MORIMOTO XB LED HEADLIGHTS 16+
Discussion in 'Lighting' started by eledobleu, Feb 13, 2019.
Thread Status:
Not open for further replies.
  1. Nov 27, 2019 at 6:36 AM
    #721
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 Tundra 1794 DiamondBack ATV Tonneau Cover 7" BDS Lift 20" Fuel Krank Wheels 37X13.50X20 Toyo Open Country M/T
    Per their instructions any other LED light (as in tail lights) will cause hyperflashing. Perhaps install a resistor to the fronts?
  2. Nov 27, 2019 at 6:36 AM
    #722
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    Sorry I don't.
  3. Nov 27, 2019 at 6:37 AM
    #723
    MJoeP
    MJoeP New Member
    Joe
    2016 Tundra 1794
    2016 1794 edition. I did have the lower DRLs already. No dash light warning on mine.
  4. Nov 27, 2019 at 6:40 AM
    #724
    coTony
    Tony
    Montrose, CO
    You would install the resistor to the rear lights which is where the problem is.
  5. Nov 27, 2019 at 8:58 AM
    #725
    coTony
    Tony
    Montrose, CO
    Well after it was mentioned that buying from Lightwerkz.net that they were not an authorized dealer so the lights do not come with a warranty I checked with them and I was told they are the largest dealer and they advised people spreading the word to stop. I see that statement was removed
  6. Nov 27, 2019 at 9:37 AM
    #726
    Cptnfun
    Cptnfun New Member
    I have 2017 crew max sr5 installed the relay flasher in the dash and I have hyperflashing blinkers now on sequential mode.It a different problem than that your reference to
  7. Nov 27, 2019 at 10:26 AM
    #727
    Cfincke
    San Antonio
    FYI - The retrofit Source have the lights on sale for $925, no code needed
  8. Nov 27, 2019 at 10:27 AM
    #728
    YotaMan
    YotaMan Silver Bullet
    Colorado Springs
    2021 Platinum
  9. Nov 27, 2019 at 12:26 PM
    #729
    dv8TRDPRO
    dv8TRDPRO NOOGTRDPRO
    Chattanooga
    2017 Tundra Pro White
    Weather Tech mats, Stubby antenna, AJT gear shift knob, AJT keyfob, Tundra door sill protectors, Cup holder inserts, door pocket inserts, console inserts, Tundra tailgate letter, and TRD PRO bed insert. Kenwood dnx996xr 1299 with navigation, vehicle gauges, and tire pressure sensors gauges Keyless Remote CL6 app remote start 4 rolls of sound shield 1 Jl rd 900/5 2 Jl c2 650 components 2 Jl 10w1
    Just order from LightWerkz about two hours ago and just got my shipping info. Very friendly and made sure to I got the harness needed for the DRL.
    Got the Morimoto fog lights also.
  10. Nov 28, 2019 at 8:38 AM
    #730
    ProjectNightTrain
    ProjectNightTrain New Member
    Ithaca, NY
    2015 Toyota Tundra limited trd crewmax 4x4
    6in ProComp stage 2 lift 20x12-44 fuel octane wheels 35x13.5r20 nitto ridge grapplers 4:88 gears with auburn lsd Spectry cold air intake Custom exhaust Complete led package from headlight revolution Spod system switches TRD pro grill Fog light mod
    Anyone that got their Morimoto. Have any issues with trying to get the turn signals to work. I have led with resisters in all 4 corners of the truck. Tried cutting off the front two and still nothing. Replaced the relay with the one they gave me bc I didn't have a drl strip on my 2015. Any ideas
  11. Nov 28, 2019 at 9:57 AM
    #731
    mac2118
    mac2118 New Member
    Tom
    I just got mine installed, takes about an hour including the relay swap. The only thing that confused me is that the turn signals only work when the vehicle is running (I didn't try with the key in the accessory position). I'm assuming that they get their power directly from the fuse box and it needs power to give out power. I'm getting it inspected tomorrow; so we'll see if that's a problem or not. They don't really have the "fit" as the oem ones do, but as long as they out perform the oem ones, I won't care.
