Mounting a Vise
Discussion in 'Home Improvement' started by Ckatz53, Jan 1, 2021.
  1. Jan 1, 2021 at 3:58 PM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    2020 Cement Tundra CM Limited 4x4
    www.fouroneodetailing.com
    Running into some design issues mounting my new Yost 750-DI vise. It's a 360 degree swivel, 4 anchor point vise.
    I picked up a 1" thick treated oak board at 32" long, 10" wide for a support base to go onto my 2' deep workbench with a 2" thick hardwood top. Grade 8 hardware will be used to bolt the board to the bench then the wise to the board.
    I can left side mount it to clear the front and left side of the bench with a long vertical object (used scrap wood to test) to ensure clearance and give me 90 degrees of rotation. My father seems to think I should mount it forward of the bench so that I can utilize 180 degrees if need be (this would entail using a fence post support underneath the overhang). The workbench, although heavy, is NOT anchored at this time and won't be for the foreseeable future. Just moved into this house and new garage space and want to give it some time before I decide on permanent locations for things.
    My question: does anyone have any experience with a vise that swivels 180 degrees for a workspace (namely is it even necessary)? I've only ever had a single plane to work with on a vise so just the fact that I can swivel 90 is a huge bonus. I'm not sure if the extra juice is worth the squeeze. Attached a rough mockup to give an idea of what I'm working with (not drawn to scale).
  2. Jan 1, 2021 at 4:14 PM
    1lowlife
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    This may or may not help you.
    I've had my vise mounted like this for 13 years and never had an issue of not being adequate.
    Please forgive the messy workbench..
    srjlenes_3069d55b246a5a41dd639508b4326b3afb53c5b3.jpg a3j0jzf4_9ae1f70ddc408bb35e86bf7cad8a3c3c03c978dd.jpg
  3. Jan 1, 2021 at 4:17 PM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    This is how I had planned on it, easy and simple. But pops' suggestion has me second guessing lol.
    1lowlife[QUOTED] likes this.
  4. Jan 1, 2021 at 4:33 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k Supercharged 2008
    I do the corner mount for 90deg of grabbing stuff. Also depending on what you're doing, Grade 8 is extremely overkill. I just used some lag bolts personally, unless you're trying to hold a truck with your vice, you could save a few bucks if you want.
  5. Jan 1, 2021 at 4:45 PM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    I'll be using it for some heavier duty work. Yost recommends grade 5 at a minimum. I have a rack of 8s from various projects over the years so I'm just reusing. I think I'm just gonna keep it simple. Can't think of WHY I would need 180 degrees of swivel.
  6. Jan 2, 2021 at 5:28 PM
    Ckatz53
    Ckatz53 [OP] Newish
    MD
    Sumbitch isn't going anywhere.
