Mpg loss after level kit?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Erick, Dec 4, 2018.
  1. Dec 4, 2018 at 9:35 AM
    Erick
    Erick [OP] New Member
    Erick
    Thornton Colorado.
    Bronze 2016 SR5 TRD. CM cab.
    HID lights, Duratracs, Bilstein 5100's, 2" Spacer, Sumo springs.
    Mph loss after lift?
    I went from 17mpg with stock tires to 15mpg after I purchased duratracs, now I get 13mpg with a 3" and 2" rear level. Is this normal? I'm okay with it, I love the way she looks now with a slight lift.
    Thanks.
    Hammerhead, Rica25 and mr_souc like this.
  2. Dec 4, 2018 at 9:41 AM
    Erick
    Erick
    Thornton Colorado.
    Just a block in the back.
    I had 5100 installed in the front and got a 2.9" from the stock height.
    I did use a block in the back.
    It's a 2016 crew max. Sr5 trd.
    I'm going to toss the front block, everyone on this forum told me it was a bad idea to install it.
  3. Dec 4, 2018 at 9:43 AM
    NjPro
    NjPro New Member
    Tom
    Nj
    2017 Trd Pro Tundra cement
    Magnuson supercharger, Sprint booster, CB TRD PRO kit, 295/70/10 terra grapple G2, Black TRD shift knob, Rhino shackle hitch, Lund Tri-fold bed cover, 1.25 Spidertrax wheel spacers. TRD rear sway bar. Bud Built cross member. Arb Diff breather. Grab handle installed. 2012 DC SR5 TRD Supercharged, Gone but not forgotten.
    I would think it’s normal. Probably more drag on your truck as you drive down the road.
  4. Dec 4, 2018 at 9:44 AM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    That’s normal. Heck, I wish I got 13mpg!
  5. Dec 4, 2018 at 9:50 AM
    GiantsFanDan
    GiantsFanDan New Member
    2014 Silver Sky Tundra Ltd TRD OffRoad Dbl Cab
    That sounds pretty normal. You’re changing the aero dynamics of your truck. I’m assuming you went with larger tires so that drops millage also.
    GODZILLA likes this.
  6. Dec 4, 2018 at 9:55 AM
    matictundra
    matictundra New Member
    Franco
    AZ
    2017 Red Tundra SR5 4x4 CM
    3"/1.5" Lift (Fox 2.5 DSC all around, JBA UCA's and Toytec Shackles at 1.5") Front and Rear TRD Sway Bars Nitto Ridge Grappler 37x12.5R18 w/ Brz 18x9 +25mm Methods MR701 Wheels AFE Dry Filter with TRD Flow Acc Dirty Deed No Muffler Exhaust Nitro 5.29 Gears RCI Engine, Trany/Trans-Case and Fuel Skid Plates Relocated Rear Diff Breather | Rear Brake Line Extension Jomax ABS Sensor Armor Colored Matched Front Bulge and TRD Pro Grill Assy Modded ADD Stealth Fighter Front Bumper Custom High Clearance Rear Bumper with Modded Tow Receiver Behind Plate and Chopped Rear Fender Custom Bed Stiffeners 2019 TRD PRO LED Headlights w/ Ihacker Harness | BD 40" ARC AMB/WHT DC OnX6 BD 10" Onx6 in the Grill (2X) Rago Low-Profile Ditch and Extended Brkt with Daul BD Squadron Pros - AMB & WHT AMB LED Chase Light (Cargo) | Dual BD Squadron Sports in Rear Bumper Prinsu Roof Rack with a Pair of BD S1 For the Sides and Rear Mictunning C2 Rock Lights, 2 per wheel, and Toyota style switch 2X 55" Quick Light Whips with Toyota style switch Switch Pros SP-9100 with Custom Switch Mount, Custom Engine and Roof Terminal Junction Boxes 12K Lbs Smittybilt Winch with wireless remote and Factor 55 FlatLink E Amp Power Step EVO-One Remote Start Limo Tint (All Around) | De-Badged LED Interior lights with Front / Rear Interior Footwell LED Blue LED Lit Lock/Window Switch Mod AJT Full Chrome Delete Kit w/ 3R3 Painted SHCS Toyota LED Bed Lights Leather Perforated Wrapped Steering Wheel Black TRD Shift Knob ESP Long Box BakFlip MX4 Bed Cover Thinkware Q800Pro Dashcam (Front & Rear) Rago Dashmount w/ Ram Phone Holder
    Normal. Get even worst with bigger tires, lol.
    Rica25 likes this.
  7. Dec 4, 2018 at 9:58 AM
    Grumpy Uncle
    Pat
    CO
    You made a 6500lbs brick less aerodynamic.
    GODZILLA, ZPMAN, Ronin and 4 others like this.
  8. Dec 4, 2018 at 10:09 AM
    Stumpjumper
    Stumpjumper Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    yep, this is why all the manufacturers are lowering their front ends and using valances. Don't forget if you increased the tire diameter your ODO is reading low and so are MPGs.
  9. Dec 4, 2018 at 10:16 AM
    Grumpy Uncle
    Pat
    CO
    Exactly! The good thing is the OP said, he can accept it and wants improve on his current lift.
    Black Wolf likes this.
  10. Dec 4, 2018 at 10:21 AM
    ToyotaTundraMike
    2015 Tundra
    Totally normal. Went from averaging 16-17 to averaging 13-14 just by leveling out the front end and going up to 275/70/18.
    Hammerhead likes this.
  11. Dec 4, 2018 at 10:30 AM
    I'm almost at 11 mpg average now.......my normal
    GasGuzzler and Toyokuhl like this.
