MPG display wacked out
Discussion in '2.5 Gen Tundras (2014-2021)' started by Stumpjumper, Aug 28, 2017.
  1. Aug 28, 2017 at 3:23 AM
    Stumpjumper
    Stumpjumper [OP] Not a new member
    Fate, Tx
    2017 Tundra TSS 4x4
    First 500 miles it read consistently in low 17s. I towed boat about 150 miles and of course it read much lower. Then first trip after towing I reset it. It read in the mid 15s on hwy for about 40 miles. I reset again for return trip on now it is back to mid 17s. It is almost like it had a hangover from towing and just needed to be reset a couple of times.
  2. Aug 28, 2017 at 4:36 AM
    chphilo
    chphilo Tundra addict
    Western PA
    Your ecu will adjust to the way you drive. If you want to speed up the process, then disconnect the negative end of the battery for about 1/2 hour, then drive the way you normally drive.
