Moving to AZ - research thread
Discussion in 'Arizona' started by Breathing Borla, Aug 10, 2024.
  1. May 15, 2025 at 11:13 AM
    #421
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    :bananadance::bananadance::bananadance:
  2. May 15, 2025 at 12:47 PM
    #422
    Azblue
    The Dirty T ( ^_^)_且
    Great, so when is the move in party? I suggest Mexican food and lots of Miller Lite.
  3. May 15, 2025 at 1:25 PM
    #423
    Breathing Borla
    Breathing Borla [OP] I'd rather be fishing
    Northern Illinois
    I only have 3 bathrooms, lol, HA:bucket:
    TRDFerguson and Azblue[QUOTED] like this.
  4. May 21, 2025 at 9:52 AM
    #424
    Breathing Borla
    Northern Illinois
    ok pool pros,
    Im going to start from the beginning and work with a company out there to design and get some budget ideas rolling.
    what considerations are important
    here is what the prelim thought is
    1) freeform pool
    2) salt water
    3) propane heater (for special occasions)
    4) Im going to pass on the integrated spa and go with a vaulted hot tub later for more therapeutics.
    5) I want a more natural rock and minor landscaped area around most of it with the exception of between the crib and pool, so no 100K of travertine
    6) smooth pebble tech blue surf color
    7) want some water features if it works with the budget
    8) cool lighting a must, not just one light on a side like old days
    not sure on a solar cover, have to talk to them to see if they can intragrate one or what
  5. May 21, 2025 at 10:13 AM
    #425
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Sand, DE or cartridge filter? I've had all 3 and prefer the cartridge. I typically remove and rinse them in Mar/Oct and will go 2-3 years with a set, YMMV.
    In ground sweepers or mechanical cleaner...you'll need a dedicated vac line for that. Currently have in ground but didn't mind the mechanical in the old pool.
    Def add an aerator and auto fill leveler.
    Breathing Borla[OP] likes this.
  6. May 21, 2025 at 10:19 AM
    #426
    Breathing Borla
    Northern Illinois
    can you elaborate on that? Im new to pools and need to learn what your talking about
    thanks !!
  7. May 21, 2025 at 10:23 AM
    #427
    AZBoatHauler
    So.Arizona
    Sand, DE, or cartridge refer to the method of filtration for the water.
    the in-ground vs sweeper is the method for cleaning the bottom of the pool
    I had in ground and wasn't impressed with its cleaning ability.
  8. May 21, 2025 at 10:32 AM
    #428
    Breathing Borla
    Northern Illinois
    I was told the in ground for floor cleaning was to avoid since they can leak ,etc
    is that valid?
  9. May 21, 2025 at 10:38 AM
    #429
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    Filtration systems typically use either sand, diatomaceous earth or cartridges. Each has their own pro's - cons.
    In ground cleaners are built into the pool floor and systematically sweep the debris to a central drain point.: In-Floor Pool Cleaning System: In-Floor Pop Up Cleaning System | Jandy
    ...as opposed to a mechanical cleaner that moves along the bottom of the pool via a vacuum line when the pump is running: Pool Cleaners - Hayward Pool Products | Hayward Pool Products
    An auto fill leveler keeps the water level at a certain point. As the water level drops the valve kicks in like a toilet and back fills as needed.
    An aerator is a basic water feature that helps recirculate and cool the water: What Is a Pool Aerator and Are They Worth It?
    Otherwise, I think you're on the right track... :thumbsup:
  10. May 21, 2025 at 10:39 AM
    #430
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    I've never heard that. Heads can pop off/break, but that's about it. The rest of it is just standard plumbing and requires the same maintenance as other parts of the pool filtration system, like inspecting o-rings, gears, etc. The only time in-floor cleaners kinda suck is after a monsoon or when a bunch of leaves drop.
    As for the filter media discussion, cartridge filters are way easier to maintain, but nothing beats the clarity you get from a DE filter. That said, cleaning the DE filter is kind of a pain and a mess, but if you hire a pool company to do your chemicals and maintenance, you can let that be their problem lol.
    The newer pool lights actually throw light much better than the old school side wall ones, so I wouldn't discount that method. It would really depend on how many benches and shelves you include in your design (e.g. we put in a large Baja shelf for lounging and that area stays darker at night because of the height above the light). I've thought about installing perimeter lighting that would work in addition to the side wall light, too.
  11. May 21, 2025 at 10:41 AM
    #431
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    I suppose they could... Our pool was put in in 2015 with an in=ground system and we haven't had any issues with the pop-ups. I think we have 12(?) and just replaced them all free of charge a few years back....lifetime replacement from a local manufacturer. You just need to make sure you keep your filters and any associated baskets clean.
  12. May 21, 2025 at 10:49 AM
    #432
    Breathing Borla
    Northern Illinois
    Im torn on the lounging shelf thing, I can see it being nice, but also taking up swimming space and needing to make the pool a little larger
    was also thinking of maybe just a 0 entry thing instead, especially with the elderly crowd
    rdiddy5 and TRDFerguson[QUOTED] like this.