  12. Dec 4, 2018 at 10:43 AM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    Eh? My calculations might be off, but you’re about 1000 pounds high there (curb weight). 6500 pounds is F250, 3/4 ton territory. Our little trucks are about the same weight as an average SUV.
  13. Dec 4, 2018 at 11:00 AM
    Ronin73
    Ronin73 New Member
    2019 Tundra Crewmax SR5 4x4 5.7 Magnetic Grey Metallic
    What size tires did you have on it before? The 255?
  14. Dec 4, 2018 at 11:18 AM
    ninjajay
    Spoolston, TX
    2018 MGM 1794 TRD 4x4
    When I leveled my 2nd gen there was no loss in MPG (didn't change the tires)
    15whtrd likes this.
  15. Dec 4, 2018 at 11:18 AM
    matictundra
    Franco
    AZ
    I had my truck on the scale over the weekend, she weigh in at 6420 lbs.
    panicman, Ronin, ColoradoTJ and 4 others like this.
  16. Dec 4, 2018 at 11:25 AM
    ToyotaTundraMike
    2015 Tundra
    Yeah the stock P rated Michelin’s, believe they were indeed 255.
  17. Dec 4, 2018 at 11:26 AM
    mr_souc
    mr_souc New Member
    Joel
    Maine
    2014 Tundra TRD Off-Road CrewMax
    - 3/2" Leveling/Lift - TRD Dual Exhaust - TRD Pro Grill - 32 Inch Light Bar - N Fab Step Rails - Color Match Bumpers - 285/75-18 Terra Grappler G2s
    I'm getting about the same millage as you shared. I have a similar set up and average right around 15 mpg with a 80 mile round-trip commute to work daily, of which 60 miles is highway at ~70 mph...
  18. Dec 4, 2018 at 11:27 AM
    Warreng
    Warreng New Member
    Looks over function is a very common theme in todays society.
    Kn4x2 likes this.
  19. Dec 4, 2018 at 11:39 AM
    Grumpy Uncle
    Pat
    CO
    My truck hasn't seen it's factory curb weight since I have owned it. Mods equal more weight, (not being snarky).
    I have a topper that weighs in at 290lbs (re-enforced roof)
    add wt for bigger tires
    add wt for re-gearing and Auburn LSD
    add wt for aftermarket wheels
    add wt for the 2-40ish lbs pelican cases I always carry
    It all adds up. I am a biscuit heavier that Franco @matictundra
    ColoradoTJ and 15whtrd like this.
  20. Dec 4, 2018 at 11:41 AM
    matictundra
    Franco
    AZ
    Ahhh, don't get a truck?
    15whtrd likes this.
  21. Dec 4, 2018 at 12:45 PM
    B737
    Jersey Shore
    Ahh I see, adds up fast
    ColoradoTJ likes this.
  22. Dec 4, 2018 at 12:48 PM
    Grumpy Uncle
    Pat
    CO
    Yes, sir! It sure does...
  23. Dec 4, 2018 at 1:07 PM
    Atomic City Tundra
    Devin
    New Mexico
    2013 Tundra 5.7FFV CM 4X4
    Welcome to Physics 101.
    ninjajay likes this.
  24. Dec 4, 2018 at 1:41 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
    My truck sits about 6200lbs with a few mods
    15whtrd likes this.
  25. Dec 4, 2018 at 1:49 PM
    B737
    Jersey Shore
    Which puts you within about 300 pounds of max payload :thumbsup:
  26. Dec 4, 2018 at 2:56 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Hmm my math must be wrong then...
    Curb is 5760lbs
    Payload 1440lbs
    Gross 7200lbs
    7200 - 6200 = 1000lbs
    15whtrd and B737[QUOTED] like this.
  27. Dec 4, 2018 at 3:18 PM
    B737
    Jersey Shore
    Argh, I’m looking at the wrong #’s like an idiot, used the wrong source.
    Ronin and 14burrito like this.
  28. Dec 4, 2018 at 3:22 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Had me second guessing myself lmao!
  29. Dec 4, 2018 at 6:11 PM
    mambo143
    mambo143 New Member
    Phil
    Maine
    2016 Tundra TRD Crewmax
    Bilstein 6112, 5160, Coachbuilder 1” shackle lift, Wildpeak A3’s, LED backup, Maxiplus mats, Bak Rollover Mx4, BedRug, Westin HD Headache Rack. Westin HD Brush Guard, Spidertrax 1.5 spacers. TRD Brakes. Headlight Revolution LED. TRD rear Torsion Bar. Dirty Deeds 10 inch Stainless. TRD Pro Grill. Bushwhacker Pocket Flares. Baja Designs Combo Driving/Fog lights.
    With the OEM 275 65 Michelin’s I was getting 18+ on the highway. Actually got 20 on on 40 mile trip in hilly country trying hard to max the mileage. I then went with 275 70s 10 ply AT’s which are a much heavier tire, and a 2-1 lift and saw mileage drop to 16.6 MAX! highway-not tromping on it. I figure to add .5 MPG at most for the larger diameter/mileage error. We have to pay to play
    I had a stock Ford ranger with a V6 that got worse mileage in town and the same on the highway.
  30. Dec 4, 2018 at 6:22 PM
    Blueline
    Blueline New Member
    Jeb
    Temecula, CA
    2016 Tundra TRD PRO crewmax
    Bakflip MX4
    You want a more aerodynamic stance for better mpg, try this.
    619Tundra, Ely010606, ZPMAN and 5 others like this.
