Mounting to the Composite Bed
Discussion in '3rd Gen Tundras (2022+)' started by obgod3, Jan 25, 2023.
  1. Jan 25, 2023 at 5:06 AM
    obgod3
    obgod3 [OP] New Member
    NC
    2023 Tundra Limited
    Has anyone permanently mounted anything to the composite bed on the 22/23 Tundra? If it was a steel bed I would have no issues with it but this composite bed is new to me. I have dirt bikes and I want to mount either a etrack system or wheel chocks or something like this to the bed and Im not really feeling it .....info, advice, thoughts....
    Thanks
  2. Jan 25, 2023 at 5:37 AM
    raylo
    raylo not so new member
    Frederick, MD
    None
    Only thing I would say is for anything that will carry weight or have a heavy pull use a metal backing plate on the other side of the composite to mount the fittings. Bigger will be stronger. But of course it may be difficult to gain access to fit these.
    obgod3[OP] likes this.
  3. Jan 25, 2023 at 6:50 AM
    korslite
    korslite New Member
    Justin
    Bellingham, WA
    2022 SR5 TRD OR 6.5' Bed
    I would venture a fairly uneducated guess that the composite bed is going to be less prone to stretching under tension and fatigue cracking over time than the old sheet metal bed was. The camper tiedown eye bolts in my 2020 had stretched the sheet metal bed pretty significantly over the course of a year even with large backing plates.
  4. Jan 25, 2023 at 7:02 AM
    TheLordwoulddriveaTundra
    TheLordwoulddriveaTundra New Member
    2022 Tundra Platinum Crewmax 4WD, Mag Grey
    Talons Cat Plate Tuff Skinz Inserts RetraxOne XR Bed Cover Premium Shield PPF Revivify Coating OEM Console Safe WeatherTech Mats
    I would guess the same. But I would add that where the metal stretched, the composite will snap, crackle and pop.
    obgod3[OP] and DFS like this.
  5. Jan 25, 2023 at 9:26 AM
    obgod3
    NC
    2023 Tundra Limited
    thanks everyone ! I'm little uncomfortable with the idea of drilling and mounting on the bed. Think I can come up with a different idea to use the Bed Rail System, will post when I figure it out.