  13. May 21, 2025 at 10:53 AM
    #433
    Breathing Borla
    Northern Illinois
    Im a minimal maintenance type of dude,
    specifically, I don't mind doing maintenance and like to wrench etc, but I like to set things up to be easy as possible and not try to trip over a dollar to pick up a nickel.
    so far good info guys, thanks
  14. May 21, 2025 at 11:45 AM
    #434
    Vizsla
    Vizsla 2 = 2.5
    Think that comes from pool maintenance companies that don’t have the knowledge or readily available access to parts for the system. I’m on my second pool in AZ with in floor cleaning and wouldn’t own one without. Never clean my pool, don’t even own a vacuum. Monsoon hits, turn pool on and scoop out the big stuff. Neighbors spend lots of time cleaning their pools after a monsoon, f-that. My cleaning system has a lifetime warranty with $125 service call fee. Did use it once, but it was because the turf installer got a bunch of the infill material in the pool that damaged the mechanism in the pop up heads.
    Also wouldn’t build a pool without the baja shelf. Everyone in the family loves it, nice to stick your feet in during off season, dogs really enjoy it also.
  15. May 21, 2025 at 12:01 PM
    #435
    TRDFerguson
    Jake
    2018 MGM CrüeMax
    The zero entry is a cool idea, but you’re taking up even more space with that vs the lounge/baja shelf. I would recommend trolling through some of the galleries for the local builders and get some ideas there
  16. May 21, 2025 at 12:57 PM
    #436
    Breathing Borla
    Northern Illinois
    ya, here is one I want to base it off of I like, take out the spa and swim up bar stuff, no interest in that.
    but the pool shape, color, and I like the way the basic landscape looks.
    so Im kinda using this as a starting point.
    I'll have to talk to them about the space and price of 0 entry vs shelf, vs just some basic ledge/stair thing. My yard is WAY bigger than this so I have room for anything, going to have a large trampoline and a small outdoor basketball court area as well at some point.
    it kinda looks like they have that chair spot where the fountain is
  17. May 21, 2025 at 1:17 PM
    #437
    FrenchToasty
    Mo
    The SoAz….. big surprise
    Bone stock
    Trampoline into the pool sounds fun! Or at least close enough to the house to jump in from the roof?
  18. May 21, 2025 at 1:17 PM
    #438
    Breathing Borla
    Northern Illinois
    lol, no far away, the old lady would have a melt down, lol..
  19. May 21, 2025 at 2:37 PM
    #439
    Azblue
    We used to do that all the time when I was growing up. Then one day my friend dove in from the roof, went the wrong way into the side of the pool and snapped his neck. He got to wear a halo bolted to his skull that year at high school.
  20. May 21, 2025 at 5:35 PM
    #440
    robabeatle
    robabeatle New Member
    AZ
    2002 Tundra 4x4 LTD AC
    Bilstein 6112 & 5160, Katskinz, audio upgrades
    Just note that water features can cause a load of built of dirt to dump into the pool if you only use it occasionally. I have one, capped it off and never use it. Plus anything that is aerating the pool is messing with the chemistry, specifically driving up the ph.
    Also, anything that you get that automates cleaning/echmicals etc. is worth it.
  21. May 21, 2025 at 5:48 PM
    #441
    Breathing Borla
    Northern Illinois
    noted , I think we would use the water features a ton but I’ll see what they say and what I can afford , I want something though to add some spice
  22. May 21, 2025 at 6:26 PM
    #442
    JMGmanAZ
    JMGmanAZ New Member
    Jerry
    Belly of the Beast
    The water hardness is horrible out here, a salt system will really help. My last pool was, this one isn't...yet.
    Our scupper's get real cruddy by the end of the season. I don't run them during the winter. We just had the tile media blasted and water changed the water:
    TRDFerguson and FrenchToasty like this.
  23. Jun 12, 2025 at 4:26 PM
    #443
    Azblue
    NWPirate and Breathing Borla[OP] like this.
  24. Jun 12, 2025 at 4:28 PM
    #444
    Breathing Borla
    Northern Illinois
    yup, blast furnace time
    Azblue[QUOTED] likes this.
  25. Jun 12, 2025 at 4:29 PM
    #445
    NWPirate
    Zach
    WA
    Sign me up. :evil:
    :cheers:
  26. Jun 12, 2025 at 4:32 PM
    #446
    Breathing Borla
    Northern Illinois
    Only one day of sun here in the next 10, lame. Humid as well for this time of year dew point 65+ already
    Azblue likes this.
  27. Jun 12, 2025 at 4:38 PM
    #447
    Breathing Borla
    Northern Illinois
    Starting to lool like a 3rd week of July to move there , right in the middle of the blast furnace but there is nothing I can do about it .
    So it is what it is
    NWPirate and Azblue like this.
  28. Jun 12, 2025 at 4:38 PM
    #448
    Azblue
    Humid sucks. Still dry here, but only for a few more weeks, then we get the joy of these temps + the swamp ass of monsoon humidity.
  29. Jun 12, 2025 at 4:42 PM
    #449
    Azblue
    Nice. When is the pool party?
  30. Jun 12, 2025 at 4:50 PM
    #450
    AZBoatHauler
    So.Arizona
    Peak monsoon season. It'll be awesome.
    Azblue likes this.
