Mountun Goat’s Anatomy Thread
Discussion in '2nd Gen Builds (2007-2013)' started by Mountun Goat, May 6, 2018.
  1. Apr 30, 2020 at 9:15 PM
    #271
    Mountun Goat
    Mountun Goat [OP] She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    I primed the rack tonight. I’m hoping to Raptor line it this weekend. Stay tuned.
    BestGen, Pinay, TheBeast and 2 others like this.
  2. Apr 30, 2020 at 9:33 PM
    #272
    Hbjeff
    Hbjeff New Member
    Huntington Beach
    2010 DC 5.7 2wd
    Looks nice! I wish is had 1/5th of your fab skills
    Mountun Goat[OP] likes this.
  3. Apr 30, 2020 at 11:16 PM
    #273
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks, I have a lot of bravado, it helps haha.
  4. May 1, 2020 at 4:23 AM
    #274
    Rube207
    Rube207 New Member
    Rob
    Atlanta
    2010 Pyrite Mica Limited CM
    Since you’re not sure of the final tweaks yet, I think it would probably be fine for a bit just how it is on the truck. Save yourself the trouble of grinding down and re-raptor lining later. Or you could add a layer of black spray paint/primer to give it a little additional protection from the elements and make it the right color (for now).
    Looks great!
  5. May 1, 2020 at 7:13 AM
    #275
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks! Fair enough, I might try this, as it will need to be lightly sanded prior to bedline anyway. I’ll see how my ADD is this weekend haha, maybe I’ll be able to refrain from spraying it :)
  6. May 1, 2020 at 7:17 AM
    #276
    Outbound
    Aaron
    Northern Alberta
    Looking good. :)
  7. May 1, 2020 at 7:17 AM
    #277
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Ok, the shop got a little crazy last night. I decided to mod my taillights unlike anyone else (as far as I know).
    First, I broke all the lenses off the housings. Then cut holes up top for the led truck brake lights. I’m going to buy clears for the reverse ones below today. Once done, I will bedline the light housings color matched Quicksand to match the truck body. These will be easy to swap on the trail if a light breaks as well as makes the tail lights a bit smaller and less bulky (imho :))Thoughts?
  8. May 1, 2020 at 7:19 AM
    #278
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks Aaron! Putting hours in!
    Outbound[QUOTED] and Y0TA PR0 like this.
  9. May 1, 2020 at 10:09 AM
    #279
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I went and picked up reverse lights this morning. The lower holes are a bit too big to fit the 4” led’s, so more modification was needed. I cut out some plastic to fill in the lower bulbs refractor openings that I cut out. Now the epoxy is drying. Once dry, I’ll cut new lights mount holes and primer!
    Ps: don’t ever toss old junk away (like the center console devider thing I got extra plastic from haha)
  10. May 2, 2020 at 9:32 AM
    #280
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Ok I added some bondo to the filler piece to strength, then cut out the lower light hole once dry. I’m in a bit of a wiring pickle now... As the tundra has separate loops for signal and brake lights, it seems I need to keep the circuits separate. So, that means I either have to buy new lowers with a signal light included and add signal lights as pictured (none in town so have to order and wait). The strip I would drill hood in the housing and mount the led strip behind the housing I’m thinking if I go that route. Thoughts? Tips?
  11. May 2, 2020 at 5:16 PM
    #281
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    I finished the lights up today. I added stand alone dot signals and a 10” red underglow led strip signal per side. Also, I tied in and mounted the resistors. I’ll take some lit pics tonight for y’all. Despite the rough finish on the light housings, I’m happy as I’m sure the Quicksand bedliner will hide the imperfections. I will leave them primed until I do the whole body, for perfect color matching.
  12. May 2, 2020 at 6:12 PM
    #282
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Well here’s the end setup. This allows me to have a spare universal reverse and taillight incase for some reason one breaks. These are also the same taillights in our horse trailer, so that’s handy. Once the light housings are color matched should look pretty neat imo :) Kind of an exo-taillight haha.
    Chrslefty, BestGen, Wynnded and 6 others like this.
  13. May 2, 2020 at 6:14 PM
    #283
    Came out real nice! Kind of cool actually.
  14. May 2, 2020 at 6:15 PM
    #284
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks man, this one is a bit edgy even for me haha.
  15. May 2, 2020 at 6:16 PM
    #285
    Surprised nothing broke or cracked..heh...heh..
  16. May 2, 2020 at 6:17 PM
    #286
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha, well there are a few imperfections. The light housings have a few cracks from years of use. I epoxied what I could and am hoping the bedliner covers the rest :burp:
    Y0TA PR0 and Black Wolf[QUOTED] like this.
  17. May 3, 2020 at 7:51 AM
    #287
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Here’s some lit pics for y’all. Pics don’t do any justice on how much brighter they are. I can see in reverse for the first time!
  18. May 3, 2020 at 8:28 AM
    #288
    Outbound
    Aaron
    Northern Alberta
    I actually kinda of like it. I was iffy at first, but seeing it now it's grown on me.
  19. May 3, 2020 at 8:30 AM
    #289
    Yzed608
    Yzed608 New Member
    Wisconsin
    Turned out good, definitely creative!
  20. May 3, 2020 at 9:20 AM
    #290
    Y0TA PR0
    Y0TA PR0 Oil & Gas
    Rafael
    2017 TRD PRO
    Turned out good! Nice work Dan!
  21. May 3, 2020 at 5:31 PM
    #291
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Haha thanks me too. Honestly, the more I’m seeing them, the more I like them. A couple people even said oh you got new taillights? Like, ya, sort of new, I guess? Haha
    Outbound[QUOTED] likes this.
  22. May 3, 2020 at 5:31 PM
    #292
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thanks dude!
  23. May 3, 2020 at 5:31 PM
    #293
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Thank you sir :):hattip:
    Y0TA PR0[QUOTED] likes this.
  24. May 11, 2020 at 4:52 PM
    #294
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    This will be one of the very few things I cannot take credit for on the goat. I got a shop to remove the 12 year old front catalytic converters and the old housings from the rear ones I gutted a while back. Anyway, he did a real good job on it and used mandrel bends. It sounds a lot crisper and better downshifting now. Used to sound a tad groggy. I’m stoked on the results.
  25. May 15, 2020 at 1:02 PM
    #295
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Got the sliders and rear bumper rust proofed today! Por-15 for the win!! I’m very impressed with it so far. I’m rolling these because I’ll be covering them with bedliner after. I have to say por-15 is user friendly as it seems to self-level and smooth out. Glad I got the them weather proofed, as it’s supposed to rain on and off this weekend. Front bumper rust removal next up!
  26. May 16, 2020 at 11:22 AM
    #296
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Doing some cleanup!!
    BestGen likes this.
  27. May 16, 2020 at 5:47 PM
    #297
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Had quite a productive day today with rust removal and por-15 coating. Didn’t snap a pic, but did the wiper arms as well. All of this black stuff will be coated with black Raptor liner next.
    BigSkyTaco, BestGen, Y0TA PR0 and 3 others like this.
  28. May 18, 2020 at 6:38 PM
    #298
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    My Dad gave me this old spare bumper light housing he found he had! How handy since just the driverside one on my bumper was cracked! Score!!!
    Y0TA PR0 likes this.
  29. May 24, 2020 at 5:07 PM
    #299
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Got the truck prepped for black liner today. Wife ran to check on the horses, I will spray first coat around 8pm tonight :cool:
    BestGen, Yzed608 and Squatting Pigeon like this.
  30. May 25, 2020 at 7:18 AM
    #300
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
