#@%^#%#&*^&@!! Mouse!
Discussion in '2.5 Gen Tundras (2014-2021)' started by tech1208, Jan 10, 2020.
  1. Jan 10, 2020 at 7:04 AM
    tech1208
    tech1208 [OP] Old Salt, New truck
    Orlando, FL
    2023 Tundra Platinum 4X4 Blueprint Blue
    So I park at the Cruise terminal for the weekend in Miami. Upon return on Monday, I start to drive the family North to Orlando. I start to get high temp coolant warnings. I stop at a rest area, and can't see a thing. No steam, no liquid, I smell coolant, and see the reservoir is slightly low. I add 12 ozs of water to the overflow and continue North again. I get almost home and the temp sensor warning goes on again. Each time the temp goes back down within five seconds to normal range. I let the truck sit overnight at the house, and drive into the office next day and coolant temp sensor goes off again. I go straight to Toyota, and they put me in a loaner. After two hours, I get the attached pics.
    Damn mouse ate the coolant lines under intake on the valley plate. 1200 miles on the truck. Only upside, was no damage to the engine or any wiring harnesses. $750.00 later, I will have the truck back next Tuesday. Royal Caribbean and the Port have told me they can't control rodent/pest problems, and I'm on my own. Garage is owned and operated by Royal Caribbean. I'm following up with written correspondence and documents this week after I get the truck back.
    Frigg'n Mouse!!!!!!
  2. Jan 10, 2020 at 7:14 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
    Plenty of threads on his subject!! Dryer sheets and some type of oil in engine bay.
    Search window is your friend!!
  3. Jan 10, 2020 at 7:19 AM
    Pinay
    Pinay New Member
    Monet
    Mahal kita Kuya
  4. Jan 10, 2020 at 9:22 AM
    This is one of the cheapest repairs I have seen. Most are 3000.00 plus.
  5. Jan 10, 2020 at 9:52 AM
    BlueDream
    BlueDream New Member
    2015 Tundra Dbl cab SR5 5.7
    6" procomp stage 3 lift, Method NV 18x9, Cooper STT pro 305/70R18, AFE air cleaner, LED fogs, Ranch hand Grille guard, Rhino liner, retrax bed cover, Flowmaster Duals, 15% Tint, vinyl chrome delete
    Holy shit!! Thats fuked up. Just last week, wife started her Suburu, and immediately squeeling and smoke from engine compartment. She looked under hood, and called me. Belt had slipped. I told her call tow. So busy they hadnt showed up for 4 hours. So I got in the truck and went to her at work. While fixing the belt, I discovered the cause of problem. Big male rat, trying to make a warm home. Bad news - for him, he was cut into pieces. Picked his pieces out and fixed the belt. Not a happy camper.