  12. Nov 28, 2019 at 10:52 AM
    #732
    coTony
    Tony
    Montrose, CO
    No vehicle I have every owned had the turn signals work with the key off, FWIW
    louscrw and AZTundra like this.
  13. Nov 28, 2019 at 11:17 AM
    #733
    ProjectNightTrain
    Ithaca, NY
    Update For those who wonder. I have stock tail lights with led lights and had resistors in all 4 corners on the truck. In order for me to get the turn signals to work I cut all of the resistors out and they worked but had hyperflash. I rewired in the front resistors that I used with my oem housing with led upgraded bulbs from gtr lighting and boom fixed my hyperflash Problem. So as of now I have resisters in the front but not the back. Hope this helps anyone that may get confused like I did.
    DigitalFusion likes this.
  14. Nov 28, 2019 at 12:36 PM
    #734
    Cptnfun
    Cptnfun New Member
    I have spyder taillights and Morimoto headlights.The turn signal will only work with the Morimoto headlights in normal blink mode.If I try to use the sequential blink mode both front and back hyperflash.I bought the Morimoto for the sequential blinker so not happy about it at all.Headlight revolution is telling me I now need resistors in the taillights in order for sequential blinker to work.From what I read here do not know if that will fix it or not.Any help with a setup like this would be much appreciated.
  15. Nov 28, 2019 at 8:14 PM
    #735
    mac2118
    mac2118 New Member
    Tom
    ya... it was a long day. did the install outside in the rain/snow. low beam and high beam pics are attached
    dv8TRDPRO likes this.
  16. Nov 29, 2019 at 7:08 AM
    #736
    BRYMTIME
    BRYMTIME New Member
    Andrew
    Portland, TX.
    21' 1794 CM
    Zone Offroad 5 Inch Lift Nitto Ridge Grapplers 35x12.50xR20 Fuel Wheels - Rogue D709 Chrome Delete - Match Paint & Wrap LED Lighting Upgrade (Headlight Revolution) Decked Truck Bed System Full Factory Speaker Swap - Installed JL 10 Inch Subs & Amp. Helix Door & Dash Speakers. ( All Equipment & Custom Sub Box - Tech 12 Volts)
    FYI. The Retrofit Source has the XB headlights on sale for$925. Free shipping, 3-5 business days
  17. Nov 29, 2019 at 7:25 AM
    #737
    BRYMTIME
    BRYMTIME New Member
    Andrew
    Portland, TX.
    21' 1794 CM
    I still have not received a refund, or an email. I filed a claim with my credit card company, I recommend you do the same.
    19Platinum likes this.
  18. Nov 29, 2019 at 10:35 AM
    #738
    DigitalFusion
    DigitalFusion New Member
    MN
    '15 Platinum Crewmax
    I got my email late Friday night, so its only been a few actual business days. CC refunds are always slow, personally, I wouldn't file a claim just yet.
    BTBAKER likes this.
  19. Nov 29, 2019 at 11:15 AM
    #739
    eledobleu
    eledobleu [OP] retrofitwholesale.com
    Orlando, FL
    Koito Bi-LED Retrofit
    If you didn't receive an email in your inbox check your spam folder or confirm your email address on file.
    Yes there's only actually been A few few business days that passed confirmation refunds was sent on Friday and yesterday was a holiday. Some received the refund Tuesday and Wednesday but again it depends on your bank. Sons refund fast but most are extremely slow. Your more than welcome to file a claim with your Cc company if you'd worried.
    Also, TRS has a mega sale going on which puts the lights at $925 plus free led fog light and free shipping good until December 3rd. Us dealers can't match it better act on this deal they have
  20. Nov 29, 2019 at 6:21 PM
    #740
    19Platinum
    19Platinum New Member
    2019 Magnetic Gray Tundra Platinum
    I didn't receive my refund either. I called Discover(my CC company) and they told me that if a refund was issued I'd see it pending within 2 business days.
  21. Nov 30, 2019 at 7:52 AM
    #741
    DigitalFusion
    MN
    I get that some are worried about getting their refund. Your CC provider will easily be able to a chargeback for quite some time. I urge others to refrain from doing so because if they get a slew of chargebacks in a short period of time eledobleu's account could have some adverse restrictions applied.
