MPG - 13.5????
Discussion in '3rd Gen Tundras (2022+)' started by HulkHog, Jul 8, 2024.
  1. Jul 9, 2024 at 2:46 PM
    HulkHog
    HulkHog [OP] New Member
    2024 Limited Nightshade - 3” dealer lift w/ 20 in. wheels; Nitto RidgeGrappler 35x12.50R20LT
    Thanks for the help, and yes, I did “want” this setup but it was done by the dealer and modded before I ever laid eyes on it. Since I’ve never had a truck outfitted like this I’m new to the learning curve here. So, appreciate the hepp!
  2. Jul 9, 2024 at 2:53 PM
    teab
    teab 2023 Platinum w/ PRO bits
    Ty
    Denver
    2023 Platinum MGM 6.5
    TRD Pro Wheels, Go Rhino D6, Airlift bags/compressor, Talons Alum Cat Shield, Cheap-o Amazon Mud Flaps, Fastop Tonneau/Topper, Rear TRD Pro Shocks
    Ahh with that context that makes more sense, so yeah you have nothing to compare to it before because its been that way since you got it....yeah you won't get great mileage with a lift and 35's (you never stated what size you have or if they are E rated tires, but if its dealer installed its probably the cheapest chunky tread they could find). You might get another mile or two per gallon once broken in but don't hold your breath and the speedo being off makes a bit of difference. If your 65mph and under you'll get better mileage too, anything above 65 and the mileage takes a dive.
  3. Jul 9, 2024 at 3:21 PM
    HulkHog
    Roger that. Nitto RidgeGrappler 35x12.50R20LT
  4. Jul 9, 2024 at 7:23 PM
    teab
    Ty
    Denver
    Well shit those are F rated tires and are 71 lbs a piece (stock mildpeaks are mid 40's) hope your running those around 45 to 55 psi because if not the creates some rolling resistance. D rated tires usually recommend about 10% over stock, so F is probably over that. That will knock some old MPGS off, I personally would explore running a little smaller 34-ish tall tire and decrease that width a bit if you want a mpg or two and a softer ride as well. E rated tires are overkill and F is just ridiculous.
  5. Jul 10, 2024 at 1:39 PM
    dagooaz
    dagooaz New Member
    Dave
    2024 Tundra TRD Off-Road Limited Solar Octane
    Most 35s nowadays are F rated. They do have some in that size that are D rated, but very few. I have the Falken Wildpeak AT4Ws and they only came in F load for the 35/12.50R18. They are heavy, but the truck rides great, and damn these tires look good.
    HulkHog[OP] likes this.
  6. Jul 10, 2024 at 3:24 PM
    Tyrus001
    Tyrus001 New Member
    Ty
    2021 Crewmax
    Seems like they could’ve come up with a 10-speed transmission and accomplished everything they did with the V6
  7. Jul 11, 2024 at 8:35 AM
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    MPG concerns? Clearly a function of the right foot, tires, rolling resistance, head winds, terrain, weight loaded on truck and the list goes on.
    Just saying, just came back from vacation. 1000 miles. Four people, bed fully loaded. Running anywhere up to 80MPH but most in the 72-75 MPH range and averaged 18.8MPG.
    No complaints.
    PS: AC works great...runs at 38 degrees all day.
  8. Jul 11, 2024 at 8:46 AM
    cmiles97
    cmiles97 New Member
    2018 Toytota Tundra SR5 4x4 XP
    XP package
    These are my favorite threads, 1st started when Ford put an Ecoboost into the F150 in 2011. You can count on them all the time with turbo/hybrid trucks.
    I am OCD about research before buying a vehicle and folks that start these threads apparently do none.
    My response every time.
    Why does my prius get bad mpg?
    75tranzam and Hadelson like this.
  9. Jul 11, 2024 at 8:49 AM
    cmiles97
    cmiles97 New Member
    XP package
    People wonder why the 2.5 Gen Tundras get bad MPG with 4.3 gear ratio with the 5.7L
  10. Jul 11, 2024 at 10:33 AM
    ARB1977
    ARB1977 New Member
    Anthony
    DFW
    24 Tundra CM SR5 4x4 CSM build date 05/24
    I did loose a few mpgs taking the air dam off. Stock everything except AFE Prodry air filters. Was getting 22.5…now 20.5 ish.
