MPG's
Discussion in '2nd Gen Tundras (2007-2013)' started by Agitated1, Nov 18, 2016.
  1. Apr 5, 2017 at 11:32 AM
    BigCountry
    BigCountry New Member
    Garrett
    Edmond, ok. (Arkadelphia, Arkansas, school)
    2009 5.7L flex fuel, 4wd, sr5.
    Leveling kit, 20" hostage fuel rims, mangmum flow dual pipe, and bull guard.
    I ment to type 24 . So it's 26.4 gallons eh? Everywhere I looked they read 24.
  2. Apr 5, 2017 at 11:44 AM
    ej63090
    ej63090 New Member
    Eric
    McHenry, Illinois
    2017 White Crewmax SR5
    Mine has been slowly climbing up to 14.6 hwy/city mix since I bought it to about 1400-1500 miles. The transmission's ECU needs to learn how you drive and make it past the break in period. With the summer fuel coming I hope I can get it up to 16 before knocking it down with lift/tires.
  3. Apr 5, 2017 at 11:44 AM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    Yep. for second gens, just google 2007 toyota tundra gas tank size
    3rd gens are 26.4 to 38, depending on options
  4. Apr 22, 2017 at 1:40 PM
    AuMiner
    AuMiner New Member
    White 2007 Toyota Tundra SR5 DC
    I have an 2007 5.7 with 35's and a 2' lift. MPG = 15-16 with a mix of hwy and city
  5. Apr 30, 2017 at 9:18 PM
    JTP
    JTP The Big Black Moose
    Sterling, Alaska (Formerly DFW Texas)
    The Big Black Moose
    Im now getting 14 Highway mpg at 75mph and around town is about the same. K&N air filter, 7" lift, 5.7L 4x4 CM with 37x12.5x20 Nitto Terra Grappler G2's at 60psi.
  6. May 1, 2017 at 3:55 AM
    VBSR5
    VBSR5 New Member
    2014 Tundra Crewmax
    BDS 7" Suspension, 20 " XD Wheels, 35" Toyo R/T, Spyder Headlights, BakFlip G2 Bed Cover, Bilstein 5100s, Bull Bar (LED bar, LED fog cubes)
    My truck is a 14 with 49,000 miles. I do a lot of driving. With my leveling kit and 33s I was getting 14.2, now with this new lift kit I haven't had it long enough to get an accurate MPG. When I first got the truck all stock was 16.8. Id say theres something wrong, that's bad MPG unless you have a really heavy foot.
  7. May 1, 2017 at 4:34 AM
    DVYota
    DVYota Super stock street truck
    South Carolina
    2014 Sequoia 2021 Tacoma
    Basically stock
    Non-ethanol fuel will give you better fuel economy. You have to find the sweet spots for driving... I feel like over 65 the mpgs start to drop. With 3" leveling kit and 295/70r18 nittos I got 14mpg running 70ish through mountains in NC and TN this past weekend. In SC where it's mostly flat I was closer to 16mpg. If I get on it a lot around town I get 11mpg. I do have a 4" Banks cat back exhaust though
    JTP likes this.
  8. May 1, 2017 at 5:31 AM
    Bear
    Bear Fargin' Iceholes
    Bear
    Custer, SD
    2022 GMC Sierra 3500 Dually
    Pulsar Edge V3; MBRP side dump exhaust
    Yeah dude, something's up. My last 4 tanks after the 6" lift and 35 M/T's added I saw my number dip a bit. My first tank was at 14.9 (yikes) and the one after that 15.1
    I went back to the shop and got them to do a no kidding, take your time, get the alignment spot on kind of job. The two tanks following the alignment were both at 16 on the money.
    Driving habits are crucial to mpg as well. I tend to coast whenever I can. I use the cruise control, even in town when I can. Anticipate traffic lights. I tend to drive like I don't have brakes as well.
    Check all your fluids...at 44k, your are more than likely due for dif fluid changes (don't forget center dif as well). Plugs, pcv, filters. MAF...I even clean the throttle body itself very 15k or so miles.
    Tire pressures can be crucial too.
    Let us know if you've gotten anything better and what you did
    EDIT: Make sure you're accounting for different tires size from stock as well when crunching your mpg. Larger tires log LESS miles actually travelled in the odometer. If you're tire difference was 10% greater than stock, let's say, then your mileage will be off by roughly the same amount. On a 400 miles trip on the odometer, you would have ACTUALLY driven 440 mi
  9. May 1, 2017 at 5:38 AM
    niru316
    niru316 New Member
    2017 Tundra TRD Pro CrewMax
    what app is that?
  10. May 1, 2017 at 5:39 AM
    Bear
    Bear
    Custer, SD
    Fuelly, Gas Tracker Plus
    ColoradoTJ likes this.
  11. May 1, 2017 at 5:54 AM