    Even if he took the money and dropped off the face of the planet (which is beyond extremely unlikely) your CC would still refund your money.
  22. Nov 30, 2019 at 9:35 AM
    #742
    eledobleu
    Orlando, FL
    This... I refund the money through whichever payment gateway you used rather it be PayPal, stripe, 2 checkout etc. Most state Thad refunds typically take 5-7 business days not including holidays. So next week you should see the refund for those that didn't get it last week.
    Like @DigitalFusion stated, either way you'll get your refund. If you file a dispute and the refund goes through before the dispute is closed then they'll close it and mark your account as well. If you don't see refunds next week let me know. But some already posted in this thread that they received their refund so no need to worry.
  23. Dec 1, 2019 at 3:15 PM
    #743
    DigitalFusion
    MN
    I totally spaced that I put LEDs in the tail lights, and I have the hyperflash issue. (only with turn signals, harzards work fine?!?!)
    Maybe I missed it, but has anyone confirmed that resistors in the tail lights fix this issue?
    EDIT: I had a set of these laying around for some reason:
    https://www.amazon.com/Resistors-Signal-License-Warning-Cancellor/dp/B004EDF8HY?th=1
    I installed them in the tail lights and I still have hyper flash.
  24. Dec 1, 2019 at 4:51 PM
    #744
    DigitalFusion
    MN
    UPDATE: It was just a bad connection. I installed those resistors in the tail lights and now my hyper flash with sequential in the front is fine.
    The black housing looks sexy AF with black TRD grill.
    Newm and gdisarray like this.
  25. Dec 3, 2019 at 7:29 PM
    #745
    Cement79
    Cement79 New Member
    G
    San Antonio,TX
    2019 cement 4x4
    Bilstien 6112/5160 leveling kit, amp research steps,18x9 fuel vapors, 33” nitto ridge grapplers,morimoto fog lights
    Hey guys! New member here in Tx.
    Im interested in these lights, for anyone who has installed them does the stock headlight adjustment on the dash still work with the morimotos?
  26. Dec 4, 2019 at 8:12 AM
    #746
    DigitalFusion
    MN
    Welcome to the site! Yes, the headlight adjustment/leveler still works with these lights, and unlike a lot of other lights out there, you do not have to remove the motor from your stock lights and install it on these because they come with a motor.
  27. Dec 4, 2019 at 9:24 AM
    #747
    TheRetrofitSource
    TheRetrofitSource New Member
    Came here looking for something else - but couldn't help but notice that we (TRS) were being thrown under the bus for apparently purposely delaying shipments.
    That is not true at all. As another member suggested after placing an order with a different vendor and got his tracking number the very next day....if we get an order, we ship it, simple as that!
    To any of you who took advantage of the deal we had on the Tundra XB's over Black Friday- BIG THANKS! our warehouse is cranking out 1500 orders a day and filling up every UPS truck that comes our way. Happy Holidays everybody
  28. Dec 4, 2019 at 9:45 AM
    #748
    Cement79
    Cement79 New Member
    G
    San Antonio,TX
    2019 cement 4x4
    Awesome, thanks for the info! Im gonna pull the trigger on getting them from lightwerkz today.
  29. Dec 4, 2019 at 9:56 AM
    #749
    gdisarray
    gdisarray Short term member
    2023 Tundra Limited HV
    Tint and wheels. Decked box in the bed. S and B Cold Air filters under the hood. Shiftpower throttle response controller.
    I knew OP @eledobleu was bullshitting on the ship date. He arranged an interest free loan on our backs. He held up placing the orders with TRS. When he had the money back in his pocket he tried to place the orders with TRS the pricing had changed. So he is refunding. If he had placed the orders right after the gb was over he could have delayed the shipment at that time for whatever reason at the good price. But he didn't have the money at the time. That is why he was dragging it out and not forthcoming.
    drumzdj, DigitalFusion and Pudge like this.
  30. Dec 4, 2019 at 10:18 AM
    #750
    DigitalFusion
    MN
    I'd go with TRS if they still have that sale going on
Thread Status:
