W3 Sub running off a Phoenix Gold 1200.5 amp. I kept that system and put the stock system back in when I traded it in. The system sounded great and was perfect for my needs. The Kenwood system was good but I didn't use many features except Apple Play after initial setup. Also about tired of the warning screen that has to be cleared each time it starts, and the tiny volume buttons on the unit. I don't always want to use the steering wheel controls.
    I would put the whole system in the new truck but don't want to loose the features in the "heads up display" I like the turn by turn, radio in the display and such. Also not sure but it sounds like the parking assist things don't work with it.
    It sounds like I could add the JL fix 86 to this system. I could use the components I already have with the exception of the Kenwood HU and have a pretty good system.
    With your install using the stock Headunit and the Fix 86 are you happy with the overall sound? It sounds like you have the experience to give a pretty good opinion. Thanks for the great writeup. It gives a guy more options to consider. I am not an audiophile by any stretch, just like my 80's rock and stuff to sound great and loud when I am cruising.
    Phil
  23. Sep 25, 2018 at 6:09 PM
    #53
    xodeuce
    xodeuce New Member
    Keith
    With those Focal speakers and the trim rings in the door woofers, are you still able to roll your windows down? I'm trying to figure out my mounting depths to see if the 77mm mounting depth is a problem. I talked to Crutchfield, and they said you could space it out far enough, but that it would get into the door panel if it was spaced out enough for the magnet to clear the window when rolled down. I don't know if their measurements are right though.
  24. Sep 26, 2018 at 7:39 AM
    #54
    xodeuce
    xodeuce New Member
    Keith
    Also, what sub box is that, and do you know the interior air volume?
